Comfy Thin Beanie for Giant Head
All the beanies/skull caps I try on are way to tight on my head. Need something for 25-35 degrees. Any suggestions?
Quoted: 20810 Post(s)
Liked 9,456 Times
I have a big head, not sure if it's giant. Anywho, my favorite lighter weight hats are the reversible ones from Smartwool, they cover the ears and fit under a helmet nicely - https://www.rei.com/product/191707/s...ersible-beanie
Likes For WhyFi:
Quoted: 18883 Post(s)
Liked 10,646 Times
Synthetic beanie
https://arcteryx.com/us/en/shop/motus-beanie
Wool beanie
https://arcteryx.com/us/en/shop/rho-ltw-beanie
Wool neck gaiter
https://arcteryx.com/us/en/shop/rho-ltw-neck-gaiter
A neck gaiter can be worn like a beanie with a vent. If you run hot, but need to cover your ears and forehead while allowing some heat to escape, that's the answer.
Wool beanie
Wool neck gaiter
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
I have one made from Alpaca. Can be hard to find but a very comfy alternative to regular wool. Also, if you truly have a giant head and can't get a fit, you might try fashioning something by cutting a leg off women's tights. They come in some really large sizes and a variety of fabrics.
Likes For shelbyfv:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
I wear an old firefighter's balaclava that I have from a past life. They are designed to be worn under a helmet. It is something like this one:
https://www.thefirestore.com/store/p...FPA-1971-2013/
You can get different models that include more shoulder coverage but I just go with the ones I have on hand. When the temperature is colder than your range I add in a Cold Avenger. Then heated goggles...
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,860 Times
Just ordered three of these on sale
https://www.jans.com/buff-lightweight-merino-wool-hat
but my head has normal circumference (if oddly shaped).
Quoted: 3241 Post(s)
Liked 2,512 Times
I've had good luck with these. I use them on the bike and night running in 20s temps.
https://www.amazon.com/Helmet-Liner-...hopifytough-20
I also have a couple of their gaiters.
Liked 10,646 Times
Likes For Seattle Forrest:
Quoted: 2432 Post(s)
Liked 638 Times
I wear a cheap cotton bandanna and pull it over my ears and it's actually fine down to 32 degrees which is my limit. If I warm up I just push it up over my ears. I may buy a merino wool one.
Quoted: 5224 Post(s)
Liked 3,581 Times
