28.6 Clamp On Downtube Shifter Bosses
Old 06-19-22, 04:29 PM
etherhuffer
etherhuffer's Avatar
Bikes: Surly Long Haul Trucker,81 Fuji Gran Tour SE, 83 Fuji S12S LTD, Voyageur 11.8 chrome, Raleigh R300 Touring, Voyageur 11.8
Quoted: 283 Post(s)
Liked 500 Times in 226 Posts
I have some adjustable cable stop ends I would like to use on a frame with no bosses. I don't need vintage and not finding a lot. Some old stuff is crazy expensive. Anyone recently found/used anything that looks decent?
etherhuffer is offline
Old 06-19-22, 05:15 PM
juvela
juvela's Avatar
Quoted: 3801 Post(s)
Liked 3,324 Times in 2,170 Posts
the message header and content sound separate
perhaps you could clarify your meaning or post images...
since you are in an urban area would think you could find any small pieces you require at low cost via a co-op by sifting through their parts bins
juvela is offline
Old 06-19-22, 06:40 PM
nlerner
Quoted: 3802 Post(s)
Liked 6,624 Times in 2,596 Posts
So you want to put modern downtube cable stops on a frame without brazed-on bosses? If so, a fair number of clamp on downtube shifters will work (without the shifters, of course). I’ve also retapped an old Huret band clamp to accept M5 bolts and those cable stops. You can also use a fairly common SunTour, Shimano, or Campy cable stop for bar-end shifters. It won’t have a barrel adjuster to take up cable slack, but if you can do that at the shifter and/or derailleur end, it would work.
nlerner is online now
Old 06-19-22, 08:19 PM
etherhuffer
Quoted: 283 Post(s)
Yes. I can do cable adjusters up top or on the downtube but since I have spare ones that mount on downtube bosses, that was the preferred choice. I think as noted above it may be time to root around for parts at the recycle places. I thought there were more out there of recent make, like the downtube cable guides that clamp on, but not so.
Old 06-19-22, 09:13 PM
Mr. 66
Mr. 66's Avatar
Quoted: 1134 Post(s)
Liked 1,726 Times in 950 Posts
I got a little crafty the other day.
Mr. 66 is online now
Likes For Mr. 66:
Old 06-19-22, 10:12 PM
etherhuffer
Quoted: 283 Post(s)
Yep, that is exactly where I am heading. Did you have to grind on the posts or tap them?
Old 06-20-22, 06:55 AM
Mr. 66
Mr. 66's Avatar
I first cut the lever stop and removed, then I found it's not a pressed washer. I had to grind that area round to match the boss with my dremel. It was more effort than I thought it would be. Not a ton of effort, about 30 minutes. I did this all hand held, probably could have been a little easier if I used a vise to hole the band.
Old 06-20-22, 07:07 AM
Classtime
Classtime's Avatar
Quoted: 1946 Post(s)
Liked 2,004 Times in 1,105 Posts
Problem Solvers?
Classtime is offline
Old 06-20-22, 09:00 AM
etherhuffer
Quoted: 283 Post(s)
Originally Posted by Classtime
Problem Solvers?
That's it! Thanks! Going on a black frame so that works.
Old 06-27-22, 04:55 AM
arex
Abuse Magnet
arex's Avatar
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times in 88 Posts
There's also this:
https://problemsolversbike.com/produ...ackstop_-_1282
arex is offline
