Bottom brackets, Road/Mountain
I have a Sugino triple I want to use for a build. I see Sugino suggests 110 BB vs 113 BB for road vs mountain. Why the difference on the two? Inner chainring clearance?
Really Old Senior Member
130mm vs 135mm drop out spacing?
Split the diff.
Split the diff.
Aha! Got it. Thanks
Don't be too obsessive about CL.
It presumes you use all cogs & rings an equal amount and gives the best "average" CL.
That may work for robots.
I tend to use the middle ring & outer cogs the most.
I use the next longer BB to give me a best average CL for the gears I use the most.
Likes For Bill Kapaun:
Quoted: 4371 Post(s)
Liked 1,549 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Off-road frames often have curved chainstays to accommodate wider tires, and need the crank arms positioned further out to clear the stays.
Mad bike riding scientist
Quoted: 6215 Post(s)
Liked 4,213 Times
It depends on the crank design. While mountain bike frames are wider, some mountain bike cranks use narrower spindles than road bike because the arms curve inward towards the frame more than road cranks do. For the Sugino cranks in question, the recommendations are correct but they might not be for other cranks.
Stuart Black
Stuart Black
Liked 1,549 Times
Yabut…
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Yabut…
care to present an example of these mysterious reverse curving MTB cranks, Cyco? the ones i've seen/installed/stock all "curve" outward, then go parallel to the main frame line before reaching the pedal threads.... not one "curves" in.. not one. except a badly bent 105 crankset that already went to the scrap heap.... someone parked a Buick on top of that bike...
Liked 4,213 Times
Because there is no such thing as a “designated spindle” when it comes to internal bearing bottom brackets.
Stuart Black
Stuart Black
Liked 1,549 Times
