external power bank for sport cam
Quoted: 5218 Post(s)
Liked 3,564 Times
a little reminder, maybe just to myself? if any rain is expected, take precautions, or use the small interior batteries
I went out last night & got a little wet, but just a little. didn't hear, or smell, any frying electronics
Your camera isn't in its waterproof casing? Just put your battery pack inside a plastic bag.
Likes For Daniel4:
Liked 3,564 Times
the camera is waterproof w/o a casing. I'll just use the little batteries if there's active wetness like that again. I don't usually ride in the rain. sometimes wet snow, but even riding in an active wet snow storm is very rare. I can probably just tape around the connections at the camera & battery to avoid some miscellaneous drops getting in for an hour. my wet rides are pretty short. also gonna rethink batteries in my jacket pocket
Along for the ride
Quoted: 109 Post(s)
Liked 209 Times
But since late 2019 I've been using a pair of Drift Ghost X video cameras that came with 5 hour battery modules that lasted a true five hours per charge for the first year, and a little less the next year. I just replaced one battery module that finally wouldn't hold a charge, with Drift's newer 8 hour battery modules. These snap into the camera body and are weather sealed, no optional weather housing needed so far for the rainy rides I've encountered. No need for a backup battery for most long rides.
I highly recommend the Drift cameras for basic ride documentation for traffic safety and legal purposes. Beats messing with external battery packs for most other popular bike cams -- GoPro, Cycliq, etc. (In fact, the attorney who represented me after I was hit by a car a few years ago had the Cycliq and was disappointed in the runtime and reliability. I recommended the Drift cams.)
Likes For retswerb:
Quoted: 4559 Post(s)
Liked 2,798 Times
Thanks for this - I went looking on ebay after reading your post a few weeks ago and was able to pick up a used Drift for $31 including shipping. Haven't fully tested the battery life yet but it seems to be quite good, with decent video quality. Still figuring out how best to mount it.
Blu-Tack and Scotch detachable putty can be molded to any shape, holds securely, yet detaches without damage to most hard surfaces. I've used the stuff for at least 10 years on various projects, including outdoor mounting of wire antennas for my shortwave radio, to hold the wire against the brick exterior of my apartment complex. It held for months, much more securely than I'd expected.
I prefer to mount the camera on the top rear of my bicycle helmets for better balance. It puts the camera weight over my spine, so it causes less neck strain (I have pretty severe cervical spine stenosis, and I'm very picky about pressure on my head and neck).
To get the camera aimed where I'm looking, rather than down at the ground or up into the sky, I need to build up a wedge from the Blu-Tack or Scotch putty. I guesstimated it the first time, mounted the camera and did some test videos from my indoor trainer, while walking, and riding around the block. Usually it was very close and needed only minor tweaks in wedge shape and height to get the camera aimed where I wanted it.
On my hybrid with rear rack, I've used Blu-Tack putty to secure a Drift helmet mount for rear-facing camera. Works fine and would be a good solution for any bike with a rear rack -- which excludes all of my road bikes, unfortunately.
I also have a couple of Drift bar mounts but they're a bit crude and not practical for a rear facing camera. I've mounted the bar mounts on the seatpost or seat tube, etc., facing rearward, but the knobs for the thumb screws tend to scrape the insides of my thighs. So for now I'm not using a rear-facing camera. But those bar mounts work fine on the handlebar, stem or possibly some head tubes. I'd like to find a better solution but I suspect I'd need to have a clamp custom made by a 3D printer to suit my preferences. I'd prefer a flush mount Allen, Star or other bolt rather than the protruding thumb screws. And better quality detents for adjusting and holding the camera angle.
Likes For canklecat:
Liked 3,564 Times
turns out the GoPro comes w/ a wire. nice black one. tried a different mounting spot for the power bank, which I still have not charged. could have mounted it further back I guess
Liked 3,564 Times
assembling some components ...
got the off-brand door
bought a battery not realizing how big it was so I also got a smaller one
not sure where I'll be using the battery, relative to the camera placement, so got a cpl long wires & some short ones
short ones are fun looking
those batteries are waaay bigger than necessary
didn't need any wires because the gopro comes with one, that is long enough, when both are helmet mounted
Liked 3,564 Times
quick note to myself
for my purposes, may not need an external power source for the camera after all
3 internal batteries may be enough
might still carry one on epic long rides just in case, but for regular rides of 1-2 hrs, w/ only sporadic recording, even in cold weather, don't think I need it
I carry 8 spare batteries with me for my two cameras. That's enough for an 8hr45min ride in good warm weather. Probably 7hr in cold weather. My SD cards have memory six hours.
Likes For Bald Paul:
Liked 3,564 Times
it was pretty cool using the external power bank tho. glad I experimented w/ it
