New Campagnolo Centaur 11s vs old Chorus 10s group
Old 03-21-23, 10:35 AM
curiousabe
Quoted: 36 Post(s)
Liked 66 Times in 16 Posts
So Im having a custom frame made from Cicli Barco in columbus XCr tubing but am having a hard time deciding on a groupset. The bike vill look have a nice old racy look with quill stem and everything. Im not really up in arms on 10 vs 11 speeds per se, both works just fine. To me feel and looks are more important and Im not sure how a 20old chorus group will hold up against a brand new centaur group? I would however guess that spare parts etc will be available for longer for the centaur set.
Brand new Campagnolo Centaur 11s, silver, with a new nice looking crankset
Or
Old, probably 20 year or so but stunning, Campagnolo chorus 10s group, condition is decent enough
curiousabe is offline
Old 03-21-23, 11:04 AM
alcjphil
alcjphil's Avatar
Quoted: 1750 Post(s)
Liked 1,610 Times in 922 Posts
One advantage to a current Centaur 11 speed setup is the ability to have much wider range gearing. A 10 speed Chorus rear derailleur maxes out at 13-29 for the cassette and compact cranks are hard to find.
One of my bikes has a Chorus, Record components mix with Record brakes and shifters and Chorus for the rest. I originally had an Ultra Torque 52-39 crank(yes, they did make them for 10 speed) I wanted to go compact and couldn't find any. Eventually went with a 4 arm 11 speed crank which works just fine and looks acceptable with the rest of the black components
alcjphil is offline
Likes For alcjphil:
Old 03-21-23, 11:51 AM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 9274 Post(s)
Liked 10,417 Times in 5,302 Posts
How about an 11 speed Centaur group with an old 10 speed Chorus crank? You'd also need to source an appropriate square taper bottom bracket. AFAIK, since Campy's front shifting is a simple ratchet, there's no reason it shouldn't work. I'm currently running an 11 speed Centaur crank in a 10 speed Veloce drivetrain on my Bianchi.
genejockey is offline
Old 03-21-23, 12:47 PM
MPStoops
Liked 12 Times in 4 Posts
I'm doing this exact thing and it works great. My Scapin Columbus EL-OS steed has served me well since the early/mid 1990s when I raced on it, and I recently decided it was time to upgrade the groupset. I had been running an old but still very functional and trustworthy Chorus group (8 speed!!!) on it with the old Zonda 16 spoke aero wheels. I went with a new Centaur 11 speed group but had already replaced the crank with a Chorus 10 speed unit for other reasons, so I just kept that part to save a couple bucks. Also got the new Zonda C17 wheels so I could run an 11 speed cassette.
The shifting is fantastic, and the improvement of front derailleur shifting is amazing. But the new brakes are just phenomenal in comparison!
In short, go for the 11 speed Centaur groupset - you'll love it!
MPStoops is offline
Old 03-23-23, 05:00 PM
curiousabe
Quoted: 36 Post(s)
Thank you! Will go with centaur 11s excluding hideous crank and source a NOS or mint condition chorus 10s silver crank
Old 03-24-23, 07:10 AM
alcjphil
alcjphil's Avatar
Depending on the gearing you want, a silver Chorus crank may be difficult to find. If you need to go to compact gearing, a 50-34 chainring setup will be quite rare. Campagnolo did make them, but they were not very popular at the time, so they didn't make many. This is why I had to go to the later 4 arm cranks that the OP finds ugly. The advantage of the 4 arm cranks is that they accept all chainring combinations. The earlier 5 arm cranks have different bolt circles for standard and compact setups. I have a very nice Chorus Ultra torque 10 speed crank that I am not using anymore because the smallest inner chainring it will accept is 39 teeth
alcjphil is offline
Old 03-24-23, 07:40 AM
himespau
himespau's Avatar
Quoted: 4067 Post(s)
Liked 2,805 Times in 1,700 Posts
Just don't fall down the rabbit hole of the Campagnolo 10 speed triple. Sure the shifting is great and the range is excellent, but stay as far away from that as you can. That extra weight of the chainring and the slightly larger FD will really hold you back. Don't go near it at any costs.
Gotta drive demand down as low as possible so I can keep affording the best groupset for retromodding vintage bikes.
himespau is offline
Old 03-24-23, 09:35 AM
squirtdad
squirtdad's Avatar
Quoted: 2209 Post(s)
Liked 2,567 Times in 1,406 Posts
if it does not have to be campy couple of other options
sugino 50/34 https://www.benscycle.com/sugino-xd2...kaAq5vEALw_wcB
rene herse https://www.renehersecycles.com/shop...double-cranks/
squirtdad is offline
Old 03-24-23, 10:13 AM
curiousabe
Quoted: 36 Post(s)
Yea Ive found other compacts too but from what Im hearing the shifting is kinda sheit using a non campa crankset?
Old 03-24-23, 10:36 AM
squirtdad
squirtdad's Avatar
no personal experience but the sugino is ramped and pinned and the rene herse claims extensive for in making sure the shifting is good
my guess is they would shift well
Old 03-24-23, 10:41 AM
rosefarts
With a mighty wind
Quoted: 1033 Post(s)
Liked 803 Times in 454 Posts
Ill chime in too.
That big ol block of aluminum isn’t too sexy but unless you want to ride 53/39, you might be stuck.
Campy made carbon 5 arm compact cranks for 11 speed, I have one. I’m not aware of a silver one. Possibly Velo Orange.
rosefarts is offline
Old 03-24-23, 08:02 PM
eljayski
slow on any terrain
eljayski's Avatar
Bikes: Kirk Frameworks JK Classic; Sella Ronda by Bertoletti; Tommasini Tecno
Quoted: 60 Post(s)
Liked 164 Times in 50 Posts
I just purchased a silver Centaur grupo from Bike24 in Germany (I'm in Colorado). It doesn't have the cachet of the Athena silver but it will look good on my new Sella Ronda by Bertoletti, just the same.
eljayski is offline
Old 03-25-23, 06:29 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4639 Post(s)
Liked 1,476 Times in 960 Posts
Here's a CX silver campy option:
https://www.lafobikes.com/products/c...32820019134510
Sy Reene is offline
Old 03-25-23, 02:06 PM
alcjphil
alcjphil's Avatar
It appears that the OP is looking for compact cranks. Too bad, I have a pair of Chorus crank arms that I would gladly give away. No chainrings or bolts however. These were one of the nicest looking cranks ever made
alcjphil is offline
Old 03-26-23, 06:58 AM
curiousabe
Quoted: 36 Post(s)
They are good looking, so good looking that I scored these nos locally today
Likes For curiousabe:
Old 03-27-23, 11:40 AM
MPStoops
This is the exact set I'm running with my Centaur 11sp group. No issues at all.
MPStoops is offline
Likes For MPStoops:
Old 03-27-23, 12:19 PM
Germany_chris
I’m a little Surly
Germany_chris's Avatar
Bikes: Two Cross Checks, a Karate Monkey, and a Disc Trucker
Quoted: 697 Post(s)
Liked 1,260 Times in 637 Posts
Yea Campy 11 is new skool and ugly..I have no idea how folks run all this 11 year old campy on steel bikes
Germany_chris is offline
Old 03-27-23, 12:21 PM
Germany_chris
I’m a little Surly
Quoted: 697 Post(s)
This is some silly karma farming drivel..let's close, this isn't re**it
Old 03-27-23, 03:18 PM
georges1
Steel is real
georges1's Avatar
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 566 Post(s)
Liked 779 Times in 512 Posts
old speed 10 chorus for me for many reasons:
-nicer crank
-nicer ergopower
-nicer brakes
-nice seatpost
georges1 is offline
