Better cassette spacing for aging rider
As I approach my 67th birthday, I find that my average speed for typical rides is not what it used to be. Related to that, I also find that I use the smaller cassette sprockets less frequently. Actually I never use the 11T and 12T sprockets at all. I can't push those gears on flat roads, and if I'm on a downhill I don't feel the need to keep pedaling above 35 mph.
So this leads to my question: Why don't manufacturers produce cassettes without 11T and 12T? My ideal cassette -- matched with my 50-34 crankset on an 11-speed (Shimano) bike -- would be a 13-30T (13, 14, 15, 16, 17, 19, 21, 23, 25, 27, 30).
My internet searches tell me these cassettes don't exist, but maybe I've missed something. Your thoughts?
Likes For cwilly8:
Quoted: 8279 Post(s)
Liked 9,034 Times
I use Miche cassettes. I've bought them "off the shelf" but I think you can order them any way you want them.
LIGHT PRIMATO 11 SH (miche.it)
I turned 67 earlier this year and I still use the 12.
Combining 30/46 crank with a 12-25 cassette would get you close and Im sure a custom Miche cassette could do the trick as well. Either with a 34/50 crank or a 30/46.
Bicycle Gear Calculator
Quoted: 1819 Post(s)
Liked 1,693 Times
Such a thing does exist if you have Campagnolo compatible wheels
https://www.xxcycle.com/sprocket-11-...-13-30,,en.php
I have been riding my Gravel bike with road wheels lately, and I am really liking the sub-compact 30-46 crankset.
Likes For mgopack42:
Quoted: 6193 Post(s)
Liked 4,809 Times
DR's spec a max size for the Top Sprocket. Commonly it's 12 teeth for the DR's I've paid attention to. Maybe similar to the max size for the Low Sprocket they are conservative, and it will be no issue.
Liked 9,034 Times
I think it is a 11-32 (Shimano) here is the gear chart.
I can spin out going down hill, but if the road is steep, I just coast. I have been trying to stay in zone 2 for endurance anyways on that bike. Getting ready for a week long credit card tour...
Liked 9,034 Times
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Some bikes now come with 46-30 or 48-32 instead of 50-34. It requires a new crankset, since the usual 34 can't go smaller.
That 30 chainring is 88% of the 34. So it's like moving everything down one shift.
So you get reasonably close shifts, but in an easier range. This would be very good for a lot of riders. Better than the ultra wide cassettes, like 11-36.
14-32!
A few years ago, I made a 14-32 11 speed! It's a mix of a 14-28 "junior racing cassette" and my 11-32.
Here's the details, and the disadvantages: https://www.bikeforums.net/19934886-post38.html
More details: https://www.bikeforums.net/19717550-post6.html
I only used it to keep up in fast group rides at 18-23 mph, where it had very close shifts. That worked great! Not as practical as an 11-32 for general riding.
14-32!
the bike has GRX setup, so I could even go lower if I wanted. I used to ride Campy Chorus, with a compact, and 29 was the biggest I could go in the rear, and it was hard in the hills east of Fresno, for sure! now I can spin up the long (8 mile or more) average 6-8% grades with relative ease.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1947 Post(s)
Liked 1,468 Times
Liked 1,468 Times
Liked 1,468 Times
14-32!
14-32!
Bike Forums - View Single Post - Custom 12-28 cassette
Bikes: Nashbar CR5 Ultegra, Trek 2300
Quoted: 14 Post(s)
I had a 11 speed custom Miche 13-32 made at the Cycle Clinic UK a couple of years ago, 13-14-15-16-17-19-21-23-25-28-32. I use it for extreme gradients to keep my 69 year old knees happy. I think I could nearly climb a tree with a 50-34 and the 32.
Quoted: 283 Post(s)
Liked 262 Times
Maybe there is a 46 chainring that will fit your crank and FD
https://www.jensonusa.com/SRAM-11-Sp...inrings-110BCD
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,860 Times
https://absoluteblack.cc/oval-road-c...-for-110-4bcd/
They make 46/30 and 48/32 chainrings that fit standard shimano road cranks. I run their 46/30 on my road/gravel bike. They aren't cheap though and if you want more of a compromise a 48/31 GRX crank and new GRX fd would also work and gain you a few more MPH on the top end. Personally I don't spend very much time pedaling at over 30mph so I don't care.
Quoted: 1528 Post(s)
Liked 718 Times
mosquito rancher
It is (I think I've seen a 33t, but yeah). Absolute Black is using oval rings, which lets them get away with the smaller rings. And there's someone else out there making 30t chainrings where they do something sketchy with the bolt holes—I can't find a link, but I know they've been discussed here on Bikeforums.
Adam Rice
Adam Rice
Quoted: 1814 Post(s)
Liked 923 Times
https://www.ebay.com/itm/362960929730
The small ring is tapped and the chainring bolts are screws. Not sketchy, kind of more sensible actually. Working well on my cx bike with 11/36 since beginning of the year.
I ride primarily flat roads in Florida, although there are decent hills in Lake County. I found myself constantly wishing for one tooth jumps in the middle of the cassette. I rarely use the 11 or 12 sprocket. Recently installed a Shimano 14/28 cassette. Unbelievably efficient for my level of riding. 1 tooth jumps up to the climbing gears; 14-15-16-17-18-19-20-21-23-25-28. 11 speed cassette and I have 50/34 crank.
A shimano grx 46/30 crank is $145. There is a FD dropping adapter, if needed. Google front derailleur lowering adapter.
I use grx 48/31 and 46/30 cranks with my sram force axs 12 speed drive trains. I do use spacing washers to correct the +2.5mm chainline.
Quoted: 974 Post(s)
Liked 512 Times
My road bike low gear is 34F-32R. I'd like an even lower gear, but this is good for the hills I climb, that often reach 12-14% briefly. I think 18% is about as steep as I can do now, for maybe 120 feet high, but that would be hard.
My adventure/gravel bike has a triple, and I recently put a bigger cassette on the back. 52-39-30 and 11-34. Yeah!
The 30F-34R let me stay seated on a 12-15% grade. Nice.
I almost never shift to the 52. The 39-11 or 39-12 reaches the low 20 mph ranges.
