Solvent for degreasing/cleaning?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1944 Post(s)
Liked 1,466 Times
The degreaser itself may be biodegradeable, but the stuff it removes from your bike components is not biodegradeable.
I like OMS because it is safe and effective, and can be reused multiple times by letting the particulate matter settle out and decanting clean solvent off the top.
Old enough, hmmm?
BTW in my former life (machine tool service business) I would always carry along a 5 gallon can of Kerosene since some of my customers would use the cheaper Varsol to clean/wash parts etc.
I'm allergic to that stuff and apart from that it is harder to get a proper lube film back on parts if they are cleaned with Varsol. Not the real McCoy if any kind of bearing/transmission is involved!
Quoted: 965 Post(s)
Liked 1,629 Times
Being cheap I carefully use gasoline. When I am worried about parts that contain plastic or rubber I use automatic transmission fluid or the old WD40. Marvel Mystery Oil is also an excellent cleaner. And lets not forget Diesel and Simple Green. Gone are the old Army days of using Barsol and MEK.
NOT
NOT
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
cyccommute If my Lowes order of odorless mineral spirits does not come through, and I no longer want to pay >$20/L to an art supply store to buy more, is it more dangerous to use kerosene or naphtha? Both are available as camp fuel from my local REI, and their respective costs are almost the same (~ $8/qt). I generally do my bike maintenance in an attached garage with the garage door open
To be clear, you don’t need buckets full of mineral spirits. A cup of mineral spirits will clean a dozen or more chains. I put mine in a wide mouth Gatorade bottle (16 oz). I feed the chain in, cap it, and shake vigorously for about 30 seconds. For surface cleaning, I use a bit on a rag. As I’ve shown in this post, my drivetrain doesn’t need a lot of cleaning.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,217 Times
You probably don’t want to post this on-line. When you set your house on fire, the insurance company can find this post and then your gasoline isn’t so “cheap”.
Where do people get these ideas? Automatic transmission fluid is incompatible with styrene-butadiene rubber. It’s also an oil which, if the point it to remove oil, why use “oil”? WD-40 also contains 25% oil.
Again, oil to clean oil?
Okay. But why not mineral spirits? It’s easier for most people to get even a gallon of mineral spirits a lot easier than they can get a gallon of diesel fuel. I’d have to go to a hardware store to get a gas can (hopefully in a different color than red so as to avoid dumping it into a gasoline engine). I’d have to go to Tractor Supply since hardware stores don’t have 1 gallon version. I’d pay $15 for the can and about $4 for the diesel fuel.
Or I could go to the same Tractor Supply and buy a gallon of mineral spirits for $12.
Barsol is still available, although I suspect the stuff you look back on so fondly was a chlorinated solvent. And MEK can be be purchased from Home Depot or Lowes. This chemist wouldn’t use it as a solvent for oil based materials, however. It’s just not a good oil solvent. There are better ones out there…like mineral spirits. It’s safe, effect, and clean.
Stuart Black
Stuart Black
Quoted: 2604 Post(s)
Liked 1,928 Times
I don't see the "so what?" point. Am I missing something?
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Perhaps kerosene and diesel don't fully evaporate. Aren't those fractions going to be long chain hydrocarbons? And lubricating oils and paraffin, aren't those also long chain hydrocarbons? And won't any part of the solvent that evaporate leave behind anything that was dissolved in it?
Quoted: 2026 Post(s)
Liked 1,096 Times
My local Home Depot shows OMS at $8.28/qt and $13/gallon. It also sells K-1 Kerosine for heater use at about the same cost per gallon.
Note to cyccommute: Years ago, "white gas" was sold as a heater fuel and the name implied it was lead-free, unlike motor fuel gas at the time. It was not intended for use in automobiles.
Liked 4,217 Times
Even getting a whole gallon of mineral spirits is sort of silly. I have a couple of liter cans of mineral spirits that are a couple of decades old. They may last me another couple of decades. I use a cup (250ml) of the solvent to clean a chain one time at installation. By using a chain lubricant that is clean, I never have to clean the chain again until I replace the chain about 3500 miles later. I basically get over 40,000 miles out of that cup of mineral spirits. Since there are 4 cups in the liter, I’m looking at north of 150,000 miles of bicycle riding before I need another quart. A gallon of mineral spirits would last me 620,000 miles
I think I’m getting my money’s worth.
Stuart Black
Stuart Black
Liked 4,217 Times
In a refinery, naphtha is passed over a catalyst where it is forced to undergo chemical reactions that “reform” it into hydrocarbons that can be used in gasoline. But without that reformation, no amount of additives is going to make it suitable for running in an engine. In other words, “white gas” isn’t gasoline with or without additives.
All this confusion comes about because we humans are sloppy in our word useage. Gas, whether it is gasoline or “white gas”, isn’t…gas that is. They are both liquids. Even in use in stoves or cars, the liquid isn’t in a gaseous form, it a mist with small droplets of liquid suspended in air.
The term “gasoline” appears to be due to a bit of fraud. According to Wikipedia
"Gasoline" is an English word that denotes fuel for automobiles. The term is thought to have been influenced by the trademark "Cazeline" or "Gazeline", named after the surname of British publisher, coffee merchant, and social campaigner John Cassell. On 27 November 1862, Cassell placed an advertisement in The Times of London:
The Patent Cazeline Oil, safe, economical, and brilliant … possesses all the requisites which have so long been desired as a means of powerful artificial light.[10]
This is the earliest occurrence of the word to have been found. Cassell discovered that a shopkeeper in Dublin named Samuel Boyd was selling counterfeit cazeline and wrote to him to ask him to stop. Boyd did not reply and changed every ‘C’ into a ‘G’, thus coining the word "gazeline".[10] The Oxford English Dictionary dates its first recorded use to 1863 when it was spelled "gasolene". The term "gasoline" was first used in North America in 1864.[11]
Finally, I really do love these discussions. It makes me go out and find more information for my personal game of “how many useless…but interesting…facts can I cram into my brain”.
Stuart Black
Stuart Black
Liked 1,466 Times
Honestly the reason I want something I can get in bulk is so I can fill a decent size Tupperware tub with it, toss all the crap that needs to be degreased in, and forget about it for awhile. That's what we did at the shop.
It sounds like mineral spirits is a great option, even if it's a little more expensive than some other options. I do bike stuff for fun mostly. I guess it's an expensive enough hobby that, even if it costs me $10 in mineral spirits everytime I do a bike, that's pretty small compared to the overall costs. What's another drop in the bucket, right?
Liked 1,466 Times
Liked 4,217 Times
I’d probably not completely immerse a rear derailer in solvent. It has grease in the knuckles that would be flushed out by solvent.
Stuart Black
Stuart Black
Don't discount what you can get done with some dish detergent and water and some good scrubbing. I like dawn honestly. Totally good for getting things like cassettes clean, is what Shimano officially recommends for cleaning derailleurs, etc. For mild cleaning that needs not to leave residue isopropyl alcohol is fine.
For heavier cleaning OMS or naptha is good stuff, but I like to handle heavy solvents as little as possible especially at home, particularly given I'm a professional mechanic who handles too many chemicals as it is.
Having worked in bike shops for over 10 years now, I would honestly recommend muc-off drivetrain cleaner for cassettes & chainrings and their quick drying degreaser for chains. Easy to work with and biodegradable. Plus get yourself a "lakeland home tile & grout brush" off amazon, hands down best solid brush that will last longer than any bike specific brush.
You shouldn’t need “$10 in mineral spirits every time” you clean a bike. Mineral spirits and oil are almost like ethanol in water, i.e. infinitely soluble. There really isn’t a point where the oil will come out of the mineral spirits nor where the mineral spirits will come out of the oil. Additionally, if you need to clean parts, you don’t need any more mineral spirits than what is necessary to just cover the part. The widest part…and likely largest part…you are likely to put into mineral spirits is a crank which would need less than 3” in a relatively small tub. A 9”x11” would be big enough for a 175mm crank with a 52 tooth chainring.
I was using the $10/clean thing just to make a point. Even if I needed $10 worth I'd be fine with it so there's really need to worry about (for me anyway) finding a cheaper option.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Lots of "Fuel" mentions.. What does this stuff fuel anyway? aka Denatured alcohol, used after OMS for some chain cleaning routines. How does denatured alcohol differ from rubbing alcohol (ie. Isopropyl)?
Liked 4,217 Times
“Alcohol” is a class of compounds with the generic formula of CnH2n+1OH (where n is the number of carbon atoms in the molecule). The class of compounds can also be represented by CnH2n+2O. Rubbing alcohol is 2-propanol with a formula of C3H7OH (C3H8O). Ethanol, which everyone calls “alcohol”, has a formula of C2H5OH. Alcohols are toxic but some are worse than others.
Both ethanol and 2-propanol are infinitely soluble in water. Both are polar which makes them really poor at dissolving oil and grease. If they are used after mineral spirits in chain cleaning schemes, it’s a waste of solvent. The mineral spirits will evaporate without chasing it with either denatured alcohol or rubbing alcohol.
If, on the other hand, you use water based degreasers, the alcohol is almost a necessity to remove water.
Ethanol is a fuel for either mass burning or for engines. It’s not necessarily an energy dense one…it’s already partially oxidized…but it does burn.
Stuart Black
Stuart Black
Advocatus Diaboli
Liked 1,532 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
While 2-propanol isn't a good choice for degreasing I have always thought that the polar nature of isopropyl made it a good choice to get that last remaining film of almost invisible oily residue off of brake rotors.
When I use to very stupidly use gasoline to clean things in, the rotors on my vehicles in particular and they would always squeal. Then I saw a recommendation to use isopropyl as a final cleaning and I never had squally rotors again.
And it seems there was something about it's polar nature letting it lift or get under other contaminates. But only when there were few remaining contaminates.
Liked 1,466 Times
The OMS + Denatured Alcohol thing is part of the somewhat well known Molten Speedwax prep instructions. Googling, "do Mineral Spirits leave behind a residue" -- it seems to be split on hits that say yes vs no. Those that say 'yes' refer to an oily residue -- ostensibly it's this residue that the alcohol is used to get rid of.
https://www.youtube.com/watch?v=lI0tZqIpguk
Liked 4,217 Times
Thanks for the complete rundown. The OMS + Denatured Alcohol thing is part of the somewhat well known Molten Speedwax prep instructions. Googling, "do Mineral Spirits leave behind a residue" -- it seems to be split on hits that say yes vs no. Those that say 'yes' refer to an oily residue -- ostensibly it's this residue that the alcohol is used to get rid of.
If you are using wax, the hot liquid wax is a solvent too. Most of the hard waxes people are using for chain lubrication could benefit from a little oil/oily residue to soften it a little.
And, finally, every 97 step chain cleaning process has 96 too many steps. Even if you do all 97 steps, you aren’t going to see any gains that are more than marginal…if that. If it takes more than 20 minutes to clean a chain, you are wasting your time.
Stuart Black
Stuart Black
Quoted: 206 Post(s)
Liked 38 Times
Buying cleaning solvent by the quart is far more expensive than by the gallon. I pay about $8.50 a gallon for crown camp stove fuel - half the price of OMS. If gasoline and camp stove fuel are so dangerous, how do I manage to fill up my cars, three lawnmowers and a an emergency generator and not blow myself up. By accounts here, gas stations should be blowing up right and left. Yes, l know that gasoline related fires happen. My workshop has an electric water heater, placed 8 feet above floor level.
I reuse my solvent many times, to minimize the amount I use. Once there's enough oil in it, it won't always light if I throw a match in some, to burn it off.
It's not clear to me what the strong argument is in favor of using something that's specifically designed to be ignited easily in vapor form and burn hot and fast instead of something that's purpose-made to clean things. Just to prove you can get away with it and to save a few bucks doesn't sound like a good reason but's that's just me.
