Interesting finds around the web
#1427
Lapped 3x
An interesting couple of photos going back to 1996. The first is Brian Walton of Canada (Silver in the Points Race) aboard his unnamed bike. If anyone knows who made this, I would be very appreciative of any information. His bike sponsor at the time was Trek, as he was riding for Saturn.
The second photo is from a wheel that Paul Lew made for him prior to the 96 Olympics. It was a one-off (at the time Brian had th only track version), dubbed The Black Hole. He never rode it at the Olympics, as the UCI had banned it by then, but he did medal in the IP the previous year using it. It originally came out in a much more open version for triathletes, and this model, the more closed one, was for the track, to be much stiffer and more aerodynamic. Apparently it had the same cda as a disc.
#1428
Lapped 3x
Found the Aussie seat manufacturor when looking for the new aerobatic.
askil
The new bars are used for pretty much races only, they don't warm up on them during competition are designed for each rider and to work in tandem with the aero gloves. They're supposed to take advantage of the maximum lenghts permitted as the extensions are on held by the ring and pinky fingers leaving the rest of the hand to be shaped aerodynamically.
askil
#1430
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
#1432
Lapped 3x
So under the old rules, if you were at the morphological limit, your hands would have had to stay wholly on the bars, and fall within the 750mm/850mm rule. Now the bars just have to fall within the limits.
#1433
Lapped 3x
Here's another look
That warning sticker on the left hand side is from aviation circles. It's a pre-flight checklist warning, to make sure you cross the I's and dot the T's. The little thing you see jutting out at the top pf the opening is the pre-load/set screw for the top bearing. This is the bearing that gets removed to assemble/disassemble the wheel.
#1434
Elitist
Liked 92 Times
I found an article on that wheel and it mentioned that it came in at 1lb lighter than comparable race fork+wheel combinations at the time.
Imagine being the engineer that made that truly revolutionary device just to have the UCI ban it.
#1435
Lapped 3x
You can thank Paul Lew for it. He started his own company back in the 80s making racing wheels, as well as aerospace parts and nascar/F1 components. Reynolds licensed his design, then bought out his patents and hired him on as a designer/engineer for their wheels. Barring a bad car accident that he had a few years ago (fully recovered now I think), he's done very well for himself.
More on the man himself - https://www.bikerumor.com/2012/10/25...pert-paul-lew/
#1436
Lapped 3x
On the other side of the pond, the British had Mike Burrows. He was the man responsible for the Lotus 108 and Lotus 110.
It all started with his own TT bike design.
Check out the tiny drivetrain on the second bike.
The Lotus Sport 108
Chris Boardman about to catch reigning IP WC Jens Lehmann aboard the Lotus 108
It even came with it's own wheel/bike cover
The Lotus Sport 108
#1437
Lapped 3x
The Lotus Sport 110
Mike Burrows own more recent TT bike. Giant eventually licensed the design and put it into mass production as the MCR.
The last one with the wheel is interesting. Those are solid bladed carbon spokes. Not a very stiff wheel at all, and because the fork was so skinny, it made for a very flexible front end. You could remove the brake and get the tire to rub the inside of the fork when out of the saddle. The spokes were also prone to chipping from rocks and pebbles thrown up off the road during races.
#1438
Elitist
Liked 92 Times
Taras is on fire today!
Isn’t that 3-spoke Mavic rumored to be faster than the Io?
I wonder why they dropped it from the lineup.
#1439
Lapped 3x
The 3G I think was phased out when they came up with the Io, basically because it wasn't sexy anymore. The DuPont Specialized Trispoke wheel had just come out and was proven faster than the 3G. The Trispoke was bought up in droves by competitive cyclists. Mavic needed something new, and because the Tripsoke wasn't that great of a sprint wheel, being so mushy, they decided to make a beefier wheel and focus on the sprint game. Corima already had a 4 spoke wheel that was well regarded and stiffer than the Trispoke, so 5 must be better right? Incidentally at this same time, Corima came out with their 3 spoke wheel to make a faster wheel to compete with the Trispoke.
Now it seems like the Corimas were best all along with the rumblings going around the pits at the big races.
#1440
Elitist
Liked 92 Times
This is so easy for Mavic to settle by publishing wind tunnel data. I find it curious that they do not. I also find it curious that they don’t offer a 5 spoke for the meticulous road TT crowd.
Personally, I’m convinced that the 808 is faster.
#1441
Lapped 3x
There's two problems with publishing wind tunnel data. The data will vary for the same item from tunnel to tunnel because the testing apparatuses are different. The second is competitive. Even if you are the leader, publishing your data may be harmful if you're not far ahead. It was mentioned previously that the Zipp combo is drastically cheaper than a Comete/Io, and if it is slower it may be so close that it doesn't matter. If people see no real cost:benefit, then who's going to pay for all the wheels that get given to National federations?
#1442
Elitist
Liked 92 Times
Agreed.
I don’t think they even *claim* to be the fastest.
They only write, “Totally reinvented for the 2016 Rio Olympics, the iO is faster than ever.”
#1443
From the first golfball solution from 2007 (?), trough the strange bulb design from 2010 with very narrow tubular glue berth, to the large firecrest up to the strange "new" design...
#1444
Elitist
Liked 92 Times
All of the 808 Track models. I’m not certain of the year. I bought my set used in 2009 I think. So maybe they were the 2007 model. I think the current Zipp 808 Track is probably as fast or faster than the Mavic Rio IO. Both have wide rim beds now.
#1445
Quoted: 70 Post(s)
Liked 5 Times
All versions of the 808 are fast. The original fully toroidal rim from 2006-2010 is the one that was tested against the IO years ago and found to be essentially equal. The wider 808 Firecrest is faster with wider tires (22-23 is ideal) and has better performance in crosswinds. Zipp themselves discontinued the 900 front track disc because they said an 808 firecrest front wheels is faster.
#1446
Elitist
Liked 92 Times
Do you have a link to a source on that info?
#1447
~2009 or 2010 stickers became white and the bulb changed avoiding the flat brake surface, it's more bulge and round but the glue berth became very narrow, and deformation on tires should makes it slower, not from the aero point but from the energy consumption on rolling resistance. Worst with high g on turns.
So, the large tire berth of Firecrests, allowing wider tires remain supported even under high banked turns, should be the best.
I have a set of those 2010 "real bulb" white stickers 808 - track spoke counting and track hub on the front - and even with the 15mm wide tubular bed (yes 15mm) they "feel" fast all the time, and some non-scientific numbers I have for the second lap on 500m TT training sections showed it as good as a ShimanoPro 5 spokes I use to consider a "race wheel"...
As the data I'm talking about for those second laps is speed/power (Powertap), I´m one more with the idea of 808s being competitive from the aerodynamic point of view.
#1449
Elitist
Liked 92 Times
Zipp says it on their disc timeline page at the bottom: Zipp - Speed Weaponry | Support | Identify Zipp Products | Zipp Discs Through Time
In early August 2014, the long-serving 900 tubular track front disc was discontinued after over 20 years in production. The 808 Firecrest front wheel with a track legal skewer is now faster and lighter and suggested as an ideal substitute.
#1450
Quoted: 1851 Post(s)
Liked 678 Times
New SRM mount options. A lot cheaper than past options too: https://www.shapeways.com/shops/amag...SRM+Mounts&s=0
They have other computer mount options as well.
