What did you just buy for your gravel bike?
Old 08-24-21, 08:30 AM
  #876
franswa
franswa's Avatar
Quoted: 324 Post(s)
Liked 251 Times in 105 Posts
Originally Posted by beaumontjl
Sonder Camino AL frame, & DT Swiss G540 wheelset.
There are no gravel bikes for sale within hours of me, so I'm building one instead.
Nice! I almost pulled the trigger on one of those frames several times. Update us with build pics!
franswa is offline
Old 08-24-21, 11:42 AM
  #877
Germany_chris
I’m a little Surly
Germany_chris's Avatar
Quoted: 699 Post(s)
Liked 1,294 Times in 647 Posts
I got some 52cm Salsa Cowchppers today
Germany_chris is offline
Likes For Germany_chris:
Old 08-24-21, 12:28 PM
  #878
jonathanf2
Quoted: 446 Post(s)
Liked 1,044 Times in 442 Posts
I wanted GK SS tires and it was cheaper to buy pink!
jonathanf2 is offline
Likes For jonathanf2:
Old 08-24-21, 12:44 PM
  #879
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10955 Post(s)
Liked 7,484 Times in 4,186 Posts
Interesting- your SS tire tread looks a lot different from my SS tire tread in the regular black. I run 43s, but still- those look quite different.
The pink is cool since its otherwise an all black bike.
mstateglfr is offline
Old 08-24-21, 08:40 PM
  #880
beaumontjl
Bikes: Yokota 21 speed hybrid
Quoted: 5 Post(s)
Liked 4 Times in 3 Posts
Thanks! It was a pre-order, so I won't get the frame until at least late Sept. Once it gets here I'll get the rest of the parts ordered and start a build thread.
beaumontjl is offline
Old 08-29-21, 06:56 PM
  #881
jeremybart
Quoted: 7 Post(s)
Liked 8 Times in 3 Posts
Pink!
Anyone else have or see these? Would love to see it on my frame ( light green Raleigh Tamland &#128517
jeremybart is offline
Likes For jeremybart:
Old 08-30-21, 09:25 AM
  #882
jonathanf2
Quoted: 446 Post(s)
After a week or so of riding, the pink color actually gets a bit muted, but so far I really like how they look! I can see myself getting more pink tires in the future!
Old 09-01-21, 01:01 AM
  #883
Prodigy4299
Prodigy4299's Avatar
Bikes: 1990 Trek 850, 2005 Cannondale R1000, 2019 Cannondale Topstone 105
Quoted: 26 Post(s)
Liked 35 Times in 21 Posts
I swapped out my FSA crankset that came on my bike and replaced it with the GRX 600 10 speed crankset and Shimano Tiagra RS-500 BB. The tolerances are much tighter, but the crank shifts smoother and the chain line is more straight. A lot of people here said a new crank and BB wouldn't make much of a difference...I'm glad I didn't listen! I also cut almost 200g of weight switching out the square tapered BB. Seems like a win/win upgrade for me!
As someone who is about to do just about the same upgrade, I am very happy to hear this. The combination of FSA crank and 105 FD on my Topstone has meant chain rub in the highest gears and i finally managed to get myself a 2x11 GRX 600 crank!
Prodigy4299 is offline
Likes For Prodigy4299:
Old 09-01-21, 09:21 AM
  #884
mstateglfr
Sunshine
mstateglfr's Avatar
off brand Garmin Varia seatpost mount
brooks c17 all weather, since a lot of the top on one of my original c17 saddles is finally worn away.
400x27.2 Whisky no7 offset carbon seatpost since the current 350mm Easton seatpost is basically right at the min insert line and there is a slight clicking every now and then from somewhere in the saddle/seatpost area. This will give more surface area inside the seat tube and maybe itll feel different from the aluminum seatpost its replacing.
Likes For mstateglfr:
Old 09-01-21, 09:58 AM
  #885
jonathanf2
Quoted: 446 Post(s)
I know the bike manufacturers are trying to hit a price point, but the difference going with the complete groupset was a significant upgrade. Mainly because I can now put the power to the pedals much more efficiently. Tracking my stats for the past few weeks, my average/top speeds have increased and my cadence has also improved. Plus I went with shorter crank arms which eliminated toe overlap allowing me dive into corners at full speed and I'm able to spin at a higher cadence which has helped on group rides. To me, it was the equivalent of installing a race clutch on a rally (gravel) car (bike)!
Old 09-01-21, 07:58 PM
  #886
Cyclist0108
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
Silca frame pump:
in situ
Compared to my 1987 Bianchi Silca pump, and current mini pump and CO[sub]2[/sub]:
Cyclist0108 is offline
Old 09-02-21, 01:47 AM
  #887
Prodigy4299
Quoted: 26 Post(s)
In Cannondale's defence, back in 2019 GRX wasn't around, and Shimano 105 does not come in 46/30T, so it was very slim pickings. The 46/30 is actually why I chose the Topstone over the Grail, which had a compact 105 (50/34T).
But yeah, looking forward to the difference.
Old 09-02-21, 10:32 AM
  #888
jonathanf2
Quoted: 446 Post(s)
That's funny, I'm in the process of building a second (road emphasis) gravel bike using a Shimano R7000 105 50/34 crankset, 105 5800 shifters, TRP spyre brakes and using a Shimano GRX 400 rd. My thinking is that I'd have the high gears for the flats, but still have low gear access with a bigger rear cassette and GRX clutch.
One of the guys I ride with has a gravel bike with a front 48t chainring and 11-42t, but is insanely fast and strong. He was telling me he wants to swap out to a 50t, because the uphill trails were too easy with his current gearing!
Old 09-02-21, 11:15 AM
  #889
mstateglfr
Sunshine
mstateglfr's Avatar
So he has a 1x system thats 48 up front and 11-42 in back? If he doesnt need all the gearing to get up hills, then if he just gets a smaller cassette he will have smaller jumps and still have all the range he needs. A smaller cassette will save weight and likely be cheaper too.
...unless he is saying he needs harder gearing too, which then the 50 up front makes sense.
Old 09-02-21, 11:44 AM
  #890
jonathanf2
Quoted: 446 Post(s)
This guy has no car, rides his gravel bike everywhere, always has a hydration pack and is in great shape. He wants 50t up front to go faster and doing trails on the 48t with his gear range is no problem for him. At first I was wondering why he was so fast on a 1x, but then I looked at his chainring and realized it was setup for high gearing. He reminds me of a cycling superhero every time he shows up for the group rides fully kitted!
Old 09-02-21, 01:13 PM
  #891
LeFreakyBone
Bikes: BMX – FBM Gypsy; Gravel/Adventure – Rodeo Labs Flaanimal 4.1; Mountain – Santa Cruz Bronson CC X01
Quoted: 17 Post(s)
Liked 18 Times in 6 Posts
Ordered the parts needed for a SRAM Eagle AXS 1x mullet conversion. The X01 derailleur came in, but with the shortage it looks like I’ll be waiting till the end of December for everything else to arrive.
LeFreakyBone is offline
Old 09-03-21, 10:39 AM
  #892
Branko D
Quoted: 338 Post(s)
Liked 408 Times in 252 Posts
A Microshift 10 speed clutch derailleur. XLE something, probably previous generation since now XLE clutched is 11 speed only.
Solid piece of budget kit, some 30ish Euros. The old non clutch Deore led to chain slap on rough terrain, this looks way more solid and shifting is more precise, the old mech got a bit sloppy.
Branko D is offline
Old 09-07-21, 03:02 AM
  #893
Lazyass
Quoted: 2432 Post(s)
Liked 638 Times in 395 Posts
My '07 Raleigh RX 1.0 is actually my favorite road bike. It still has the original Tiagra/105 9sp group. I just ordered a Rival 22 mini group and the Bicycle Wheel Warehouse Pure Race wheelset for it. I already have a nice set of Raceface Cadence cranks with 46/36. I believe I'll get some 35mm Gravelking slicks for it, still trying to decide that. Never had a SRAM group before but always wanted it. It'll be a nice little budget build.
Lazyass is offline
Old 09-13-21, 08:26 PM
  #894
DarKris
DarKris's Avatar
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times in 54 Posts
I bought a second gravel wheelset for my drop bar MTB that finally arrived after a few months of being built. Aaaaand then I bought Curve Walmer bars in 60cm so my bike is now MASSIVE!
DarKris is offline
Likes For DarKris:
Old 10-10-21, 04:32 PM
  #895
franswa
franswa's Avatar
Quoted: 324 Post(s)
Can’t believe this thread was on page 2
Treats
franswa is offline
Old 10-11-21, 01:25 AM
  #896
Lazyass
Rival 22 shifters/derailleurs and Blackset Race 24 wheelset now installed. The SRAM levers must have a higher brake cable pull ratio. The canti's feel like the power was doubled, they're more grabby than my 105 hydraulic discs. These are the best brakes I ever had. The rims are 3mm wider and maybe that has something to do with it. I almost switched to mini-v's but I'm glad I didn't.
Lazyass is offline
Old 10-11-21, 08:07 PM
  #897
chaadster
Thread Killer
Quoted: 3134 Post(s)
Liked 1,702 Times in 1,027 Posts
Ultradynamico Rosé JFF
Against my better judgement, I just purchased a pair of Ultradynamico Rosé JFF tires, tanwall.
I say it was against my better judgement because I’m using these for winter tires here in Michigan, so besides the price being rather stupidly high for my amateur needs, I reckon the winter slop is going to make the sidewalls, especially the DS rear, look crappy in short order.
Oh well. These are going on my first dedicated gravel bike, so gone are the restrictions and compromises of my old dual purpose rig, so I’m bound to make some mistakes while finding what works best for me now. The main reason I went with Rosés was the tread pattern, which seems to be well suited to my conditions; I’ll see plenty of hardpack during the season, which turns into a shallow layer of medium viscosity, sandy mud when wet. When it snows, the dirt roads get packed hard pretty quickly and I have used file treads fairly successfully on it in the past, but snow is always a mixed bag, depending on so many variables, so I figured that between the record-setting (for my use history) width of 42mm and the shoulder knobs, I should at least add stability beyond what I’ve ever had, and that’s a good thing.
I just had an appendectomy today, so it’ll be awhile before I can log miles and say anything meaningful about their performance, but I’ll try to post a review at some point.
https://ultradynamico.com/products/rose-jff
chaadster is offline
Old 10-14-21, 01:59 PM
  #898
NumbersGuy
Bikes: Fairlight Strael 3.0 Ultegra Di2, Lauf Seigla Rigid SRAM Red XPLR
Quoted: 107 Post(s)
Liked 115 Times in 64 Posts
Installed bolt-on top tube and frame bags on my Niner.
NumbersGuy is offline
Likes For NumbersGuy:
Old 10-14-21, 02:36 PM
  #899
rosefarts
With a mighty wind
Quoted: 1086 Post(s)
Liked 860 Times in 489 Posts
I got an Archer D1x Trail system.
I had to get TRP Hylex RS brakes to make it work. They are a huge improvement over the SRAM.
I think I’ll end up with a shorter stem to make the longer hoods fit.
It shifts great. Not necessarily any faster than well tuned mechanical but with no effort. $700, 300 for the brakes and 400 for the system. Pretty pleased on first impressions.
rosefarts is online now
Likes For rosefarts:
Old 10-14-21, 03:08 PM
  #900
chaadster
Thread Killer
That’s a very interesting system! The flexibility it offers is amazing.
