O.M.A.S. bottom bracket? On a what?
PeopleCode delaminator
So I dragged home an Allitalia bike a few months ago:
It has an interesting bike boom era mix of parts. Suntour Cyclone derailleurs, Sugino Super Mighty cranks, KKT pedals, Weinmann brakes, Jim Blackburn rear rack.
The hubs and rims are so dirty I have no idea what they are, Front rim is steel and rear is alloy.
It's surprisingly light.
I want to use the cranks on another build so I pulled them. Since the bottom bracket was in much better shape than other parts I have, I pulled that too.
And scratched my head a good while.
The cup says "O.M.A.S Italy" and "36 x 24F"
Neither side is a fixed cup, they both have lock rings.
Sealed bearings that are still smooth:
The spindle is a very high quality piece of machining.
Why on earth would a bottom bracket this nice be in a brand of bike I've never heard of?
EDIT: If any of the hive mind here know anything about Allitalia bikes, I'd appreciate it if you shared your knowledge.
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
...using adjustable cups with lock rings on bikes with RH threading on both sides was a commonly used trick to create a BB with an adjustment for chain line.
This is doubtless what someone has done on yours. It works well, so unless you are swapping the entire unit out for something else, I would just use it as is.
OMAS is not seen all that often, but it was commonly available back then. It's relatively high quality stuff....probably on a par or better with Campagnolo in terms of durability.
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
...I know nothing about your bike frame itself. There were a lot of contract built Italian frames sold here under various names. Check the frame tubing for butting. Either the steel rim is a replacement and a downgrade, or the alloy one is a replacement and an upgrade. Or they are both replacements, for an original high quality set of tubular wheels.
...unless you are swapping the entire unit out for something else, I would just use it as is.
There are clamp on Campy shift levers.
I'm thinking someone in a bike shop in the 70s had a few too many beers and leftover parts.
Friendship is Magic
Bikes: old ones
Liked 10,374 Times
...that spindle is probably sized for Italian BB shell width anyway, so using it in a 68mm shell is problematic anyway.
lurking nightrider
Oh, and while you're at it get a magnet and see if it is attracted to the spindle. Titanium?
"If there hadn't been women we'd still be squatting in a cave eating raw meat, because we made civilization in order to impress our girl friends. And they tolerated it and let us go ahead and play with our toys." Orson Welles
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Likes For JohnDThompson:
Quoted: 3810 Post(s)
Liked 3,335 Times
[catalogue page of 1978]
frame -
are either of the bridges plate style?
lug pattern: Agrati "AMERICA"
upper head lug: Agrati N. 007.8505
lower head lug: Agrati N. 086.8053
seat lug: Agrati N. 086.8569
fork crown: Agrati "AM" N. 005.8048
dropouts: Agrati N. 000.8002
fork ends: Agrati N. 000.8010
bottom bracket shell: difficult to see clearly; looks like it may be Agrati "AM" pattern
remaining original fittings -
Balilla brake levers
3TTT Tourist stem & bar set
Agrati headset
front wheel: Gnutti hub with NISI rim
seat binder
original gear ensemble would have been Campag Valentino
original brakes would have been Balilla centrepull
original chainset would have been cottered steel by either Agrati or OMG
original pedals would have been Sheffield all steel
original saddle pillar plain steel
possible that identity of manufacturer could be advanced with information on placement and format of serial marking, if present
one possible maker might be Chiorda - mentioned only as a possible
frame -
Agrati headset
seat binder
