Best brushes or tools to knock surface rust off steel frame
Just picked up a 90's Specialized Rock Hopper, but it's got quite a few areas of scratches under the paint and primer leading to rust.
Is there a certain bristle material to use by hand or in a drill to knock off the rust while preferable keeping the paint mostly in intact? I'll plan to use clear coat rattle can (or nail polish) on the bare metal after the rust is off.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
IME you’ll have to strip any rusted areas to clean bare metal, at least locally. I’ve had success with a wire wheel, though careful use of sandpaper works as well. Obviously a gentle touch is appropriate, along with proper PPE if using a wire wheel or other powered rotary tool.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
Try balled up aluminum foil.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Likes For stevel610:
Quoted: 836 Post(s)
Liked 1,061 Times
These work great for small chips and scratches. ProMotorCar PrepPen Adjustable Sanding Pen 3437 | O'Reilly Auto Parts (oreillyauto.com) Can be found in various sized tips for very narrow to wider paint area removal. Just a cluster of very fine glass strands that give you very good control and rapid removal of paint/rust leaving a surface ready for paint or primer. If you have a small chip you can just twist the pen leaving a very small round prepped surface as opposed to sandpaper which creates a larger area. Make sure to wear rubber gloves and cover the floor as the glass strands break off during use and easily get in your skin and near impossible to find and remove. Auto parts places and Ebay, etc. have them for sale.
Likes For Crankycrank:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I would suggest that anything that doesn't remove some local paint, to get down to the bare metal in the scratch, will not be effective long-term - you'll get rust coming up through the painted scratch. For this reason, I'd use sandpaper, maybe one of those tools that use a small thin loop of paper on a spring-loaded stylus. Like these.
Then prime and sand, then paint and sand, then clear-coat and sand and polish.
Quoted: 77 Post(s)
Liked 88 Times
If you're not going to re-paint the bike I suggest washing the bike with soft cotton cloths to preserve as much of the paint as possible. If you still wish to remove more of the rust try either the White and or Grey scotch brite pads as these are slightly abrasive and used to polish paint. Try the scotch brite pads under the bottom bracket to see if they remove too much paint. Best wishes.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Likes For dedhed:
Quoted: 114 Post(s)
Liked 119 Times
My first idea is to use a fine, wet sandpaper, and favoring light strokes with many passes. With sandpaper, you can feather and blend the surrounding paint so there is a smooth transition from the original paint to the sanded area. Smooth transitions help with paint adhesion.
A potential problem with a wire brush is it is likely to damage the surrounding paint with visible scratches from the wire.
Likes For MudPie:
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
Likes For 3alarmer:
Picked up a bottle of evapo rust to try first after cleaning the frame.
If that doesn’t work, then I’ll try foil maybe with vinegar.
if that doesn’t work, I’ll try wet sandpapering.
if that doesn’t work, I’ll try a hand brass brush.
if that doesn’t work, I’ll try a rotary brass brush.
if that doesn’t work, I’ll try a rotary stainless brush.
fingers crossed
saw a guy on YouTube try automotive solutions like clay bar and rubbing compound on random orbital buffer to good effect, but wasn’t sure which step/product actually got the rust off.
fingers crossed
Quoted: 339 Post(s)
Liked 632 Times
I find that there are 2 kinds of rust on a bike, minor and major. Minor includes the light rust you might find in scratches in the paint . Major rust is where an area has a thick crust of rust that has been building up for some time.
For the this crusty rust the best thing I have found is to scrape the area with a disposable knife, the kind that you snap off the end of the sliding blade to renew the sharp point and edge. Using a steel brush will just not penetrate the crust. The knife can be used fairly surgically just on the crusty area.
After the crusty areas are scraped down to bare metal , coat the entire frame with naval jelly , let work for 1/2 an hour then rinse off. Persistent areas can be treated again with naval jelly and you can scrub the jelly into the rust with a stiff tooth brush or similar brush with stiff nylon bristles .
Before you coat the painted frame with jelly first try it out on an inconspicuous place to be sure it doesn't react to the paint.
I have done this on an old Raleigh sport with lots of rusty scratches and the improvement was considerable.
The areas that you scraped and treated with naval jelly should be immediately primed with an etching rust preventative primer as soon as it has been cleaned and dried.
After treating the frame rinse with water then wash with Dawn dish soap and water, rinse, then wipe down with alcohol to remove any remaining surface contaminants being careful not to wipe any decals or stickers . Alcohol or acetone can wipe the ink off them.
Likes For capnjonny:
