Marin san rafael suspension upgrades
Marin ridee
Bikes: Marin san rafael ds2
Hey guys. I have a Marin san rafael ds2 and I'm looking to upgrade the front forks from the stock 63mm travel to something in the 120mm range does anyone have a recommendation?
I should clarify I'm not doing any hardcore mtn biking. I weigh 230 and when I'm doing any uphill climbing I alone am maxing out the suspension
Clark W. Griswold
Quoted: 4328 Post(s)
Liked 3,949 Times
That bike is not a mountain bike and is more of a lower end hybrid that is fine to ride but not worth putting a lot of money into and especially one that will change the geometry of the bike and is also not designed for the bike. The bike is probably OK for light duty off road stuff but not for mountain biking and putting a mountain bike fork on it would not be a good idea. Also you probably don't have much clearance for proper MTB tires on the bike.
If you are stuck on Marin here are some actual entry level mountain bikes with air shocks:
https://www.marinbikes.com/bikes/2023-team-marin-1
https://www.marinbikes.com/bikes/2023-team-marin-2
https://www.marinbikes.com/bikes/2022-san-quentin-2
https://www.marinbikes.com/bikes/2022-pine-mountain-1
https://www.marinbikes.com/bikes/2022-pine-mountain-2
And some entry level full suspension stuff:
https://www.marinbikes.com/bikes/2022-rift-zone-29-1
https://www.marinbikes.com/bikes/2022-rift-zone-29-2
Otherwise there are tons of awesome bikes for mountain biking and generally you are looking to spend $1200 and up for something decent with air shocks that is a capable mountain bike. There are certainly a load of bike listed as mountain bikes but in many cases the parts are not super reliable and generally you miss out on air forks and such.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Likes For Kapusta:
If you simply feel you HAVE to update something on your bike -- then please do something about the rather unfortunate looking stock crankset (appearance only - im sure it works fine )
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
gently, now
Genesis 49:16-17
Genesis 49:16-17
