Been Any Advancements In Aluminum Frames Lately?
Quoted: 965 Post(s)
Liked 1,629 Times
Of course Carbon is the true wiener for light weight bicycles these days. And thank goodness Carbon prices, although inflated, are becoming reasonable for regular cyclists when selective. I am just wondering if there have been new innovations in Aluminum Frames lately.
I have to admit, at my age and weight, if I were going to go light weight I would most likely select a Carbon Touring bicycle...
Quoted: 882 Post(s)
Liked 821 Times
To me, aluminum reached its peak when Scandium was being used 15 or so years ago, but that alloy seems to have become a relic. My Niner frame weighed 2.75 pounds AIR, and rides as well today as when it was purchased.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Aluminum mostly fell out of favor because it moved from being a novelty to being seen as a cheap bike's material.
Good aluminum frames are labor intensive and expensive.
Carbon fiber got cheap, and labor got streamlined.
Craftspeople who wanted to make high-end metallic frames moved to either titanium or lugged steel, because the people who wanted to buy high-end metallic frames would pay more for them.
Scandium made some inroads because it was good stuff that held up better to industrial quick welding and didn't need heat treating, not because it had a lot of fans.
But if you're an aluminum fan and want something unique and a little old-school:
https://www.frankthewelder.com/andaris/
Frank The Welder FTW
Likes For DiabloScott:
Quoted: 1943 Post(s)
Liked 2,164 Times
If recently means from the oversized tube era, then yes.
Modern(er) aluminum frames are better designed and hydroforming allows for different shapes to maximize the design for a better ride. It is not going to supplant carbon fiber as the top spot, but a well designed and manufactured aluminum frame is definitely better than the ones I ride.
John
John
Likes For dsbrantjr:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Salsa is doing some stuff with aluminum that they call Class 5 Vibration Reduction System (VRS); it might just be a different way to configure the bends on the stays, but they claim there's a comfort advantage. I haven't seen or ridden it, personally.
Quoted: 1561 Post(s)
Liked 1,734 Times
I agree that hydro-forming was/is the big quantum leap forward for aluminum frames. For a while I was commuting on a Giant Avail with hydroformed aluminum frame, and the ride was not bad at all. Another time I bought an older Performance brand aluminum bike to harvest the groupset off of. It was made up of 70XX series tubes welded together. The ride was just horrendously stiff and buzzy. I quit after going 10 miles and couldn't wait to tear up that bike. When I started riding during the Covid shutdowns, I started on a hand-me-down aluminum town bike, also built from aluminum tubes welded together. The ride was really stiff and unpleasant as well. So from my own limited experience, I think hydro-forming is the big advance. Too bad nobody has done the same with steel,
Likes For icemilkcoffee:
Quoted: 3238 Post(s)
Liked 2,084 Times
I've a Specialized Chisel aluminum hard tail that is a joy to ride. Its a shaped tubing bike, had reviews of being a tad flexy but I dont notice and I'm a clyde. So you can design ride quality into aluminum and Speicalized did it with this bike. It also weighs 26.6 lbs with the SPd pedals, so is not heavy for a modern mt, bike, many are over 30 lbs, which I dont get.
Quoted: 569 Post(s)
Liked 581 Times
At one time I had a Cannondale CAAD 4 and can remember a '90s Raleigh R500 that might have shook a filling loose and just recently if I had not know what the frame was on the new CAAD I got to try I would have swore it was some new exotic material, unreal difference.
Quoted: 31 Post(s)
Liked 13 Times
I notice that Trek added a higher-end model to their aluminum Domane lineup It's basically an Al frame with a 105 disc setup, and it's ~$1200 cheaper than the same model with a carbon frame
So someone must be buying Al frames with decent components.
Quoted: 696 Post(s)
Liked 910 Times
No.
mosquito rancher
Cannondale also hasn't given up on aluminum—you've got to dance with them what brung you. And my reasonably new distance bike (from Kinesis UK) is made of scandium, so that's still around. I agree that hydroforming has been the big new thing in aluminum, which allows Specialized to form the whole head tube and adjacent "lugs" as a single piece, for example.
But I've got to say, if you're looking at buying a touring bike, weight probably shouldn't be a high priority, unless you're doing ultralight credit-card touring.
Adam Rice
Adam Rice
Quoted: 1397 Post(s)
Liked 1,876 Times
old (old) school aluminum is king !
Quoted: 514 Post(s)
Liked 448 Times
Cannondale's CAAD 10 or anything later, the current generatlion Specialized Allez, and Trek's ALR frames are the lightest aluminum frames I'm aware of. They're popular with amateur racers and sport riders on a budget, and they ride better and are lighter than lower-grade carbon. If I ever break my 10 year-old Madone 5, I wouldn't hesitate to replace it with one of these. Of course, except for Trek's Domane, these are race geometries with no bosses for hanging racks and fenders.
