Front brake making loud noise
Old 09-10-22, 06:36 AM
curiousabe
Quoted: 12 Post(s)
Liked 23 Times in 7 Posts
In the process of swapping a 105 group set for a dura ace 7700. Almost finished when I noticed the front STI makes a loud clicking noise when fully pressed. On further inspection it seems the the white plastic end cap on the cable hook unit (part nr 18 marked in red) is quite worn introducing some play and making the hole cable hook unit move when breaking.
On even further inspection it also seems that the same side of the actual mount/adapter (marked in green, part nr 15) is also quite worn on the right hand side where the worn cable house unit was fitted
  1. Does anyone know where I can buy a new cable hook unit? Tried one from the 105 groupset from the same era but that did not fit.
    According to this ad https://www.ebay.com/itm/27491179818...mis&media=COPY it is the same part for:
    1. Dura-Ace ST-7801 ST-7803 ST-7700 ST-7700-C
      Ultegra ST-6600 ST-6603 ST-6510
      105 ST-5600 ST-5600-S ST-5601 ST-5603
      Tiagra ST-4600 ST-4603
      Sora ST-3500 ST-3503
      Claris ST-2400 ST-2403
  2. Do you think a new cable hook unit will be enough or is the actual mount/adapter (part nr 15) too worn? From the video I took (14 seconds in https://photos.app.goo.gl/bpGcfb8EobovAtgD6) it looks like the white plastic end cap of the cable hook unit is sliding up towards the worn part of the metal mount/adatper and it is the actual adapter causing the wear on the plastic end cap.
    adapter
curiousabe is offline
Old 09-10-22, 07:09 AM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1169 Post(s)
Liked 780 Times in 528 Posts
eBay. Twenty + year old part. A bike shop might have one in their back room, but that will take far too much time to locate.
No prediction on whether this will solve your problem. But plastic wears a lot faster than metal. Very dirty in there.
I've had other problems with the 7700 series STI levers. Over time, I replaced all of them with micro shift levers.
wrk101 is offline
Old 09-10-22, 09:31 AM
curiousabe
Quoted: 12 Post(s)
No prediction on whether this will solve. your problem. But plastic wears a lot faster than metal. Very dirty in there.
Yea found one on ebay but with shipping its like 35 eur lol..Am gonna move over the cable hook from the right lever to see if that works first though and maybe try and clean them in the meantime.
Old 09-10-22, 09:44 AM
smd4
Quoted: 1217 Post(s)
Liked 885 Times in 583 Posts
Youíre participating in this sport, with Dura Ace, and you think 35 euros is a lot? Lol, indeed!
smd4 is offline
Likes For smd4:
Old 09-10-22, 09:55 AM
curiousabe
Quoted: 12 Post(s)
For a small piece of metal barrel with 2 plastic end caps, yes
Likes For curiousabe:
Old 09-10-22, 10:26 AM
Bad Lag
Quoted: 786 Post(s)
Liked 385 Times in 238 Posts
I wish you the best of luck fixing this. The thing you are dealing with does not seem very C&V, despite its 20 year age.
Perhaps, the solution to your problem is to revert back to a truly C&V solution - brake levers that are just brake levers and shifters on the down tube that are just shifters. It's just a thought.
After playing around with newer tech, I reverted back to my bike's original configuration and couldn't be happier with it.
Sometimes, many times, simpler is better.
Bad Lag is offline
Likes For Bad Lag:
Old 09-10-22, 10:42 AM
embankmentlb
embankmentlb's Avatar
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 114 Post(s)
Liked 212 Times in 100 Posts
I have a 7700 equipped bike from new. It may have 50 thousand miles or even more at this point. I also have a 4400 Tiagra bike from that same era. The dura ace does everything marginally better for certain. My experience is DA is just that much more finicky with age.
I had to replace a sticky freehub, those cable hooks, rear shifter, the BB more than once.
The Tiagra probably has similar mileage and nothing replaced but the BB.
Dura Ace is worth the extra trouble.
I would also check that there is no play in the cable housing as in connects to the STI levers.
It is easy to create a gap when re-wrapping the bars.
embankmentlb is online now
Old 09-10-22, 10:51 AM
smd4
I could have gone STI when I built my bike with 7700 20 years ago. So glad I didnít. Just looking at that exploded view diagram makes me nauseous.
smd4 is offline
Likes For smd4:
Old 09-16-22, 11:59 AM
curiousabe
Quoted: 12 Post(s)
Found a new in package left lever for 70 eur, this should do the trick
PS, my other bike already has downtube shifters
Old 09-16-22, 02:18 PM
smd4
Niiiice...
smd4 is offline
Old 09-26-22, 03:50 PM
curiousabe
Quoted: 12 Post(s)
Aaaand done (=
Old 09-26-22, 04:51 PM
smd4
Gorgeous bike!
smd4 is offline
