Help changing my first flat
Old 09-24-22, 03:45 PM
Porknz
Quoted: 26 Post(s)
Liked 5 Times in 3 Posts
I am having trouble getting the last of the tire bead back onto the rim. I'm changing my first tire as I transition between summer outdoor riding and winter indoor riding. Thanks for any tricks. I'm finding that as I use the lever on one side, it just lifts the bead on the other side off, so I'm basically moving all around the tire and just moving the part that isn't over the room around the tire as I go.
Porknz is offline
Old 09-24-22, 03:51 PM
Inusuit
Bikes: 1987 Diamondback Ascent, 1995 Specialized Rockhopper,1989 Specialized Rock Combo, 2013 Specialized Tarmac Elite
Quoted: 135 Post(s)
Liked 382 Times in 187 Posts
Since this is your first time, is the tire you are trying to mount the correct size and type for your rim (shot)?
Inusuit is offline
Likes For Inusuit:
mdarnton
Bikes: nothing to brag about
Quoted: 110 Post(s)
Liked 186 Times in 108 Posts
The last bit is easier if you press the opposite end of the bead you're working on--the other side of the whole wheel from where you're working--to the center and let it drop into the groove track in the middle of the rim--that will give more slack on the side you're working on.
Re your specific issue, use two irons, one on each side of the problem. One will hold the tire tire on the rim where it belongs while you use the other to get the other end over the hump.
mdarnton is offline
Likes For mdarnton:
Old 09-24-22, 04:10 PM
Paul Barnard
For The Fun of It
Paul Barnard's Avatar
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 1888 Post(s)
Liked 1,322 Times in 667 Posts
The side opposite of what you are working on needs to be off the inside edge of the rim and down in the groove of the rim. You Tube videos will likely be better than us trying to describe the procedure.
Paul Barnard is online now
Likes For Paul Barnard:
Old 09-24-22, 04:23 PM
Porknz
Quoted: 26 Post(s)
Yes. Actually the rear tire wore off the tread, but the front tire looks basically new still. Moving the front tire to the rear tire and putting a new one on the front tire.
Porknz is offline
Likes For Porknz:
Old 09-24-22, 05:54 PM
BillRS22
Bikes: Waterford RS22 (2004), PEUGEOT PKN10 (1981), Raleigh Gran Sport (1976), Mercian 1974
Quoted: 15 Post(s)
Liked 37 Times in 16 Posts
Tire mounting
If needed I spray a slight lubricant, such as Windex or soap solution, on the rim and tire section that is difficult to
finish up. I have never needed levers to mount a tire, although some tires are quite difficult. Bill
BillRS22 is offline
Old 09-24-22, 06:09 PM
Porknz
Quoted: 26 Post(s)
What am I doing wrong? I got the first one on after probably thirty minutes of serious effort. Broke out into a sweat before getting it on. Here is my progress on the second tire so far. There is a zero percent chance of me ever getting one of these repaired on the trail.
First use.
https://teravail.com/products/sparwood-tire#/
Porknz is offline
Old 09-24-22, 06:14 PM
big john
big john's Avatar
Quoted: 5338 Post(s)
Liked 4,905 Times in 2,575 Posts
Some of the newer tubeless ready tire and rim combinations make installing a tire very difficult. Best to use a bead jack. Some people carry them on the bike.
big john is offline
Likes For big john:
Old 09-24-22, 06:27 PM
Porknz
Quoted: 26 Post(s)
Never heard of a bead jack. Going to check this out. Thanks.
(https://www.salsacycles.com/bikes/20...eyman_sora_650)
(https://teravail.com/products/sparwood-tire#/)
Porknz is offline
Old 09-24-22, 06:48 PM
Trueblood
Quoted: 62 Post(s)
Liked 30 Times in 15 Posts
start as 12'30" and particularly what he says at 13'09". That should help.
Trueblood is offline
Old 09-24-22, 07:09 PM
Porknz
Quoted: 26 Post(s)
I'll give it a pinch next time and see if that helps.
Porknz is offline
Old 09-24-22, 08:12 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1904 Post(s)
Liked 2,821 Times in 1,444 Posts
This is a mechanical question and should be posted in 'bicycle mechanics' not GD. The only way to get good at installing tires is to do it a few hundred times.
cxwrench is online now
Old 09-24-22, 09:04 PM
Barry2
LRP=HR
Bikes: Holdsworth 1979 Special, C-dale 1993 MT3000 Tandem & 1996 F700CAD3, Cervelo 2022 R5 & 2018 R3, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 620 Post(s)
Liked 795 Times in 461 Posts
CLICK HERE
Barry
Recovery ride.. If you're not waving to small children as they pass you on their bikes, you;re goin too fast,
Yuri (cyclezen)
Barry2 is offline
Old 09-25-22, 07:52 AM
VegasTriker
Quoted: 490 Post(s)
Liked 188 Times in 146 Posts
If you have one of these larger spring clamps handy put it around the tire and work the tire iron toward the clamp. It keeps the tire from coming back off the rim as you work toward the clamp.
VegasTriker is offline
Old 09-25-22, 08:43 AM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4862 Post(s)
Liked 3,385 Times in 2,347 Posts
Notice how you didn't have any issue getting the bead of the tire of the other side on the rim. That is because there wasn't anything competing with it for the smallest diameter of the rim which is why you had little trouble at all with it. Now the bead of the second side of the tire needs that same space and the bead from the first side isn't giving it up without a fight..
As others have said you need to go back to the point you started with on the side that's giving you issues and push it's bead to the center of the spoke channel if there is one and push the bead of the side that is already on the rim out of the spoke channel and onto it's bead seat of the rim. Do that every few inches working in both directions around the rim, toward the point where the bead is making you wonder how it's even possible or if they made the tire wrong.
Takes some practice and you might have to do this multiple times, but every little millimeter of bead you gain getting it over the rim is one closer to success.
When you get good at this, you may not even have to use a tire lever to unmount your tire from the rim. But a good lever or tire jack for bicycle tire does make it quicker to mount and dismount a tire. One day I'll get one! <grin>
Iride01 is offline
Old 09-27-22, 09:05 AM
SpeedyBlueBiker
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Quoted: 93 Post(s)
Liked 187 Times in 120 Posts
I have found youtube videos to be very helpful in demonstrating how to get tires on and off tight rims. Just search youtube.com and you'll get a lot of advice from some people that really know what they are doing.
SpeedyBlueBiker is offline
Old 09-27-22, 09:37 AM
livedarklions
High Performance Noodler
livedarklions's Avatar
Quoted: 7299 Post(s)
Liked 7,532 Times in 4,231 Posts
Probably too late now, but if you're finding it difficult to change tires, next time just put the new one on the rear. I don't see the point in making this two tire changes instead of one except for a very small theoretical cost savings. I'm not even sure that there's any cost savings at all as the tire on the replacement tire on the back is probably going to need replacing at about the same time.
livedarklions is offline
Likes For livedarklions:
Old 09-27-22, 03:39 PM
cxwrench
cxwrench's Avatar
Bikes: lots
The idea is to always have the newest tire/best tread/most puncture resistance on the front. I never leave a tire on the front wheel when replacing the rear, I swap them at that point.
Likes For cxwrench:
Old 09-27-22, 04:56 PM
rumrunn6
rumrunn6's Avatar
Quoted: 4766 Post(s)
Liked 2,568 Times in 1,740 Posts
fwiw - I like toe clip strap(s) or velcro straps as an extra hand(s) to keep the tire squeezed into the channel, while I work my way around the wheel
rumrunn6 is offline
Old 09-27-22, 06:05 PM
sean.hwy
sean.hwy's Avatar
Bikes: Blur / Ibis Hakka MX
Quoted: 339 Post(s)
Liked 215 Times in 155 Posts
Most tires I can put on by hand. You don't want to use a tire lever to install the tire. It might pinch the inner tube. Some tire/wheel combos are real PITA, for those I use bead/tire jack already posted back in #10.
sean.hwy is offline
Old 09-28-22, 06:08 AM
sbuckaroo
Quoted: 25 Post(s)
Liked 6 Times in 4 Posts
This is a cool idea.
sbuckaroo is offline
Old 09-28-22, 04:24 PM
rumrunn6
rumrunn6's Avatar
learned it here from another BFer about a decade ago. the MTB doesn't need all that but the summer MTB tires are kinda soft & floppy so a strap helps. the hybrid's winter tires are tough, so all hands on deck. I have a bead jack, but that only works w/ narrower tires on the road bike. doesn't fit around the hybrid winters & the MTB summer or winter tires
rumrunn6 is offline
Likes For rumrunn6:
