Weird brake lever deterioration
Old 09-25-22, 10:06 AM
tenrec
Quoted: 13 Post(s)
Any idea what's going on with my brake levers? These are not scratches or scrapes -- they are some sort of curlicue lines in the aluminum of the levers. They remind me of worm damage to wooden ships at sea. These are the original brake levers that came with my bike. Thay are 2009 Shimano Ultegra and they're mounted on a 2009 Trek Madone 4.7. The deterioration began a number of years ago and had been getting gradually worse.
tenrec is offline
Old 09-25-22, 10:20 AM
mdarnton
Bikes: nothing to brag about
Quoted: 111 Post(s)
Liked 186 Times in 108 Posts
Do you wear a wedding ring? This looks like something cut through the surface as a small scratch, and then given an opening the decay spread. Looks worst under your ring finger.
mdarnton is offline
Old 09-25-22, 10:25 AM
Unca_Sam
The dropped
Unca_Sam's Avatar
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1966 Schwinn Deluxe Racer, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules
Quoted: 1665 Post(s)
Liked 929 Times in 639 Posts
Those parts are anodized, or they should be. While the oxide layer created by anodizing is tough, it's not invincible. Besides sanding, one of the only ways to get through anodizing is a strong basic solution, or enough time with a weaker solution.
To be perfectly honest, it looks like someone took a fine grinding stone in a Dremel and let it skip across the surface of your levers. Usually when anodizing wears through it has an obvious cause.
Unca_Sam is offline
Old 09-25-22, 11:09 AM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1925 Post(s)
Liked 2,839 Times in 1,452 Posts
Corrosion, nothing more, nothing less.
cxwrench is offline
Likes For cxwrench:
Old 09-25-22, 11:58 AM
jimc101
Quoted: 428 Post(s)
Liked 77 Times in 67 Posts
That's common on older anodized Shimano shifter levers, often seen on the levers from the early 90 onwards, unfortunately
jimc101 is offline
Old 09-25-22, 12:47 PM
tenrec
Quoted: 13 Post(s)
Is there anything that con be done about it? Can the levers be refinished?
tenrec is offline
Old 09-25-22, 12:48 PM
tenrec
Quoted: 13 Post(s)
Corrosion, certainly, but in such an odd linear pattern.
tenrec is offline
Old 09-25-22, 12:50 PM
tenrec
Quoted: 13 Post(s)
I do wear a wedding ring. I'm not sure it's exposed by my gloves, although that's possible. I see what you mean about the problem being worse in that area.
tenrec is offline
Old 09-25-22, 01:22 PM
sweeks
sweeks's Avatar
Quoted: 850 Post(s)
Liked 377 Times in 278 Posts
Has the bike been ridden in the winter, when there might be salt residue on the roads? It certainly does look like corrosion.
sweeks is offline
Old 09-25-22, 01:45 PM
SJX426
SJX426's Avatar
Quoted: 1364 Post(s)
Liked 1,550 Times in 816 Posts
@tenrec - you can remove the levers from the base as an individual part.
Spray with Oven Cleaner and let it sit for no more than 15 min and rinse. The anodizing will be removed.
Polish with Mothers AL polish and it will be fine. The downside is needing to polish periodically.
SJX426 is offline
Likes For SJX426:
Old 09-26-22, 12:14 PM
MudPie
MudPie's Avatar
Quoted: 98 Post(s)
Liked 98 Times in 76 Posts
I assume this is on both R and L levers? Pictures suggest L and R levers.
If true, a ring may not be the only cause, unless you wear rings on both hands.
MudPie is offline
Old 09-26-22, 02:31 PM
Iride01
Plz hurry Dec 22!
Iride01's Avatar
Quoted: 4881 Post(s)
Liked 3,401 Times in 2,357 Posts
If the bike isn't for show or about to be an art exhibit, just don't worry about it. Or buy new if it bothers you that much.
Iride01 is offline
Old 09-26-22, 03:36 PM
FBinNY
Quoted: 4624 Post(s)
Liked 514 Times in 345 Posts
+1,
You sweat too much. Aluminum and salt don't get on very well, especially with a bit of acidity to help things along. Once your caustic mix gets through the protective surface it's free to attack the base metal with impunity.
Clean them up If you care) with something like Scotchbrite, then apply some kind of clear lacquer to protect them. You don't have to be obsessive, but a periodic wipe with a damp rag can prevent a recurrence.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Likes For FBinNY:
Old 09-27-22, 04:57 PM
tenrec
Quoted: 13 Post(s)
Yes, it's on both levers. I only wear a ring on one hand.
tenrec is offline
Old 09-28-22, 07:33 AM
bblair
Bikes: Lynskey R230, Trek 5200, 1975 Raleigh Pro, 1973 Falcon ,Trek T50 Tandem and a 1968 Paramount in progress.
Quoted: 223 Post(s)
Liked 182 Times in 123 Posts
I'm thinking abrasion from a car rack or something like that.
bblair is offline
Old 09-28-22, 10:27 AM
bboy314
bboy314's Avatar
Quoted: 111 Post(s)
Liked 188 Times in 107 Posts
This is normal corrosion, probably from sweat. I’ve seen hundreds of levers that look just like it.
bboy314 is offline
Likes For bboy314:
Old 09-28-22, 01:33 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Not that...we already figured it out a few days ago.
cxwrench is offline
Old 10-05-22, 03:25 PM
rickpaulos
Quoted: 88 Post(s)
Liked 74 Times in 50 Posts
The aluminum wheels on my van looked like that, before they got really bad. From cat urine and road salt. i'd say cat urine does more damage than road salt. And both cause far more damage than human sweat. I've seen plenty of bikes that are relegated to indoor trainer status that were destroyed by sweat. Living in the rust belt, all cars and bikes (and snowblowers) used in winter get destroyed so there isn't much hope in fighting it. Titanium is best at resisting corrosion but I haven't see ti sti levers.
Aluminum forms aluminum oxide on the surface as it cools to a solid. Any minor scratch can expose the underlying aluminum to corrosion. That factory finish is hard to replicate unless you have a lot of patience. A bit of clear spray paint can help protect the finish. There are aluminum colored spray paints but they are a tough color to work with.
rickpaulos is offline
