Lube n00b
Lube n00b
I cleaned and re-lubed my chain, then went for a long ride in the rain and the lube did not last. Does anyone have a lube they recommend for riding in the rain?
Squeaky Wheel
Chain-L is the best I have found: Home Page Chain-L High Mileage Bicycle Chain Lubricant
Quoted: 871 Post(s)
Liked 726 Times
How long was it between applying the lube and riding? The lube needs to work its way into the chain.
I've been using NFS, but the new Silca lube looks to be even better.
Quoted: 164 Post(s)
Liked 44 Times
if you want performace boosts from you lube you have to just strip the entire chain and use something molten speed wax that has dissolved particles that will get into the rollers and stay there , but you have to take your chain off almost every time , at least if you want that boost , if you find a way to apply molten wax to a chain on bike without making a mess let me know plZZZZZ
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
I've used Finish Line Ceramic in the PNW winters for many years. I use a heat gun with a shrink tube attachment. First I heat and dry the chain with the gun. Then wipe it clean. Then apply fresh lube and heat with the gun while pedaling 100 strokes. Then I wipe dry again. I never clean a chain with solvent or use wax. My lube job will last maybe 200 miles of rain riding. My chains last 1000s of miles. I've tried all sorts of materials and schemes and this has worked best for me. I understand that Chain L is also good, though I've never used it. I think my method of application and never cleaning with solvent are the keys to long chain life in the wet. Rain rides, in actual rain, are easier on gear than riding on wet roads after rain.
Results matter
Results matter
Quoted: 896 Post(s)
Liked 2,063 Times
I use Finish Line Wet Lube. Seems to work fine.
