#9576
Quoted: 3241 Post(s)
Liked 2,512 Times
Here is what the Iris color looks like in the sun.
#9577
Mostly OEM, however it's been converted to 7 speed.
Non-original 7 speed dura ace Freewheel, gripshift, aerobars, DA pedals, Shimano aero seatpost, and triathlon turbo saddle.
Likes For texaspandj:
#9578
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 582 Post(s)
Liked 697 Times
Yep
My 85 was also updated to Aero Levers they were Aero Gran Compe's they should be non Aero Shimano 600 levers (which it will be going back to) the rear derailleur was also changed to a 600 tricolor. the bars and stem were also changed, the bars were newer 2000'ish era bars. The Aero levers were a common change when they came out in 1986ish. it was the thing to do.
For yours having tri bars i would suspect that yeah they changed the brake levers when they put the Tri bars on. not sure how well a non aero brake lever would function with Tri bars.
#9579
Likes For seedsbelize:
#9581
Liked 2,512 Times
#9583
Quoted: 1557 Post(s)
Liked 1,732 Times
Finally found time to finish my MV. I got a set of yellow Jagwire housing /cable for my MV, but it’s too light a yellow, not a good match:
I returned the yellow set and got a Lavender/purple set. That turns out to be a very good match with the Bike’s magenta color!
Here it is. Bike finished (?)- 13-28 7 sp Sunrace freewheel shifted with Sora ST 3300 brifters, 105 FD1056 . 42/52 Biopace SG chain rings. Cannondale 25.4mm carbon seatpost with Fizik Aliante seat. Easton 26.0mm carbon drop bar on an Origin8 stem.
Too bad the pink Selle Italia Smootape doesn’t quite match the magenta color. Anyone has magenta bar tape that is a good match with the frame?
#9585
Liked 2,512 Times
#9586
Perhaps bar wrap in yellow would be easier to match.
Also, I think the yellow bar tape would give (in the words of R.T.) better aesthetics Balance.
#9588
Liked 2,512 Times
I had some yellow for a while. The color was off just enough. It didn't look bad, but not very good either.
#9590
Quoted: 1946 Post(s)
Liked 2,004 Times
Still room for these 87s? My wife and I picked these up within a week of each other. My wife still has hers but with 7700.
His and Hers
His and Hers
Likes For Classtime:
#9591
Liked 2,512 Times
#9592
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
I'm interested in the bottle cage. Is it a good a match for the magenta as it appears in the picture? If so, do you know the brand?
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
#9593
Where I'm at in the '83 Centurion TA?
Well, after RTs ban I felt the wind was let out of my sails and just had the frame sitting in the stand.
I'm finally slowly getting over it and starting the build.
So the build, a beautiful red color, and small 52cm frame. I comfortably ride a 54cm and my favorite Ironman road bike is a 52cm, so it'll work.
I initially thought I'd use a full tri color 7 speed group. However the HS that R.T. sent with it was the Shimano 600 and it's silver looking and not the gray looking that comes on the Shimano tricolor 600. And I like the way the silver looked on there against that nice red.
Remembering the parts I pulled from my '85 Ironman had most of the original 600 parts I decided to go with those 600 parts instead.
Two issues I'm having is, although I have the original '85 brake levers I don't have the original calipers. I may be forced to use the tri color Brakeset if I can't find some . Also, I'm using the '85 Ironmans down tube shifters which fit perfectly on the Shimano type A shifter boss But I don't have any 4.5mm screws. If I can't source them, I'll go therccardr route and dremel to fit and tap to 5mm, and go to full Shimano tricolor group. The simplest fix is to get some 4.5 screws.
One last thing, if someone has a '85 Ironman, can you post a Close-up pic of the OEM rear derailleur shot from behind. Alrighty then Ironkids, hang in there.
#9594
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
I prolly have some 4.5mm mounting bolts. Let me know how long they have to be, as they came in several sizes.
#9595
Liked 1,732 Times
The Specialized bottle cage is pretty much a perfect match with the frame! I can't take credit for finding it though- it came with the bike when I bought it.
#9597
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
Worse comes to worse, you can source those screws from Loose Screws. Don't go through their website; their eBay store has free shipping.
https://www.ebay.com/itm/Shimano-NOS...EAAOSw7VJeQFvd
If you don't need the flange on these, just put them upside down in a vice and tap with a hammer to remove the screw,
#9598
Liked 2,512 Times
I'm still waiting on a crank, and chainrings for the black Turbo. Also the rest of the original headset. Even though I prefer shiny over murdered out, I'm still excited to see how it turns out.
#9599
Liked 2,004 Times
Probably not polite to ask, but how why the IM sticky reappears? AND RT vanishes at the same time? Some kind of sacrifice?
