October 2020 Goat Head Thread
Non omnino gravis
Miles ridden over the past 5 years: 50,000+
Number of goathead-related flats: 0
Number of bikes fitted with tubeless tires: all of them
If you get frequent "nuisance" flats, you can either go tubeless, ride frozen hoses (aka My Tuffys or Gatorskins,) or suck it up and get good at fixing flats on the side of the road.
Likes For DrIsotope:
Quoted: 850 Post(s)
Liked 344 Times
I used Orange Endurance Seal with regular butyl tubes and it works remarkably well... until it doesn’t. It seems like OES has this nasty tendency to booger up to the point where you have tons of fluid (which will squirt everywhere and dry on your frame and be a b**** to remove) but it won’t actually fix your flat. I imagine that sealing works a lot better with actual tubeless tires though.
I’d say if you’re not willing to try TL, definitely get some Orange or Orange Endurance seal. But don’t put much in. I’d say put in like 0.5fl oz. and top up frequently (once a month?) If you dump 1-2fl oz into a single tube, it’ll just booger up super quick leaving you high and dry. And there’s no good way of checking the boogerification.
Another reason to not use too much sealant is that with goatheads, if it’s gonna seal, it’ll seal instantly. If it’s not gonna seal, it’s not gonna seal and any additional sealant is just money down the drain + extra work to clean up.
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I used to live in goathead territory (San Jose, CA). Pretty much guaranteed to flat at least once during each ride if I didn’t use sealant with non-gatorskin tires.
