A New Lubricant
#51
Quoted: 3375 Post(s)
Liked 5,513 Times
I want a new lube, one that won't go away 🎵
One that won't splatter my bike 🎵
One that won't squeak all day 🎵
One that won't make me nervous 🎵
Wonderin' what to do 🎵
One that makes me feel like I feel when I'm with you 🎵
I'm alone with you, baby 🎵
Likes For Shimagnolo:
#52
Friendship is Magic
Bikes: old ones
Quoted: 26411 Post(s)
Liked 10,378 Times
....someone here could do posterity a great service by collecting all the chain lube threads into one giant sticky, similar to the endlessly entertaining Helment Thread in the A+S. Not me, of course, but someone.
#53
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
#54
Quoted: 1062 Post(s)
Liked 665 Times
At my day job, I work with a lot of engineers. The trouble is, a lot of the information and advice that floats around is qualitative, and can't be quantified in our lifetimes at an acceptable cost. We're faced with, either committing to a qualitative study, which might never come to fruition, and might take a couple tries before actually getting actionable data. Or, letting the engineers follow their gut instincts and qualitative recommendations. In some industries (automotive, aerospace, electronics), you have either high enough production volume, or enough money to burn, that you can engage in a careful quantitative study of every engineering decision. Bikes are not one of those industries. For that reason, we're stuck making our best guesses. Also, because most R&D on lubricants is done under much higher power applications, many of the rules of thumb are probably inapplicable to our needs.
Once again I'm not a chemist (a mere industrial physicist), but the jet black stuff is probably metal dust. For instance that's what you get when you polish metal with very fine grit, such as when sharpening a knife on a hone.
#56
Advocatus Diaboli
Liked 1,532 Times
#57
Quoted: 1943 Post(s)
Liked 2,164 Times
Probably when people see it for what it is. It is just a chain, and apart from those who need a bike for their livelihood, it’s just a bike.
I imagine the vast majority of people who ride, really don’t care about chain lube. And when they do oil their chain, once in a blue moon, it is probably with whatever is handy.
It’s that very tiny percentage that won’t give up the ghost.
John
John
#58
Palmer
Quoted: 1665 Post(s)
Liked 1,818 Times
It's still sold today as multi-purpose oil. And while I'm fully aware that doing so puts me in the group of kids who get more cavities, I use it on my bike chains.
Likes For tcs:
#60
you suppose (imagine) the world is rid of poverty and the vast majority of people don't care about costs that add up because the vast majority of people own their houses and they don't care about chain lube precisely because of that. right?...
imagine all the ignorant people living for today and never caring about the day after tomorrow... why care about chains if you are unable to see more than one chain on your bike because you are living for today?
free market economy? can't have that. you have to choose between capitalism and communism. other option is not allowed.
all lubes have the same additives, right? gear oils from 2021 are the same as gear oils from 1970, right? greases too...
polymer additives to improve film thickness as to prevent wear for example... they are present in all lubes, right?
particulate matter that is small enough to enter the film thickness is what causes most damage to the chain surface. there's also mixed lubrication instead of hydrodymanic lubrication. so you need as thick film thickness as possible. ever care to measure the lubricant film thickness inside the chain? you could do that but it's too hard for you to "imagine" a way to do it. we are talking about microns. polymer additives that strongly adhere (adsorb) to the metal surface. additives that increase viscosity when subjected to pressure. and lastly... the base oil's viscosity. the thicker it is the more time the inside of the chain stays cleaner. that's not the only reason to have some type of wax used.
particulate matter is a problem in your house too. dust settles just because you keep your windows open. how thick do you imagine the lubricant film is inside the chain? could it be that some lube is thinner than another and therefore does NOT prevent wear? ok, don't imagine that, we are only to imagine a world where some should give up the ghost.
so then i'm a minority, should succumb to the (relative) wealthy majority and give up the ghost.
ppl who own bikes and get onto this forum are all born into wealth, right?
one aspect of planned obsolescence is the effort of big players to keep people in ignorance as to how they are screwed. but they don't need to put that much effort if the ignorant masses are programmed to despise each other and pretend that a chain is too cheap - although there might be more than a dozen of chains used - to care about.
why learn anything? cost of chains and lubes don't really matter. cost of learning stuff is too much.
wax (and any other base oil - although some are more resistant than others) can oxidise faster once is subjected to pressure AND chemicals. that's one reason to mix it with other stuff.
https://link.springer.com/article/10.1007/BF01173332
With a 30-minute initiation by air containing 0.35% of N02, the induction period is ten hours, as compared to 366 hours in absence of initiator.
#61
some players in automotive lubricant offer much better products than most of the chain lubes or at least for a much lower cost to the customer (price). all you need is to mix 1-2 products and add some wax. you just need to find out what product is most suited for the application. the most expensive products will still be much cheaper than chain lube bike label crap and will last you a lifetime. and if you own a car... the cost (for bike use) is negligible.
bike label lubes are overpriced crap. i've yet to find an exception to this rule.
i won't advertise.
i won't advertise.
#62
One of the advantages of a liquid lube is it can be applied more frequently, if desired, so there's no need to try to get extreme mileage from a single application. Chain removal is not necessary to relube. With hot dipping, most of the lube goes onto surfaces that don't require it and that all flakes off. I only apply a drop or two to each roller. My drivetrains are cleaner than ever using a paraffin wax based liquid lube.
#63
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I agree that it doesn't matter much what you lube with as much as that you lube your chain. I do indeed use an expensive mystery oil on my chain, I wipe it down after every ride, and I got 4K miles from my last chain. But I'm not kidding myself; it's hobby-style entertainment rather than science or engineering. As Stuart Black says, no matter what your ritual or lack thereof, you'll probably get about 3.5K out of a chain. For many years, I was happy to just replace the chain every year. No boiling, no alchemy, no storage of hazardous chemicals, no arguments!
#64
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
yea, the vast majority of people don't care because they are proud of their ignorance, they have a discomfort if ever admitting they have been screwed more than once. it's easier to fool people than to convince them that they have been fooled.
I’ve worked in chemical research and development for 4 decades. I know a thing or two about chemicals, chemistry, processes, and the cost of development. You think that it is easier and cheaper to develop your own homebrew but what are you basing your development on? How many different parameters have to tested? How many chains have to tested to see if a specific formulation works better than another…whether it is your own brew or a commercial product? Each parameter change is going to require a significant investment of time, money, and materials. If you are poor, you don’t really have the resources to do that kind of investment. Most people don’t have the time.
But, yet again, a chain is a consumable. It doesn’t matter if you are rich or poor. It doesn’t matter which lubricant you use from something expensive like the Wolftooth lubricant (remember what the post was about) or you use used motor oil. The chain will wear and need replaced. You haven’t invented a better mouse trap, especially considering that you have yet to tell us anything about how well (or poorly) your “system” works.
As to whether lubricants from 50 years ago are the same as lubricants the same as today, definitely not! Bearing grease, for example, is entirely different from 50 years ago. We used oils trapped in sterates in the 70s. The oil drained away fairly quickly which is why old grease solidified over time. It simply lost the oil. Modern grease is based on polymers that behave much differently. Even fluid lubricants of today aren’t the same as they were even 30 years ago. Chemists have spent a lot of time improving the formulations for better lubricity and longevity. Refiners are making purer materials that perform better and longer. Motor oil, for example, started breaking down in engines very quickly and needed changing after 3000 miles. Modern oil lasts much longer.
Even 50 to 100 ppm (70 to 35 times less than 0.35% nitrogen dioxide) is hazardous to the health. Nitrogen dioxide simply isn’t a factor in oxidation of any lubricant on a bicycle.
Stuart Black
Stuart Black
#65
Liked 4,217 Times
i won't advertise.
i won't advertise.
Stuart Black
Stuart Black
#66
Liked 2,164 Times
The pandemic illustrated the complete globalization of the bicycle industry by communist China and the complete inability of so-called capitalist economies to take any steps to prevent it. But the capitalistic United States chose to extend unemployment benefits and send stimulus checks as we wait for bikes and components to become available again.
But there is one constant, from the beginning of mankind until the very last breath, money and power will rule. Those with the gold truly do make the rules. I'm sure there have been many who may oppose this, but they are buried in obscurity throughout the world.
John
#67
RidesOldTrek
Probably a better marketing message than “Works at least as well as the hundred other chain lubes on the market for twice the price!”
Likes For Bamicus:
#69
Finish Line makes a cleaner/lube. I was skeptical but I got a can for my daughter who tends to neglect things if they take more than one step. So far it seems to be working fine and it’s so easy she actually uses it. 17 oz aerosol for $15 on Amazon.
#70
I thought I'd go to the experts on this.
Wolf Tooth is advertising a lube called WT-1 Chain Lube. They say that it cleans, lubes, protects and lasts 3-5 times longer than other lubricants and is for all conditions. I'm not sure how one product can work optimally in both wet and dry conditions.
Has anyone tried this yet? Before I consider spending $18.95 for a 2 oz. bottle, I'd like some user thoughts and comments.
Thank you.
Thank you.
Currently I use Boeshield T-9. I find it to be splendid and would recommend it to one and all.
Ride on!
#71
MODS...Please kill this thread. I was asking whether the claims were credible and if anyone had used it.
I did not intend the 'what's the best lube' or 'what lube do you use' that it's become.
Sorry for taking up bandwidth.
Likes For MAK:
#72
Friendship is Magic
Bikes: old ones
Liked 10,378 Times
Likes For 3alarmer:
#73
Bikes: 2020 S-Works Roubaix, Infinity seat
Quoted: 20 Post(s)
Liked 25 Times
Bring data driven, I love reading Zerofrictioncycling.com.au
It's very clear (to me) there are significant differences in chain lubes with respect to :
1) watts saved
2) chain wear/longevity
and, maybe most importantly,
3) (expensive) drive train wear/longevity
I alternate 2 chains, never wash them, rewax them every 150+ miles in a slow cooker, and expect to use each for many many thousands of miles.
If you believe in good studies, believable data and avoiding common and harmful industry myths (factory grease is good, etc. ..), give Adam a read.
Spoiler Alert-nothing tests better, lasts longer or protects better than Silca's products.
Likes For bfaIllini:
#74
True about Silca products. I have a pista track pump that’s 36 years old! I’ve seen some of zero friction stuff, very interesting. You may also want to check out rolling resistance stuff that Josh recommends. You can really save serious watts with the right tires, tubes, etc. And of course chain issues. I would say, if you have prepared chains for the hour record, you know what your talking about! Engineers are usually smart people!
Also interesting that some so called lubes, actually deteriorate chains, and add watts.
Likes For Bamicus:
