numbness
Bikes: Specialized Hardrock
numbness
The longer I ride the more Im realizing that the numbness in my hands isn't something I can train through. I thought it might go away the more I trained but not so. My hands go completely numb with a regular frequency during my rides. any tips? drives me nuts trying to ride one handed while i shake the feeling back in my hands.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
squishy grips use them like an excercise ball?
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
I imagine there's gel grips, I was just thinking you could possibly kneed those like a therapy ball, possibly get flow back?
Bikes: Surly Long Haul Trucker, Gary Fisher Hoo Koo E Koo, Dahon Mu P 24 , Ritchey Breakaway Cross, Rodriguez Tandem, Wheeler MTB
Quoted: 32 Post(s)
Raise your handle bars a bit, thereby lessening the weight on your hands ( adding weight on you saddle however). More comfortable grips, gloves. Of course moving your hand position often will help as well.
I was never able to get rid of hand problems, regardless of different bars, padding, gloves, exercises, or adjustments. Finally went 'bent. Problem solved.
Quoted: 1572 Post(s)
Liked 643 Times
What kind of bike?
I've had that at various times in my career. My hands have become so numb that I couldn't feel the brake levers or shifters. I can't say how I got rid of it other than the constant messing I do with my position on the bike. Raising the bars and/or adjusting them closer to you so that you put less pressure on your wrists might help. If you ride a flat bar bike adding bar ends that allow you to rotate your wrists 90 degrees might help.
Bikes: Trek FX 7.2
This generally comes from putting consistent pressure on the palm of your hand and compressing and vibrating the ulnar nerve. Anything you can do to alleviate the amount of downward pressure you are putting by your hands onto the stem will help with this. You can get more ergonomic grips or gloves to help with the vibration and spreading out the pressure more across your hand. Or you can also adjust the stem upward or the seat slightly backward to put more of your weight on the saddle and less on the handlebars.
As you found, this is not something that goes away or you get used to. Repeated injury to the nerve will only make the numbness last longer in fact, and it can be permanent if you do it too much. Look up Cyclist's Palsy for more info.
i never use gloves and never even thought about it to be honest. its a specialized hardrock mountain bike that im riding purely road. Gets so bad that after a few miles i cant shift and have to slap them on my thighs to get the feeling back. Ill try raising the handle bars. i bet that will work for me. dolanp man now you have me nervous about damage. maybe ill try gloves today if i go. Ill try raising the bars first cause i have a feeling that will make a huge difference.
Humvee of bikes =Worksman
Quoted: 10 Post(s)
Liked 6 Times
The only workable solution is TO SIT MORE UPRIGHT TO GET YOUR WEIGHT OFF YOUR WRIST AND HANDS!!
https://highperformancesports.blogspo...-palsy-or.html
https://www.hughston.com/hha/a_15_3_2.htm
https://www.sportsinjurybulletin.com/...-injuries.html
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
raised my bars up an inch. unfortunately its still 100 degrees so no bike ride today. sucky. maybe it will cool off enough to try it out.
Bikes: Bianchi Infinito Celeste, Trek 7.5 FX, Felt Z6
Quoted: 18 Post(s)
In my experience, a couple of things were going on.
First, I found that I was using a "death grip" on my handlebars, for no good reason. I had to consciously relax my grip.
That helped some. Another thing I noticed was that if I was particularly tired, I tended to rest more of my weight on my hands. I had to make an effort to just sit up a bit straighter, and not lean down so hard.
Of course, there's the changing your hand position solution, except with straight handlebars, there aren't many choices! :-)
I'm also a big believer in gloves, especially padded ones. I did a test ride just last night w/out the gloves, and really noticed a difference.
One caveat regarding gloves: make sure they fit! I first had a pair that was too small, and if anything, they contributed to the numbing!
Good luck!
Good luck!
Im just worried about my hands sweating bad in gloves. I am one of those people that cannot wear gloves for anything. As a result its going to be difficult for me to get used to them. so do people that ride have pale hands and tan arms? Curious cause i tan very easily. not that im vain but i dont wanna look like there is something wrong with me lol
Quoted: 18 Post(s)
My advice? They're fairly cheap, give them a try.
Maybe ill pick up a pair today at my LBS when i bring my bike in for its new shoes and get the cable slack adjusted on my derailleurs
Yeah, if you've got a flat style bar, your #1 big problem is lack of hand positions. Gloves may help too, but get some bar ends and change positions once in a while. On the recumbents, I don't *need* gloves, except to help me grab my GripShifts in hot weather or in case I go down. But for those reasons, I almost always wear them. For me, weight lifters' gloves with minimal padding work fine.
Intrepid Bicycle Commuter
Bikes: 1976 Motobecane Grand Jubile, Austro Daimler 'Ultima', 2012 Salsa Vaya, 2009 Trek 4300, Fyxation Eastside, State Matte Black 6, '97 Trek 930 SHX, '93 Specialized Rockhopper, 1990 Trek 950
Quoted: 76 Post(s)
Liked 94 Times
Numb hands? Just take the pressure off of your hands. Your body rests on the saddle and handlebars, with a pivot at the pedals. Numb hands means that either you're pivoting too far forward, or you're death gripping the handlebars. If it's a pivot issue, move the seat back until you pivot further rearward. Once you've achieved a more neutral pivot position, adjust the handlebars to meet with your hands.
Here's a cool step-by-step fit guide:
https://www.singletracks.com/blog/mtb...ke-like-a-pro/
Quoted: 111 Post(s)
Liked 5 Times
1) padded gloves
2) add bar ends and use them to vary your hand position
3) Ergon-brand grips https://www.ergon-bike.com/us/en/product/gp1
4) trekking bars https://www.sheldonbrown.com/deakins/handlebars.html
Then there is the deep end,,,, that will usually fix seat pain, hand numbness and neck pain, all at once,,,, -if you dare,,,,
5) recumbent bikes (many different brands, several different types, all fairly expensive but the riding is wonderfully pain-free)
6) RANS crank-forward bikes (still look fairly normal, but much much much improved riding comfort) https://www.ransbikes.com/Fusion-N.htm (one model, but they also offer frame kits)
Yes recumbents are expensive--but a bike that hurts so much to ride that you won't use it is no bargain.
just got some gloves today so ill give that a try tomorrow and see what happens. Pretty sure its just too much pressure on my hands. Thanks everyone. Ill keep yall posted on if this solves it or not.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6766 Post(s)
Liked 5,477 Times
A few suggestions with what you've got, ranked from easiest/cheapest:
1) padded gloves
1) padded gloves
How them wheels holding up?
After todays 24 mile ride the gloves made an enormous improvement. Hands went numb 2 times really bad and the rest was very maintainable. Id like to raise my bars another inch or so but i need to get a new riser first.
Ahsposo
I have my wheels on order i actually have 2 sets coming into the LBS to try. first is the Bourough and the second is the nimbus by specialized. Both are armadillo. Gonna pick one of the two when they come in. The rep is supposed to be there too to weigh in on his assessment of my needs. Will keep everyone posted on the tires for sure. I was bummed they weren't in stock he has armadillo bouroughs but they were too big for my rims.
Ahsposo
The Mississippi Flash
Bikes: Specialized Hardrock MB
Gibs, do you have an update, I have a Specialized Hardrock also and have the same issue.
I solved that issue with Ergon GP-1 grips on my flat bars. Gel gloves help even more but I really wear them more for protection if I take a spill. Any of these ergo grips (I think the Specialized versions are even better than Ergon's) will make an ENORMOUS difference on flat bar bikes. Also, like a golf club, steering wheel, or airplane yoke, keep a lighter grip. Makes a big difference. And even on flat bars you can come up with a few positions, especially if you use bar ends.
If I ever feel uncomfortable, I stop for a bit and dismount. I don't race, compete, or have any need to press on; I ride for fun. That's something too many current cyclists seem to have forgotten about IMO.
Anyone try these https://www.serfas.com/product_details.asp?ID=193? They look like they might do well with the bulge in the middle. I'm still trying everything to get rid of left hand numbness. Lower the seat, tilt seat slightly backwards, move seat forward, change handlebars, higher stem, several different kinds of grips, padded gloves, rotate brake and shifters down. So far nothing has helped, but then again I don't know how long it might take for a positive change to have an effect. I do know that if I don't ride at all for 3 days I still have the numbness
Liked 643 Times
I have an answer but you probably don't want to hear it. It's the "R" word.
