[Brompton] Adding a front derailleur: Clamp?
Old 10-21-16, 01:01 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Of course Da Hon folds to the left, away from the drive train , Brompton Covers it with the front wheel..
And OP did Buy a Light aluminum Piece Made for The Da Hon Bikes and put it on a Brompton.
fietsbob is offline
Old 10-21-16, 04:37 PM
invisiblehand
Part-time epistemologist
invisiblehand's Avatar
Bikes: Jamis Nova, Bike Friday triplet, Bike Friday NWT, STRIDA, Austro Daimler Vent Noir, Hollands Tourer
Quoted: 122 Post(s)
Liked 3 Times in 3 Posts
Originally Posted by badmother
.. or break the derailer bottom....
Do`nt ask me how I know this..
Bummer.
BTW, the "nasty woman" blurb cracks me up. FWIW, this election cycle has made me revisit a few priors regarding sexism and racism in the US.
A narrative on bicycle driving.
invisiblehand is offline
Old 10-21-16, 05:19 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Liked 118 Times in 99 Posts
Originally Posted by fietsbob
mine came thru the original Brompton dealer in the US, Fold a Bikes, in Palo Alto Cal. he has since retired , selling the house probably gave him a fortune, given the real estate bubble in that area..
Channell Wasson's clamp is no longer available, unlike LitePro's, which is. Pick your poison.
https://www.flickr.com/photos/nwben/...impmybrompton/
Winfried is offline
Old 10-22-16, 01:36 AM
badmother
badmother's Avatar
Quoted: 317 Post(s)
Originally Posted by invisiblehand
Bummer.
badmother is offline
Old 10-22-16, 03:38 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Removing the bottom of the cage certainly looks important given where the chainring is in the photo relative to the derailer bottom. Without removing it, the chain would be hanging on it. A "fast" fold would probably bend the derailer or mount over time.
The LBS where I bought the Tiagra doesn't recommend cutting off the derailleur cage, although it's been done:
Winfried is offline
Old 10-22-16, 10:26 AM
fietsbob
Bikes: 8
Any How I Got Mine from Channell. several Years ago , then went with the Mountain Drive, Instead On my Brommy.
fietsbob is offline
Old 10-22-16, 11:54 AM
smallwheeler
smallwheeler's Avatar
Quoted: 151 Post(s)
Liked 10 Times in 8 Posts
Bummer.
i wonder what you meant by this.
smallwheeler is offline
Old 10-22-16, 11:56 AM
smallwheeler
Quoted: 151 Post(s)
i've never thought of you as a nasty woman. that's terrible.
Old 10-22-16, 02:00 PM
badmother
badmother's Avatar
Quoted: 317 Post(s)
Oh, but I am baaad
Good girls can go to heaven but bad girls can go wherever they want, did you not know??
Not going anywhere. Staying home and deciding what bikes get studded tyres this winter. First snow came today..
Old 10-22-16, 02:13 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
The FD is a cheaper option, although the SpeedDrive is nicer:Total ≈ €150
SpeedDrive licensed to ATS : £230 + shipping ≈ £250/€280
Winfried is offline
Old 10-22-16, 03:14 PM
fietsbob
Bikes: 8
Mountain drive (mine) is a Reduction gear (130-54) the Speed drive 110 is an overdrive 34-'54',
but the frame BB edges must be Chamfered That is where the torque transfer is..
and So you need the shop tool facing cutter.
.(in France shopt that used to set Up Mavic equipped bikes needed one for that company's BB installations)
The Mk4 BB edges are somewhat faced with a Bit of a Taper , just not enough for the needed grip of the SD installation.
because of the Torque transfer needing to be More solid, the B version MD has a Knob sitting on top of the Frame
behind the BB where the rear Fold Pivot is, .. on the end of a Lever .
so It turned out to be more User Installable . on my Mk 3 & moved to My Mk4.
[if you got the version for other bikes that torque arm has a bolt hole and you wrap a coaster Brake type strap around the right chainstay. ]
Of course the big difference between a derailleur and an Internal gear is shifting, you cannot push a chain off a sprocket while you are stopped .
fietsbob is offline
Old 10-24-16, 10:01 AM
invisiblehand
Quoted: 122 Post(s)
I assume "Mr T" is Trump from badmother's signature.
As you know, I'm an economist. I am pretty familiar with research on race-ethnicity/sex/age wage and income discrimination literature. Long story short, I've revisited some of my conclusions from that literature as a consequence of the present election.
Anyway, this is the wrong forum for this.
Old 10-24-16, 11:05 AM
fietsbob
Bikes: 8
There is the Actor that starred in the A Team . had quite a Career in "the Business", as my LA friends call it..
https://en.wikipedia.org/wiki/Mr._T https://www.imdb.com/name/nm0001558/
fietsbob is offline
Old 10-24-16, 12:38 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
It's no longer the case for the SpeedDrive sold under license by ATS from Taiwan:
Welcome to ATS
https://bikegang.ecwid.com/#!/Brompt...ATS/p/60194073
In terms of price, a SpeedDrive comes between a front derailleur and a Alfine/Rohloff built by Kinetics.
Winfried is offline
Old 10-25-16, 11:52 AM
fietsbob
Bikes: 8
Quote your Link :
Milling cutter (A)
- Chamfering the bottom bracket, for cone installation required
fietsbob is offline
Old 10-25-16, 12:01 PM
fietsbob
Bikes: 8
NB Overdrive gear, the torque in the Gear train from the planetary gear is just pushing against air resistance
since you kick it in to Go Faster..
The High speed Drive (non Standard splined vs 5 bolt chainrings) is a 2.5X overdrive
the 2.5 reduction gear needs a more rigid torque transfer because the resistance Is Gravity.
fietsbob is offline
Old 10-25-16, 02:20 PM
invisiblehand
Quoted: 122 Post(s)
Clubber Lang!
Old 10-25-16, 02:59 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Quote your Link :
"Brompton New Non-Chamfer BB Shell ATS Speed drive Gearing System"
Winfried is offline
Old 10-25-16, 03:02 PM
fietsbob
Bikes: 8
Hamster wheel continues
fietsbob is offline
Old 11-05-16, 02:18 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Also works with LitePro's P clamp + derailleur kit.
File Type: jpg
File Type: jpg
Winfried is offline
Old 01-07-21, 04:15 PM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Since it's supposed to be a sturdier alternative, I got a B-series LitePro clamp, and noticed that the part where the derailleur is attached sits further out than a K-series: At rest, ie. on the smaller chainring, a LitePro two-speed derailleur sits above the outer chairing.
Can someone confirm? And in that case, what two-speed derailleur would work with a B-series clamp on a Brompton?
Winfried is offline
Old 01-07-21, 05:50 PM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
An important factor limiting the front derailleur operation is of the cage coming close to the seat tube and the derailleur mount itself. When the mounting point is above the band around the seat tube, the cage hits the band. When the point is near the band, the cage can go under the band, closer to the tube. For the K-Series Lightpro you have a proximity window to the seat tube, when you put the mounting point at the very top of the holding finger, as in your photo. However, then the torque bending the finger ends up being the highest then. Also the window narrows and maybe disappears if you get the angle right in the vertical plane for the derailleur - different for Brompton than Dahon. Litepro has a new edition of the mount for K Series, with a stronger finger, but that finger is pretty much free to rotate in the azimuth - no clue here why they mass manufacture flawed designs. In B Series, the mounting tab is presumably secured to the band with one screw. You need to add a second screw and secure both with threadlocker.
As to the specific derailleur, I got a used 105 off Ebay. Ultegra also worked in my memory. Given the challenging geometry and large difference in ring sizes I wanted, I was looking for a long steel cage that could be deformed. To get the angle right, you will need to get the Sram asymmetric washer. You will also need to push the bottom bracket axle out on the drive side, by whatever means, longer axle and/or spacers. For my 3 rings, I use a Suntour derailleur as I found their derailleurs to be slimmer allowing for a better fit against the seat tube.
2_i is offline
Old 01-07-21, 07:48 PM
biaddiction
biaddiction's Avatar
Quoted: 5 Post(s)
would like to know this as well...
biaddiction is offline
Old 01-09-21, 08:23 AM
Winfried
Winfried's Avatar
Quoted: 573 Post(s)
Thanks much. From a picture, is there a way to tell what K clamp it is (generation 1/2)?
So you used a B clamp + Shimano 105 for a double,and a B + Suntour for a triple?
Indeed, the K clamp I've been using for years with a Shimano Tiagra derailleur is slightly bent outwards, but it's working fine. At worst, you can slide a ziptie through the window:
Winfried is offline
Old 01-09-21, 02:42 PM
2_i
Quoted: 840 Post(s)
Below is a photo of 4 adapters. From left to right, they are the earlier Litepro, the more recent Litepro, Ridea and CM Wasson. Then there is Litepro B-Series with modified Suntour triple mounted. The earlier Litepro got bent and straightened several time as its holding finger is too feeble. The second has a more sturdy finger, like in the cheap, common, no-name adapter with a more coarse band, not shown here. The problem is that the finger is secured with just one bolts and is prevented from rotating with a small tab sticking out, that does not fit well and that will be sheared off in no time. The Ridea has a shorter sturdier finger, but the mounting point gets shifted farther away from the seat tube. CM Wasson is sturdy, but is basically overbuilt and heavy. The best for the purpose is the Litepro for Birdy.
I used the B-Series both with double and triple. With double there is though more flexibility and the cheap adapter, not shown, also worked.
4 adapters: 2 x Litepro, Ridea, CM Wasson
Litepro f/Birdy w/triple Suntour. The chain is on the smallest ring in the photo.
2_i is offline
Likes For 2_i:
