Rohloff, yeah, nah, yeah, nah.
Likes For GeorgeBaby:
#77
This wrench fits...
If it was new from the factory, there would not be any oil in it. In that case, add oil. But perhaps oil was added before you got it.
I do not know anyone else with a Rohloff, I pretty much had to learn everything from the internet, which was quite helpful. A neighbor is a bike mechanic, he has told me that the only Rohloff he has ever seen was mine, and he works at a major bike shop. So, they are rare in USA and you have to seek out good advice. My first international trip with it, I saw eight other bikes with Rohloffs, they are more common for touring outside of USA.
This was written by a highly opinionated writer, but it does have some useful information.
(link removed because I don't have enough posts to include links in my posts, even in quoted material. That's a bug, not a feature) - BoltBreaker
Depending on the age of yours, it might have the threaded sprocket, or might have a splined sprocket on a threaded carrier. If the threaded sprocket, that means you need a special Rohloff tool to remove the sprocket. I am not sure exactly when they changed to splined but it was well after I bought mine eight years ago.
Around Berkeley, the local shops all know about Rohloff, but most of the cycles I see with them are fat bikes in the front windows of their shops. :-)
#78
Quoted: 3451 Post(s)
Liked 1,452 Times
I am not sure why but Thorn always sells bikes with a 17T Rohloff sprocket, but the hubs come from the factory with 16T, which is what I have.
Around home I use a 44T chainring, but touring or mountain biking I use a 36T chainring. And add or remove 4 links with a second quick link.
#79
This wrench fits...
Love mine after 5 yrs of urban riding. (if you live in the east bay I will say a prayer for your bike)
Seriously, there is maintenance but it is minimal.
I just now am now getting a new cog for the wheel
I wouldn't trade it for anything. I'm just freaked out about getting it stolen.
#80
Liked 1,452 Times
Yes, the East Bay is a kind of black hole for stolen bicycles. Here, they seem to end up either at Karim's or the Ashby Flea Market, but I've managed to keep all of mine, so far. The only bike I ride and lock is my Rivendell QuickBeam, and that's just while shopping. The Rohloff bike will likely never get locked to a post or fence, it will either be under my ass on a ride or secured in the garage (or motel room). Still, life is filled with risks, and I know there are opportunists everywhere.
Likes For Tourist in MSN:
#81
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1233 Post(s)
Liked 317 Times
My Rohloff and 2 SA drum brake IGHs, all have the shifter in the best possible place, on the TT near the front. ZERO chance of any kind of damage. I can shift with either hand. The cables have no flopping bits. I just cut a 7/8" tube and filed/ welded it to a piece of cut 1 1/8" frame tube. One hose clamp with some tape and rubber padding.
I just rode it 128.6 hilly miles, in 14.3 hours clock time. Getting quieter all the time now, 17,777 miles now. I also made a CF chain case. I really like mine with the EX box and nutted axles. Easy to clean. It's 44/ 16T now. Was 48T on the first tour and 46T on the second.
Likes For GamblerGORD53:
#82
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
In my community nobody knows what a Rohloff bike is. I have had several people ask where the battery is for my e-bike. They think it is a motor in the hub. I do not use a very good lock for that bike even though I have a lot more invested in that bike than in my titanium bike. But the titanium bike looks expensive, so that lock cost over $100.
#83
Quoted: 612 Post(s)
Liked 387 Times
Tourist in MSN I saw the closeup of your rear wheel and was wondering about how much oil seepage is normal before the Rohloff would need an overhaul and new seals. My Rohloff looks similar to yours after eight months since the oil change. I read some where that it is impossible to loose enough oil to do damage to the hub between oil changes, unless you do damage to it like a cracked hub shell.
Likes For Rick:
#84
Liked 1,452 Times
So, when you change the oil, if you put in all 25ml, eventually some of that leaks out of the seals, but that 8ml is still providing lubrication so don't worry about it. And Thorn suggests putting in 15ml instead of all 25ml so you get less leakage.
Thorn has also in some of their documentation suggested adding only 8ml in an oil change, but I have only seen that once and I do not recall where. Their video I think cites 15ml, so that is what I do.
The cleaning oil, I just use 15ml of that too. Several years ago I bought the 250ml bottles of both oils, so I have enough oil to last for a while. I ride several different bikes, so I never put enough miles on the Rohloff in one year to require more than one oil change annually.
If my EX box looks too dirty, I just use a paper towel to wipe the dirt and excess oil off. And I do not worry about lack of oil in the hub.
ADDENDUM:
I just looked at the photo of your bike, you have a disc brake on the rear. Since you really want to make sure you do not contaminate your disc pads with oil, you should probably wipe off any excess oil much more frequently than I do, as I do not need to worry about disc pads getting contaminated.
#85
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
I'm in the middle of a Rohloff oil change right now, bike is in the garage with the cleaning oil draining. I fill the hub with 15ml of oil, but I have never tried to use only 15ml of cleaning oil.
#86
Quoted: 612 Post(s)
Liked 387 Times
I am going largely by memory here, but Thorn has sold a lot of Rohloff hubs and has discussed a lot of details with Rohloff. And Thorn has said that when you first fill up a new Rohloff, you put in 25ml. When time for the first oil change, about 8ml will remain in the hub adhering to to all the internals. And when you use the cleaning oil, that also adheres to the internals.
ADDENDUM:
ADDENDUM:
#87
Quoted: 612 Post(s)
Liked 387 Times
#88
Liked 1,452 Times
I used a mountain bike tube, exact size I do not know. I think the sleeves are about 1 inch long. Two photos attached.
My downtube is slightly larger diameter than the top tube, I do not recall if I used the same size sleeves or not on both tubes.
#89
boy, only 25ml !
two tablespoons ish
I'm just really surprised that its so little, really surprised. I would have thought 250 or something, but I'm just coming from thinking of motorcycle oil capacities that did engine lubing, cooling, transmission and clutch lubing also.(wet clutches)
I also worked in photography for many years, so 25ml of something sure isnt very much. I mixed and calculated developers and everything for decades, so am used to using various graduated cylinders etc.
two tablespoons ish
#90
Liked 1,452 Times
boy, only 25ml !
two tablespoons ish
two tablespoons ish
Your motorcycles had more energy available from the engine to rotate the components against friction from the seals than on the Rohloff hub where there is not a great amount of excess power to fight seal friction, so the seals are rather leaky. (The seals however are more leaky on my vintage Triumph motorcycles,)
You do not pour the oil in, you use a syringe to inject it, the oil fill hole is plugged with an M5 screw.
Think of the most expensive cooking oil that a chef might use for an expensive dish, Rohloff oil probably costs more on a volume basis.
I bought the 250 ml bottles from Germany. Even with the shipping cost it was much cheaper than 25ml bottles each year in USA.
https://www.bike24.com/p2406748.html
#91
Some people refer to it as an oil bath, but it is more of a rinse, not an oil bath.
You could see how every so often, doing the "clean" or whatever with a different liquid could be good to remove any particles or buildup of stuff.
Didn't one of you mention this?
I've always read of how rohlofs quieten down after a certain number of kilometres, so it would stand to reason that there are teeny amounts of worn off material in there.
#92
Liked 1,452 Times
that explains it, I thought all the internals were immersed in oil, so why 25ml didn't make sense.
Hub is quieter with more distance, but the hub noise is only noticeable in gears 1-7, gear 7 is the loudest. There are three sets of planetary gears and when you are in gears 1-7, the third planetary gear system is used, that is not unlike using low range on a Jeep or 4X4 pickup truck.
I noticed on my Canadian Maritimes trip where I added the oil just before I started riding from Halifax, that the first several days the hub was quite quiet, but got steadily noisier for the first couple weeks. I am guessing that it took a couple weeks for the excess oil to have leaked out and once it was out, the noise returned. But it was still much quieter than when the hub was new.
I do not know if that graphic is an actual physical object that was photographed or an computer drawn rendition, but I think I see a bit of rust on part of one of the planetary systems, so I am inclined to think it is a photo.
#93
I'd be inclined to say photo also. I've done a certain amount of product photography, including jewelry and metallic and shiny surfaced objects, so the reflections etc look natural to my eye, although one never knows with cgi. I would say though that the tiny details of imperfections and discolouration on some splines seem to me to be a real object--I can't imagine that if this was cgi and for illustrative purposes, that joe blow graphis person would purposely put in wear marks etc.
Neat to see the innards.
#94
Quoted: 612 Post(s)
Liked 387 Times
I call the noise a new Rohloff hub makes in 7th gear the turbo squirrel cage. Mine has quieted down and I can't hear it in traffic anymore or am I going deaf. There are three hills on my exercise route that I end up in 1st gear. The first few times I was at 3.8mph at around 90rpm. This morning I made it up them at 4.2mph. When this happens my breathing is louder than the traffic. I only saw one Rohloff equipped bicycle in person prior to my purchasing one. I read about the hub for the first time on the web in Florida at a public library. When I went back to the library to read more about the Rohloff, the library had a watchdog program installed. I made a query about the Rohloff hub and the system thought that I was trying to access an anarchist web site and I had to get a librarian to reset the system so I could continue using the computer. I found a back door article by Sheldon Brown on the Rohloff hub.
Likes For fooferdoggie:
#96
Quoted: 612 Post(s)
Liked 387 Times
I have seen the video and looked at cargo ebikes with the electronic shift Rohloff. The cargo bike is what I need but they have to low of a weight limit. You can only have the electronic shifting with the Bosch motor. I am going to find an older non wimpafied Yuba Mundo and put a Schlumpf Mountain drive on it. I also intend to put the GMac motor kit on it. A geared motor with regen braking.
#97
Clark W. Griswold
Quoted: 4328 Post(s)
Liked 3,949 Times
My e-bike has a Rohloff E-14 is the absolute best. Such a nice easy shift and the auto down shift when you stop is so great. Plus it has got me riding to and from work nearly daily and doing more errands via bike.
Likes For veganbikes:
#98
Liked 1,452 Times
Someone on this forum has two Surly Trolls, one with Rohloff for commuting and one derailleur with S&S couplers for touring. I find that an interesting mix. If I was commuting I would be using derailleur, but perhaps my mix of hills and flat segments to where I used to work before retirement is quite different than his. Although the thieves in my community do not know what a Rohloff is, I would not commute on anything expensive, as where I used to work was a high bike theft area.
#99
Quoted: 612 Post(s)
Liked 387 Times
I am going to stay non-electric. But it sounds to me like you are using an e-bike were it is best used, for commuting. In my community the e-bikes are clogging up the multi-use paths and bike paths by people pretending that they are getting exercise when they coast up hills, you rarely see an e-bike on the street.
#100
Clark W. Griswold
Liked 3,949 Times
