3 week old Domane sl4 has bad shuddering when going over 13mph
Shuddering feeling at higher speeds on 3 week old Domane sl4
I bought a Domane three weeks ago and it has developed a shuddering (roughness) to the ride when I go anything above 13mph. It’s not necessarily specific to that speed, but it definitely occurs more the faster I go. I can feel it throughout my pedals/frame/handlebars and it occurs even when I’m not pedaling. If I peddle out of the saddle I can still feel it in the handlebars and peddles.
I ride 5-6 days a week on the same road and can vouch that the road is not this bumpy. Additionally, the shuddering is getting worse. It happens when I’m going uphill/downhill/even when I’m on flat surfaces. There is no play in the crankset or wheels.
I just took it to my local Trek shop and they acted like I was crazy. It is not a normal road-roughness vibration. This is like riding over rough pack dirt even though I’m on perfectly smooth tarmac.
My tires seem to be set properly and there is no noticeable disturbance in them all the way around. Wheels are true as well.
Does anyone have any thoughts as to what this could be?
Quoted: 283 Post(s)
Liked 262 Times
13 mph isn't high speed. It should ride like it's on rails from 0 - 40+ at least. Take it back to the dealer, don't accept anything other than a perfect bike. It's not right for you to diag / fix a new bike. Don't volunteer to fix anything yourself, you'll just let the dealer off the hook. It's their job, otherwise- who needs a dealer?
Likes For grizzly59:
Quoted: 965 Post(s)
Liked 1,629 Times
When I feel that in a car I suspect that the tires are separating. I had belts separating in one of my cars years ago even though the tires were brand new. (Discount Tire Co.)
But then again... Its a brand new bike... TAKE IT BACK!
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Check the IsoSpeed decouplers, especially the front one. Ah, technology...
https://www.youtube.com/watch?v=tDJ3...ature=youtu.be
Likes For Rolla:
Exactly! It feels like a broken belt on a tire. I told him that I thought it might be the tires and he said that they were seated properly so it couldn’t be.
Quoted: 965 Post(s)
Liked 1,629 Times
I have noticed recently more than a few posts about poor tire quality even in the more expensive tires. Not just ChiCom outlet tires but many tires brands made in the USA. I am not sure why...
Likes For zandoval:
Quoted: 252 Post(s)
Liked 67 Times
Do bike shops take bikes out for a test ride? Or are they so sure in their expertise that they consider that superfluous? Like hurting their professional judgement? Or maybe it is a policy that (bigger ones, dealeships etc) shops can't take bikes out for a road test unless maybe they have their own closed road? Like for insurance policy or something of that kind?
In my perhaps blessed ignorance, if I would be told that tires are seated properly and that it will not be them ... I would have asked them why not test it on a ride.
Guest
Liked 3,270 Times
Oh, please. Yes, shops test ride the bikes they build. At least mine does. But that doesn't mean that they can catch everything that a customer might experience three weeks after they buy it.
Expired Member
Quoted: 3670 Post(s)
Liked 5,422 Times
I suggest you return to the shop and show them what you described.
Quoted: 836 Post(s)
Liked 1,061 Times
I intend to go back tomorrow and have them put it on their shoulder and spin the crank. Maybe even grab one of the bikes on the showroom floor and do the same thing to show them that it shouldn’t be doing this. They are making me feel like I’m crazy for having this problem. Like I don’t know how a road bike should feel.
Likes For Tmintier:
Quoted: 252 Post(s)
Liked 67 Times
And it is one thing to test your build vs when someone returns with the purchased bike saying something is wrong with it like here, vibrations at speed.. In such a case, it warrants test riding it at some clip outside. And clearly the shop didn't do that ->
UPDATE: I picked the bike up from trek today. The service tech said he couldn’t replicate what I was describing and was unable to do anything more.
Did you see the movie Mummy? Where Eve says 'take that Bembridge scholars'
Guest
Liked 3,270 Times
This is different situation. The bike is not custom built in LBS but Domaine bike model from Trek, 3 weeks old. And the way I read it, the issue was present from the first day, even if it came to attention of the owner a week or two later. Yes, I can see that out of the factory shipping box assembly likely doesn't warrant test ride by the dealer/LBS, they probably spun the wheels at low rpms on the work stand only to see how it shifts gear.
You either need a new shop or to return the bike.
Quoted: 2338 Post(s)
Liked 2,822 Times
UPDATE: I picked the bike up from trek today. The service tech said he couldn’t replicate what I was describing and was unable to do anything more. I took it home with me and went on a 15 mile ride to see if i could narrow the problem. It was still doing it and was especially bad above 20mph, even when coasting. This led me to believe that it’s not the crank/gears or chain. I got off of it and hooked the seat over my shoulder so that I was facing the rear wheel and gave it a couple cranks of the pedals. Mostly I just wanted to watch the wheel spin and look for abnormalities but I noticed that when I get it to a higher rpm the whole bike oscillates as the wheel spins. It literally shakes me back and forth. I have my old road bike and did the same experience that on it and there is NO oscillation like that. So now I’m convinced that it’s something to do with the way the rear wheel is spinning.
Quoted: 850 Post(s)
Liked 344 Times
what you can do is look up how to balance a bike wheel online and tape small weights to the rim as a stopgap and see if that helps.
BTW: the gaslighting is par for the course. You're almost certainly not wrong. A bike is a simple mechanical object. If it doesn't feel right, something is probably wrong.
video:
Likes For smashndash:
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 428 Times
...okydohy, I'll head back over to the Classic & Vintage Asylum. I wish they'd quit letting me wander away.....
ciao!
What I think it could be is the spoke tension. Is it just the rear wheel? Have them check that wheel well and show them what you mean when you bring it in-store.
Does the rear wheel have a big, goofy reflector attached to the spokes? Those will easily cause an oscillation when spinning the rear wheel at high rpms. I doubt you’d feel that will riding, though (but I could be wrong).
The first thing that comes to my mind as the cause of your problem is loose headset bearings. The typical grab the front brake and rock the bike doesn’t always detect the tiny bit of looseness that can cause shuddering when braking on a disc brake bike. It sounds like your issue is always present, though, so yours might be really loose.
It could also be loose rear wheel bearings or a loose or otherwise improperly installed cassette.
Any shop that wants to blow you off immediately when you suggest there might be a problem is one that I’d avoid.
Likes For joejack951:
Quoted: 581 Post(s)
Liked 921 Times
All the talk of 'out of balance' wheels is a red herring. Bicycle wheels are never well balanced, but speeds are generally slow enough and the total amount of weight that is off balance is miniscule. It's enough to make a bike shake when lifted off the ground and free-spinning the wheels, but not enough to make a difference in how the bike rides at normal speeds. At 13mph it certainly wouldn't be a wheel balance issue.
Likes For ClydeClydeson:
Quoted: 6193 Post(s)
Liked 4,808 Times
Dry wheel bearing on one or more sides?
Those are probably sealed cartridge bearings aren't they? Might be fun figuring out if one or more didn't get grease at the factory.
Does the mechanic or some other shop person not ride the bike to duplicate the issue or see if they've really resolved it?
Quoted: 2482 Post(s)
Liked 2,952 Times
The oscillation of the wheel is all but meaningless, as Clyde Clydeson noted above. Almost all bike wheels will oscillate at higher speeds when the bike is on a bike stand or otherwise off the ground, but the effect is imperceptible while riding the bike. If it bothers you, it's easy to figure out where and how much weight to attach.
That said: before you bring the bike back to the shop where you purchased it, call them to make an appointment for a slow time of day when a mechanic or other employee can accompany you on a test ride with both your bike and a shop bike. The shop employee should be your size, so that you can swap bikes back and forth while diagnosing the problem.
By the way, even though you must be somewhat frustrated at this point, you'll get the best results by continuing to be polite with them (as you probably already know).
Likes For Trakhak:
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Well likely not the same thing, but remembered this thread: https://www.bikeforums.net/road-cycl...ble-crash.html
Likes For Sy Reene:
