What’s eating my fender?
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
Here’s a mystery. I installed Honjo fenders on my bike earlier this year. Occasionally when I went into the basement to retrieve my bike, I’d find some sticky oily film on them, almost like chain lube dripped on them. It was a little strange but I’d wipe it off and not think anything of it.
But a couple months ago, after not riding the bike for a while, I noticed this gunk on them again and wiped them off. But when I wiped it off it was too late—the substance had apparently damaged the aluminum, etching little lines in it. Now my fenders have these squiggly blemishes on them and I can’t get them out.
On the front they’re behind the fork, on the rear they’re in front of the seat stays.
What’s causing this? Excess Frame Saver dripping out of the frame? Could that damage aluminum? None of the other shiny AL parts on the bike are affected. FWIW I store the bike on a hook vertically, sometimes by the front wheel sometimes by the rear.
Randomhead
Liked 3,690 Times
That's weird. No idea what the substance is other than maybe framesaver? I wouldn't think framesaver would do that.
I recently found one of my socket wrenches had some clear film on it and it was gummed up. No idea how that happened, but it did seem to affect the chrome in one place.
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
It seems to me that most likely, whatever it is, leaving it there for a length of time is part of the problem. Maybe contact the makers of the fenders with a description and pictures.
Randomhead
Liked 3,690 Times
Are smooth honjos anodized? I think I would take one of the chemical polishing compounds to an inconspicuous spot and see if it gets rid of it.
Quoted: 6186 Post(s)
Liked 4,803 Times
Kids or grandkids loose in the basement? Sometimes when I was one of those and left unattended I liked to spray whatever I could find that was nearby on things and think I was making them shine or at least making them better.
Grandparents, aunts and uncles probably wondered what was all over the stuff I made look pretty too.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
Fender mites.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 213 Post(s)
Liked 93 Times
Also, this is a locked personal basement storage unit, no kids running around…
Quoted: 18369 Post(s)
Liked 4,507 Times
Hmmm.... any chance you got some road salt?
Quoted: 213 Post(s)
Liked 93 Times
Well, this only started in the summer so I doubt it…
So far my best guess is Framesaver, but I’d be surprised if that has a corrosive effect on aluminum.
Could it be radon or ozone or something else gross found in apartment basements?
EDIT: Or Gatorade???
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
Do you by any chance store any bases or acids in there? Chorine bleach, muriatic acid, industrial pure vinegar, car batteries?
Likes For andrewclaus:
Randomhead
Liked 3,690 Times
It appears to be products of corrosion. So sugar might do it.
Quoted: 6950 Post(s)
Liked 10,958 Times
While they are pretty fenders, they are also pretty effective, and they still work just as well to keep me and the bike clean when riding in lousy conditions.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
Looks like superficial corrosion of some sort. That's one reason I prefer hammered/textured mudguards over smooth, polished ones: the textured surface hides stuff like that.
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
What chain lube and how wet do you leave your chain when lubing?
Quoted: 213 Post(s)
Liked 93 Times
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Proximity to pool chemicals will do that.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
zombie flies reproducing on your fenders overnight?
this was my thought also. Last year I worked on a friends bike that had bad corrosion in places and it was from being kept in a shed with pool chemicals. Bike hardly ever used so it was clearly from the pool chemicals.
is your garage very humid also? Our garage can be humid and I've seen similar ish corrosion on things that sit there for a long time like a car hydraulic jack etc that is steel.
humidity compounded by in winter a car regularly dripping off lots of salty snow and slush, combined with poor ventilation.
re sweat, chain oil etc, it's not localized corrosion, and seems evenly spread around, which supports a general air thing gong on. Ive seen this also on other stuff in our garage too.
A drag for you though.
Oh, re excess frame saver. Ive only applied this to one frame, with little excess coming out afterwards, short term and long term, including riding the bike for months in very hot counties, but even then it seems to me that this product would actively stop any corrosion, not cause it....
