Pinarello Giro
Pinarello xxx: Help needed to identify a Pinarello
I need help to identify my bike.
So I bought this rather sorry looking, tatty old Pinarello frameset off ebay, I got it fairly cheap.
The seller believedt it is a Giro, which I can not find any information about, apart from an old ad from steel vintage dot com
Well, this was white, at some point. And a Pinarello. But that is pretty much it, comparing mine to the only one I can find.
If anyone cares to have a look this is my only reference:
Now. The seller claims my bike was made 93 or 94, as sort of a hommage for the wins by Franco Chioccioli. Fair enough.
Anyone know when this model ”Giro” was produced?
It has 130mm rear O.L.D which contradicts, by what I have learned so far - looking at different Pinarellos from the alleged 90’s era;
Campagnolo dropouts, front and rear.
Fully chromed fork with just the GPT pantogram at the top of the blades.
Some of the original decals were barely visible through the ”restauration paint” some previous owner sprayed with, it had PInarello on all 3 tubes, the 80’s font, that has slightly wider letters, with a little softer edges,
and another one on the chainstay. Or the other side, can’t remember which now, I removed all the paint from it.
Chainstay is chromed.
Furthermore, it has flush bottle cage mounts on the seat tube. Initially I thought someone made them in their garage, until I learned from this forum, it was quite normal.
Integrated rear brake cable routing, going in and out on top of the tube.
It did have the chrome Olympic head badge (sticker)
Double P logo sticker on the DT, just above the shifter bosses.
The rear brake mount is not the round tube, rather the sculpted one, with pinarello stamped across it.
Others have looked at the pictures and said it was one of the expensive models. Idk, I bought it vecause it is a Pinarello, and I have gathered a bit of a collectuon of them now. (4)
Until I can post pictures, I hope to attract the interest of an helpful expert.
oh yeah, the frame is a 58cm ctc, and I weighed it about 1940g. (Not entirely accurate, weighed on a kitchen scale. It is good for my wife, while baking cakes, but apparently not so good for weighing dirty old bike frames on) (when she caught me ”in the act”, all I could think was s-1) but she was cool.
No frame material sticker has survived. I could see remnants of glue, so I have an idea about where they sat.
Oh, and the cables run over, or under, the bb shell, there is a piece of metal to guide them, so they can wear out the last L in Pinarello.
the frame number is G4089, frame and fork.
I don’t doubt the seller, I only want confirmation, and I would be really pleased if I was shown a few photos of what the bike looked like when new, along with any other information. Spec sheets, correct decals, etc. Anything.
I am not rebuilding it to be fully original, I am going 18 speeds and ergolevers, and other Campy stuff, because it is what I have in the garage. Like a tasteful makeover, with custom paint and color scheme.
Much appriciate any advice.
Quoted: 1079 Post(s)
Liked 1,899 Times
If you can upload some pictures to your album, a friendly forum member will be able to post them for you.
There's not much Pinarello documentation available post 1990, so it gets a bit tricky identifying models and years.
There's this one on SVB: https://steel-vintage.com/pinarello-...ng-bike-detail
And another one: https://vintagevelore-cycling.com/pr...inarello-giro/
This is allegedly '94 with Columbus EL-OS tubing: https://www.carousell.sg/p/pinarello...94-1063509377/
130mm OLD sounds right, the 90's heralded the 8 speed era, which required 130mm spacing.
Likes For P!N20:
Quoted: 1639 Post(s)
Liked 829 Times
IIRC, Pinarello switched over to dropouts that had the Pinarello name stamped on it (Not Campagnolo), around 1988 or 89. Which leads me to think that your frameset might be older than what the former owner thought it to be. Maybe the rear triangle was cold set wider from 126 to 130?
So then. Which Pinarello was made by Oria ML 34 tubing, had integral brake cable, entry and exit on top of the tube, Campy dropouts, that Pinarello brake brace, and possibly 130 OLD?
Oh, and Pinarello stickers on all 3 main tubes, only one Pinarello signature decal, double P on the HT and another Pinarello decal opposite the chainstay?
Oria ML 34 points toward a Banesto Pinarello. which would be cool, in a way, since I already have a genuine pro team Paris.
But I wanted to, at last, have a Pinarello in my favourite color. Which is not white.
Likes For P!N20:
Liked 1,899 Times
More pictures here if anyone's interested: https://bikeforums.net/g/album/21873937
Certainly appears to be from the Banesto era. The serial number is in a different format than the 80's Pinarellos. A lot of the Banesto bikes had a fully chromed rear triangle - but I guess that doesn't mean there weren't some exceptions. Strange that the dropouts are stamped Campagnolo instead of Pinarello, but I guess it's a small detail.
Great frame, interested in seeing what you do to it.
Likes For P!N20:
Thanks! . Much appriciated.
Well I will put some love into it, and equip it with what matches the frame type, and my wallet. I.w. No carbon.
i havw gathered most of ehat I need. Just need to clean, polish and tlc everything, so they work as well as they did when new.
I need to order some stickers, I will go custom color on them. I will order replacements for what was on it, but the Oria stickers will be different. He doesn’t have the square stickers.
i will get then from cyclemondo.
Likes For Berko:
it will not be a standard Pinarello color, similar to what they have used, but with a personal twist. May as well, because I probably can’t ever sell the bike anyway. (It will be way too expensive)
Liked 829 Times
As for not having a fully chromed rear triangle. After 1988, the amount of chrome on Pinarellos seemed to have started to lessen, just like they had been for many othe bike manufacturers, so seeing less chrome on this early 90's bike is not really that unusual. My 1988 Montello has both a chromed fork and rear triangle. It was made pretty much when Pinarellos had the most chrome on them.
I'm guessing that they maybe just found a few left over Campy stamped dropouts in one of their frame parts bins and decided to use them up?
As for the amount of chrome, well I don’t know. Chrome isn’t especially expensive, so wether anyone uses more or less of it, isn’t really a budget breaker.
Look at all the Ching-Pow Knockoff anythings. Loads and loads of chrome. The more chrome one can see on any one of those products, when it is not needed, the further one should get away from them.
That’s way OT.
Anyone recognise this frame?
Liked 829 Times
could be. But a brand like Pinarello doesn’t strike as the ”let’s see what we can find in the scrap bin, and cobble them together” kind of a brand, does it?
That’s way OT.
That’s way OT.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Edumacator
Quoted: 2439 Post(s)
Liked 3,124 Times
I am looking forward to seeing the paint job!
Likes For jdawginsc:
Can’t decide. Black handlebar ok? There won’t be anything else black on the bike.
Oh, yes. I will fit Lugano 2 on it. I know they are not very good. I had them collecting dust, and they look the part, don’t they?
Dang it. Got the seat tube sticker a bit askew. What would you lot do? Tear it off (possibly along qith some paint) or pretend it didn’t happen and clearcoat the frame.
Not centered 100%
Chrome signature...
Liked 1,899 Times
Like the colour combo.
Likes For P!N20:
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
Funny, but the frame looks a lot like my Gavia. Course that’s TSX, no chrome fork and chrome on both chain stays. Lugs and BB cluster look identical though.
Misleading topic title, but I am not able to change it, Originally I did believe the claim it was a Giro, but I don’t think so anymore.
Someone here must know a lot more.
I only know it is no older than about 1994, since the frame and fork are made out of Oria ML34 tubing. (Original sticker on fork leg) Not many models of Pinarello were made of ML34. It is not a Banesto replica, What really throws me off is the fact it has Campy dropouts. Apparently Pinarello didn’t use them after 80 something. Must have been one hell of a parts bin scavenge hunt.
Doesn't look too bad from where I'm sitting, which probably means it's not going to be detected on the road. @onyerleft is right, plenty of crooked decals came out of the factory.
I wish I can present it properly when it is finished. It really is gorgeous.
The yellow is a metallic found on some Italian supercars. I believe it is called FLY, but my paint guy had it mixed so that it shifts towards blue, rather than green.
