What is this toe clip for?
Bikes: many
Quoted: 1444 Post(s)
Liked 1,390 Times
I received a package of miscellaneous toe clips in the mail today. Most are the typical kind. One pair is for Shimano aero pedals. One is completely new to me. What sort of pedal is the toe clip on the right for?
Bikes: many
Liked 1,390 Times
Great, thanks. I knew they wouldn't fit anything I have, but wanted to be able to describe them correctly when I sell them (along with several other more pedestrian toe clips).
Quoted: 1829 Post(s)
Liked 3,373 Times
Quoted: 1943 Post(s)
Liked 2,164 Times
While not Christophe, Sugino used a very similar one for their carbon pedals.
John
John
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Quoted: 188 Post(s)
Liked 997 Times
Ofmega Sintesi the pedal not the toeclip.
Quoted: 1106 Post(s)
Liked 1,326 Times
These have unusual dustcaps - they snap in; to remove them you use the setscrew in the end to bear against the end of the pedal axle, pushing the cap off. Ofmega also made a quill-pattern pedal that used these caps.
I could use some of those caps, if anyone has them extra....
Likes For oneclick:
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Well, whenever I walked fix I would not dream of not using clips.
Jim
Cross Check Nexus7, IRO Mark V, Trek 620 Nexus7, Karate Monkey half fat, IRO Model 19 fixed, Amp Research B3, Surly 1x1 half fat fixed, and more...
SB forever
SB forever
Quoted: 188 Post(s)
Liked 997 Times
Quoted: 1639 Post(s)
Liked 829 Times
Actually, the clips supplied on the Sintesi pedals were a little bit different from the Christophe. The toe clip strap loop at the top of the clip on those pedals had a riveted pivot that rides in a slot and allows for a bit of sided to side and fore and aft play to accomodate different sheo shapes and sizes. The Sintesi clips also had a satin black finish instead chrome, but maybe the re-branded Avocet version of the pedals did have chrome finish on their clips. The bottom anchoring slot design does look very similar to the CXC clip though.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: many
Liked 1,390 Times
Quoted: 1856 Post(s)
Liked 664 Times
I think the one with three holes may have been from the Shimano platform pedals from the early and mid'80s. I have the 600EX from my Trek 610 of 1984 and a 105 of similar vintage. If I recall, steel ones were for the 6xxx and 5xxx, while the 7xxx used an aluminum toeclip.
Liked 829 Times
Not sure which toe clips you were referring to with the term "those pedals." I inferred initially that you were referring to the clips for the Sintesi pedals, but after rereading a couple times, I'm not positive. In any case, note that the Christophe toe clip in my original post has a slot which allows the loop to move around.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
