Are there any pedals that sit low (below their axle)
Quoted: 19 Post(s)
Liked 9 Times
As a consequence of swapping to shorter cranks I have to raise my seat up. That means I can no longer reach the ground while on the saddle even with the tip of my feet. Now I wonder if I could swap to using pedals that have a deep ''sit'' so that at the bottom of my pedal stroke my leg extends more and at the up stroke have less bend in the leg. This would allow me to drop the saddle significantly.
If that doesnt exist I am thinking of going to really thin platform pedals and thin soled shoes. That will allow me to reduce saddle height a little bit, probably 2-3 cm compared to what I have now. But going to pedals that sit ''below'' their axle would result in much more reduction. Does something like this exist? If not, somebody should make em !
Quoted: 4273 Post(s)
Liked 4,712 Times
2-3 cm lower saddle???
Pedals sitting below their axle would be quite tricky to engineer! But you can certainly get pedals that have a low stack height compared to others. The variation between the highest and lowest is about 5 or 6 mm
OTOH, why would you touch the ground while you're on our seat (saddle)?
When I come to a stop (for example, at a red light) I some times keep my left foot on the pedal and lean my bike over a bit so I can hold myself up with my right foot on a curb. At other times, especially where there's no curb, I just stop my bike and move my body forward so I straddle the top tube.
Likes For philbob57:
Quoted: 1158 Post(s)
Liked 439 Times
The old Dura Ace Dyna Drive (DD) or “AX” pedals were a special axle-less design where the top of the rear cage crossed the centerline of what would be the axle.
This requires the matching crank arms that have an oversized 1” threaded bore. They were very clever engineering & some people that tried them thought they were cool (like me) but most thought they were awful. Sometimes they pop up on eBay @ decent prices. The double row bearings are housed inside that oversized pedal bore & they hold together when adjusted properly.
Likes For masi61:
Quoted: 19 Post(s)
Liked 9 Times
Thanks for the replies everyone. I did some more research. It seems these special pedals are called ''eccentric pedals''. I've decided on simply getting platform pedals since I've been wanting to return to them out of practical reasons.
Stack height is the word I was looking for yes. I currently use SPD SL and it feels my stack height is very high with the decathlon shoes and cleats. I can cut a significant chunk off my saddle height by going to thin platform pedals with thin soled shoes.
Does anyone have a good recommendation for a thin, wide and long platform pedal?
Liked 4,712 Times
The other factor is bottom bracket height. It varies a lot. With shorter cranks you can run a much lower BB. Sorry, that won't help on your current bike.
