I"m 70, drive iron regularly
Quoted: 11 Post(s)
have a lot fo muscle, but need to lose 60 lbs. how much biking can I expect to need to do per day or week? Thanks. I'm aware that the main thing is "pushaways" from the dinner table.
ignominious poltroon
Quoted: 2237 Post(s)
Liked 3,429 Times
Biking is good for cardiovascular workouts and burning calories, but you will have to simultaneously control calorie intake if you want to lose any weight. The problem, especially as we grow older, is doing this while preserving muscle mass, so a variety of complementary workouts will help more. If you can do 100 miles/week and not change your calorie intake, you can start to slowly drop a few pounds per month. If you can sustain that while significantly cutting intake, especially simple sugars, then you can probably drop a lot more.
Quoted: 4392 Post(s)
Liked 4,835 Times
You would be better off thinking more about how much biking you can realistically do per day or week. Obviously the more you do, the more calories you burn. But you are not going to realistically be able to ride more than maybe an hour or two per day as a beginner - and probably considerably less if you are unfit and overweight.
So I would say just start riding and see how much you can cope with. Along with a sensible diet, you will almost certainly lose weight in the long term.
Quoted: 1068 Post(s)
Liked 781 Times
helps to Include pumping iron i.e.- resistance weight training = more weight loss
https://theconversation.com/resistan...rn%20at%20rest.
Bikes: 1996 Trek 970 ZX Single Track 2x11
Quoted: 614 Post(s)
Liked 564 Times
Here's a guide that can provide a lot of ideas for various exercises to consider for workouts, particularly the gym and "floor" portions of your workouts.
https://darebee.com/filter#sort=posi...=cardio&page=1
The MuscleAndFitness website has a search/filter tool that can show a variety of suggested exercises and workouts. Can filter for type=cardio and difficulty, to narrow in on what might best suit you. Can then pick and choose the specific exercises or routines that might work with your schedule and equipment.
https://www.muscleandfitness.com/workout-routines/
Quoted: 536 Post(s)
Liked 464 Times
If you want to lose weight, the best way is to consume as much information about proper diet as possible. That new info will cause you to find a way that works best for you.
For me, intermittent fasting and low carb became my best strategy. I lost 160 lbs in 2 years after age 50. I lost approx. 8-12 lbs. per month.
There's no way to say how long it will take you. My best advice is to weigh every day, but don't be too concerned about 5 lbs either way. You can fluctuate that much each day. What you want is to track is the trend over 1-2 weeks whether you are slowly losing weight, staying the same, or even gaining, and adjust what you are doing accordingly.
