Stabilizing Bar Tape Plugs
Thread Killer
Quoted: 3129 Post(s)
Liked 1,698 Times
KustomCaps do be the dopest, tho.
I have a few sitting around…
KustomCaps bar end plugs
Supacaz bar end plugs
Ciclovation bar end plugs
Quoted: 4387 Post(s)
Liked 4,827 Times
I don't see the point in over-engineered bar end plugs. I just wrap the tape from bottom-up with 5 mm of overlap at the start, tuck it over and push the plastic plugs in that weigh 2.5g. Job done, move along.
Thread Killer
Liked 1,698 Times
For my part, I just don’t like having to worry about knocking one out when I’m shuffling my bikes around; I don’t have enough space for them all, I’m hasty and disorganized, and I’ve had it happen more than once. I don’t like having my tape come loose on a ride, I don’t like the hassle of buying new ones, and I definitely don’t like mismatched plugs, either. I’m definitely not the kind of guy who’s going to wind some electrical tape around the end and call it good, nor is a cork jammed in there going to do it for me, either.
For those reasons, I like secure plugs.
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
Just bought a pair of their BEPs and I don't think they expand at all - it's basically a machine screw that goes through a decorative cap and a rubber cork and then a simple threaded washer that holds it all together - don't see what would make the cork expand - the rubber cork is fairly fat and I think just a tight fit holds it in there .
Sunshine
Liked 7,473 Times
Again though, there is no right or wrong to any of this.
I like sugar skulls, so I have em on all my bar end plugs except the one with bar end shifters. It is absolutely an unnecessary cost. This is a hobby- almost everything any of us purchases is unnecessary.
Quoted: 18397 Post(s)
Liked 15,494 Times
I nearly learned that lesson the really hard way. Has to be one of the dumbest things I ever did while riding. I wish there were an EKG readout of that moment.
Likes For indyfabz:
Liked 4,827 Times
A nice bar end plug is an heirloom piece, maybe?
senior member
Thanks makes sense but without holding the washer don't see how turning the screw pulls the washer up and then ultimately expanding the cork ?/
senior member
I inserted my new adjustable ones and tightened the screw down expecting the rubber cork to eventually be tight against the inside of the bar and then not allow for any more tightening but I can still turn the screw making me wonder if that's normal or did I strip it ??
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1939 Post(s)
Liked 1,463 Times
You do not have to "tighten" the bolt in an expandable bar end like the other bolts on your bike. Treat the bolt in an expandable bar end as a means to adjust the extent of the expansion (like your derailleur limit screws), and "tighten" it to expand the expandable part just enough so that the bar end stays wedged in the end of your handlebar.
senior member
I do not have Kustom Kaps but I do have Cannondale expandable bar ends that are structurally similar to the Supercaz ones.
Quoted: 1814 Post(s)
Liked 923 Times
Yeah, they are spendy, particularly when considered you receive a pair of equally functional, expanding BEPS when you buy nice bar tapes like Supacaz or Ciclovation.
Kustomcaps= painfully heavy. They could market them as "weighted bar end plugs"
Liked 4,827 Times
Thread Killer
Liked 1,698 Times
Liked 4,827 Times
Likes For PeteHski:
Thread Killer
Liked 1,698 Times
Likes For chaadster:
Liked 1,463 Times
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,856 Times
You need the lighter handlebar to compensate for the heavy plugs. If you use the plastic ones that come with the tape, you can just use an aluminum bar.
Liked 923 Times
I use screw/wedge plugs at a weight penalty of ~16g- they stay put and eliminate the temptation to pound those stupid plastic ones back in while riding.
But I cut off the excess length of the screws to save a bit of weight, and they match the bar tape, since I care a little about that.
Wine corks. Easy to remove, yet they never fall out, plus they are light, require no hack with wrapping tape to make work correctly, and they are classy.
Thread Killer
Liked 1,698 Times
Jamming leftover bark chunks in your bars is not classy, it’s primitive and rather hobo-ish. I’ll accord credit if it’s a vintage bike from before the era of plastics, but if the bike is from the era of CNC machining, laser etching, anodizing, and 3D printing, then yeah, it’s just slumming.
Liked 1,463 Times
1. Do you use the whole cork or precut a certain length prior to insertion into handlebar?
2. How to remove? Does the cork come out when you remove the bar tape?
Likes For BCDrums:
Liked 1,463 Times
Thanks. Now I do feel a bit stupid for having asked that question. I am just to used to using this: Amazon.com: Monopol Westmark Germany Steel Two-Prong Cork Puller with Cover (Silver Satin): Wine Accessory Sets: Home & Kitchen
Likes For SoSmellyAir:
