Can all clincher wheels be set up tubeless?
Old 10-15-21, 05:25 AM
GBK233
Bikes: 2020 Giant Advanced 2, 2020 Giant Contend AR1
Quoted: 166 Post(s)
Liked 78 Times in 34 Posts
Scored a nice Fuji Cross 1.3 for $575. Going to use it as a wet road and/or winter bike. Oval Concept 327 clincher wheels. Can they be setup tubeless(taped and tubeless stem)?
GBK233 is offline
Old 10-15-21, 09:02 AM
Bald Paul
Bald Paul's Avatar
Quoted: 799 Post(s)
Liked 1,598 Times in 756 Posts
ROAD TUBELESS BREAKDOWN - READ THIS BEFORE YOU CONVERT TO TUBELESS - Road Bike Action
Bald Paul is offline
Old 10-15-21, 09:19 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Possibly. I wouldn’t do it with a road tire, but I have had good luck with “ghetto tubeless” for lower pressure CX tires.
caloso is offline
Old 10-15-21, 10:21 AM
WhyFi
WhyFi's Avatar
Quoted: 20791 Post(s)
Liked 9,435 Times in 4,663 Posts
Can all clinchers be set up tubeless? Safely? No.
Can those wheels be set up tubeless? Maybe. I'd even say "probably." Take the tires and tubes off and take a look at the rim bed profile. Compare to this -
WhyFi is offline
Likes For WhyFi:
Old 10-15-21, 10:54 AM
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
I'd go as far as to say there are many rims that are marked "tubeless ready" that are not safe for tubeless. See the following:
1) you need a bead shelf as mentioned
2) you need a bead lock or ridge. This means that you need to hear a BANG when you seat the TL tire and deflating it shouldn't result in the tire unseating.
3) you need the diameter to be correct. If the rim is undersized, the tire will burp in corners. To test for this, press in the sidewall of the tire while it's inflated with no sealant. If you hear a ton of air rushing out, it's a no-go.
you could correct this by adding layers of tape.
4) of course, you need TL tape assuming you have nipple holes. I would recommend going from wall to wall. Otherwise, you run the possibility of losing air/sealant through the tape.
smashndash is offline
Likes For smashndash:
