Leaking fluid from TL wheel
Quoted: 106 Post(s)
I refilled my tubeless tires with TL fluid. I do it every 6 months and this is the third time.
I noticed some fluid leaking through the spokes the first time I pumped air in.
I wonder if this is expected. Im afraid the tape may be leaking?
The tires seem to hold air as expected.
Expired Member
Quoted: 3629 Post(s)
Liked 5,297 Times
Sealant should not be coming out of the spoke holes. Your tape needs a do over.
Likes For shelbyfv:
Quoted: 20791 Post(s)
Liked 9,435 Times
Yup, re-tape. If you don't have any tape on hand, I'd recommend DT Swiss tubeless tape - you'll probably have to order it, but it's waaaaaaay nicer to install than anything typically available at the LBS.
