When do you switch to studded tires for the season?
Forecast is calling for a chance of rain next week with overnight lows in the mid 20's. I hate to ride with my Innova ice huskies on dry pavement if it it doesn't rain and freeze up...but then again if I encounter ice I'll wish I had them on. What is your criteria for deciding to switch over for the season? Snow? Freezing temps? It is warming up to the 40's-50's in the day here. Seems odd to run studs in the 50's but I guess that's what you do if its freezing at night. Forgot to mention I ride 6 miles to work at 5am.
Quoted: 4227 Post(s)
Liked 2,488 Times
I have few different wheelsets. Some with regular tires and some with winter/studded tires. I just folllow the weather forecast and then decide when to run studded tires. I prefer to run regular tires most of the time, and only use winter/studded tires when I feel it's neccessarry.
Bikes: Raleigh Grand Prix, Giant Innova, Nishiki Sebring, Trek 7.5FX
- Slim
Quoted: 52 Post(s)
Liked 17 Times
It's generally late November or December before I switch. Once we get a significant snowfall, a heavy dose of freezing rain or something like that. A little snow that sticks in the grass a bit but nowhere else I don't worry about.
Damp roads can end up with little thin icy patches on them in the mornings this time of year. I don't bother switching for that. I'll just ride more carefully.
Once the studs go on for the season, they pretty much stay on until late March or April.
Tawp Dawg
Bikes: '06 Surly Pugsley, '14 Surly Straggler, '88 Kuwahara Xtracycle, '10 Motobecane Outcast 29er, '?? Surly Cross Check (wife's), '00 Trek 4500 (wife's), '12 Windsor Oxford 3-speed (dogs')
Lucky that they plan ahead?
I've got two bikes to commute with now, so I've studs on one and regular tires on the other and ride which ever the conditions call for. When I only had one I would wait for persistent below freezing temps plus precipitation to mount studs; if it was below freezing but dry I wouldn't bother, just be careful around bridges and other known slick spots (it helps to ride the same route everyday, to more easily keep track of changing conditions). My lady puts studs on her bike at the first sign of ice; to each their own.
If I'm in doubt as to whether studs will be necessary the next day, I just give myself an extra 15 minutes in the morning in case I need to switch tires. Gives me something to do while the coffee seeps up into my brain.
In the right lane
ride for a change
Bikes: Surly Cross-check & Moonlander, Pivot Mach 429, Ted Wojcik Sof-Trac, Ridley Orion. Santa Cruz Stigmata
There's no reason studs have to go "on for the season" unless you live in a place where winter weather comes and stays.
Paul
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12767 Post(s)
Liked 7,678 Times
I just have one studded MTB tire, and plenty of front wheels to choose from. I'll probably mount it around Thnksgiving, then only use that wheel on snow/ice days.
cyclepath
Bikes: 2005 Trek Pilot 5.0, 2001 Specialized Sirrus Pro, Kona Lava Dome, Raleigh hardtail converted to commuter, 87 Takara steel road bike, 2008 Trek Soho
I'm another with multiple bikes with one wearing studs full time...use as needed.
"Without music, life would be a mistake."
-- Friedrich Nietzsche
You folks with a separate wheel set are lucky!
and just left them on it. it is an older rig I built up from older parts starting in the late 80's.
Nokian 106 stud 26" mount and ground W, tires . Tungsten steel studs, are what auto tires use.
Rigged casing , so they are still OK 20 years on.
early on Nokian shipped tire bundles direct, from Finland, this was before
the greater capital of the big distribution companies stepped in the game.
and took it away from the small shop.
