Decoding of Eddy Merckx frames
#576
Finally got my 10 posts so here! the photo album: https://imgur.com/a/u8OWvoT
edit: one more pic: https://imgur.com/a/95HlTBF
can you confirm what rear spacing this should be? i'm worried the frame is bent but it may be that the previous owner made the rear wider to fit a 130mm wheel. a buyer is coming probably tomorrow to have a look so i need to fix that in the right way...many thanks, much appreciated!
#577
The bicycle was brought to me from France.
I have seen some other post asking for info about an older EM frame (I think also from France) using just about this same gear as in mine.
I guess I will put it back rolling like this and later try to find a campagnolo period group set to "dress" it properly.
Thanks again for your help.
#578
Found this Corsa Extra for sale locally and became a little curious... Is anyone able to tell the approximate year and what the tubing might be?
https://photos.app.goo.gl/5L1TRUfy5pzTwMzu7
#580
First post so descriptions only unfortunately... A couple of years ago I picked up a green with yellow detail MX Leader. Pretty scratched and chipped original paint, with some surface rust, but I was looking for a project frame anyway. The guy I bought it from said it was a custom frame used by a semi-pro Belgium team at the time, I know the number hanger doesn't mean much, but the frame is 54/56, does this mean it is custom, i thought all the standard frames were square 54/54 or 56/56? The serial is L -- D 9551, with the L on its own on the left, so I paid particular attention to this post earlier in the thread:
A long, long time ago, the EMC factory in Meise was getting ready for the new season - 1994. It was the Belgian autumn of 1993, it may have been November, and it was the month in which the frames for professional teams was being built... Slightly earlier a frame was built (for sure) for Jan Schur (Motorola - D9563) and after about a week a frame for Frank Vandenbroucke (Lotto-Caloi - D9674) was built (also for sure).
So a frame built around the time of the two above, November 1993? The colour scheme is the green/yellow in the '94 brochure beside the Team Telekom.
There was a name on the frame that was scraped off...
Second frame is new to me: A -- D3586, size 54, dark blue original paint, doesn't have the MX-Leader fork, and has a pump peg instead of the number hanger. 'A' builder should be 'prototypes to B3000', how come I have 'D' series number? What year would this be?
#581
Quoted: 233 Post(s)
Liked 396 Times
L D9551 - Mx Leader had a "century geo", check the tables on BigSourcEMerCkx; the frame is from the same period as profi frames, but they didn't build "profi only" frames back then - anything is possible (I don't know of teams using this paint scheme)
A D3586 - built late summer 1992; "EMC worker" A markings also appear after "B3000", updated information in BigSourcEMerCkx
#582
Thanks, great information there. hours lost yesterday...
D3586 is a standard 55 - 55cm seat tube, 55.5cm top tube.
D9551 is definitely custom - 55cm seat tube, 57.5cm top tube.
Odd one- as you said, that colour combination wasn't used for a pro team, not a nice colour scheme, dark metallic green and bright yellow. It is a different colour now :-)
#583
Bikes: Colnago Super (panto) - Gios Professional (1st Generation C-Record) - Eddy Merckx Corsa Extra (Team USA) - Barellia Reynolds 531 - Fully chromed Columbus steel bike (Patelli?) Super Record Titanium
Quoted: 60 Post(s)
Liked 33 Times
My friend owns what we consider an early "Professional".
The frame number on the bottom bracket reads
"6." ("six dot") on the left and "749" on the right.
The seat stay caps have the signature on them. The fork crown has "Merckx" engraved.
Can you date it?
There is something unusual on the underside of the lower frame tube, a marking that reads "MPS - STC 06548" (?, sorry for the bad pictures). This marking is not engraved but raised, like Braille. What is that...?
Thank you very much in advance!
Can you date it?
#585
Quoted: 60 Post(s)
Liked 33 Times
I see... Thank you, Jacek!
#586
Quoted: 4511 Post(s)
Liked 6,378 Times
#587
Quoted: 233 Post(s)
Liked 396 Times
The idea behind the 'special editions' was to get rid of excess old steel tubing... in an elegant way
As 7-Eleven is a Corsa Extra frame, you should expect SLX or TSX (but I don't know for sure, I have never seen such a frame "from the inside")
Likes For CyclesMakaron:
#588
Liked 6,378 Times
Well unfortunately, I traded the 10th Anniversary TSX frame for the tribute frame from Steve at Millfield Velo without scrutinizing it inside as I should have (what was I thinking), should have looked it over good as I had to strip and pack it.
Maybe if I follow through with this you can help me figure it out, this gives me what I need for now, I assume you know some? of these have no tubing sticker as this one does not.
#591
Here we go with my recently purchase (campagnolo dropouts and reynolds 531 tubing). Profesional model from 1981 or 1982? @CyclesMakaron
#593
Hey,
I just got an EM in Motorola colors
Serial number
Left side. Drive Side
M Z9496
Following the serial number this should from end 87, but Motorola colors didnīt come until much later, no?
Also there is a columbus sticker with SLX and eyelet racer
Info in the steerer tube is
Z9496
TM
2p. chromé later
Maybe you can give me more information about this frame?
Thanks a lot!
Serial number
M Z9496
Z9496
TM
2p. chromé later
Thanks a lot!
#594
Quoted: 233 Post(s)
Liked 396 Times
Z9496 is a fall 1986 copy.
TM is a Motorola paint scheme
2p. chrome (p=pattern, chrome pattern)
later=information about repainting the frame at Merckx.
Not sure what model it is - no markings (M is EMC employee code)
What does the brake bridge look like -
"cube" or with Eddy Merckx lettering?
What do the lugs look like - with or without "cutouts"?
#595
Thanks for the info!
Lugs without cutout and brake bridge with Eddy Merckx lettering, like the silva one?
Brake cable routing inside the top tube, front and back coming in and out from above
And no graving close to the seatpost clamp...
Sorry I canīt upload pictures, otherwise would be easier...
Thanks again!
Thanks again!
#596
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times
Thanks again!
Thanks again!
#597
Liked 6,378 Times
#598
Quoted: 233 Post(s)
Liked 396 Times
Vito Moreno: Corsa Extra (95%) or Criterium (5%)
Look for other designations around M: X or CX
merziac: L7105 U06 475
Is it the Corsa Extra 7-Eleven limited series? from March 2006, number 91/100
#599
Liked 6,378 Times
So, you think SLX or TSX?
#600
Thanks a lot!
There is only an M in the left side.And also have an sticker of Columbus SLX, so, I think is an Corsa Extra
