Help! Suntour/sugino rd has no tension
Old 06-17-21, 06:24 PM
3dvvitch
Junior Wingnut
3dvvitch's Avatar
Bikes: 1988 Litespeed, some Lemond, Slingshot 650c, blah blah
Quoted: 24 Post(s)
Liked 16 Times in 8 Posts
HI folks, I just got this Sugino75 rd delivered, but having just now mounted it on a hanger it has no return tension (Velobase says that, mechanically, the Sugino75 rd is a mix between Superbe and Superbe Pro iirc).
How easy is it to replace the tension spring? Do I just need a spanner for those slots on either side of the mounting bolt? Will it be possible for me to find a replacement spring (assuming that's what it needs) - or should I try to initiate a return on this and find something else? Thanks!
EDIT: Now I'm confused- this diagram depicts the mounting bolt and not as not having any associated spring mechanism, just a washer. Am I crazy? Is that not supposed to be a sprung pivot point in this design?
Http://mauisvintage.blogspot.com/2010/08/suntour-superbe-pro-rear-derailleur.html?m=1
3dvvitch is offline
Old 06-17-21, 06:34 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2054 Post(s)
Liked 1,996 Times in 1,242 Posts
https://www.bikeforums.net/classic-v...nto-place.html
dedhed is offline
Old 06-17-21, 06:35 PM
DiegoFrogs
DiegoFrogs's Avatar
Bikes: '77 Centurion "Pro Tour"; '67 Carlton "The Flyer"; 1984 Ross MTB (stored at parents' house)
Quoted: 153 Post(s)
Liked 51 Times in 37 Posts
I've no experience with Superbe or Superbe Pro, but no Suntour I've ever had my hands on has had a sprung upper pivot.
I had to go and look - that assembly looks exactly like my ~1977 Cyclone GT.
DiegoFrogs is offline
Likes For DiegoFrogs:
Old 06-17-21, 06:38 PM
3dvvitch
Junior Wingnut
3dvvitch's Avatar
Quoted: 24 Post(s)
Ohhhh, I'm still a newbie with a lot of this stuff. I've never encountered a derailleur that lacked a sprung upper pivot.
https://early-titanium-archive.neocities.org
early_titanium87@aol.com
3dvvitch is offline
Old 06-17-21, 06:47 PM
DiegoFrogs
DiegoFrogs's Avatar
Quoted: 153 Post(s)
The B-screw is screwed into the upper knuckle of the derailleur. Under normal circumstances, the chain tension pulls that screw's end against the derailleur hanger's notch - it's free-moving. Later (I think) Shimano designs incorporate a sprung pivot there to allow the guide pulley to better track the cogs a bit.
In a way it's nice, though. With the wheel removed it's easy to move it out of the way by hand. It also simplifies it, and that function doesn't add much value on a friction shifting bike, anyway.
Old 06-17-21, 08:03 PM
steelbikeguy
steelbikeguy's Avatar
Quoted: 1204 Post(s)
Liked 1,433 Times in 729 Posts
I'm in the group that thinks there is no upper pivot spring in that derailleur. You should be able to unscrew that locknut on the back of the bolt and verify this.
I do have some later SunTour derailleurs that have sprung upper pivots, but they look different....
Steve in Peoria
steelbikeguy is offline
Old 06-18-21, 08:50 AM
Iniezione
Quoted: 25 Post(s)
Liked 4 Times in 3 Posts
It may not be the case here, but I had a Suntour derailleur that was shifting horribly. Return tension was almost non existent. After taking it apart, I discovered super hard grease inside around the spring. A good cleaning and fresh grease, and it was back to normal.
Iniezione is offline
