Fitting winter tires under fenders
Quoted: 48 Post(s)
I have a bike with 30 - 622 or 700 X 30C tires on it. The bike has fenders that sit close to the tires.
The problem is, that winter tires seem to have some more geometry on them and "expand" a bit more due to the grooves, etc. on the tire itself, compared to slicks, at least. This might make them touch the inside of the fenders.
I was told that I should use "28 inch tires on it instead", so that the tires don't touch the inside of the fenders. However, this doesn't make any sense to me. 28 inches, for what?
As far as I understand it:
30 - 622 means 30 mm tire width, 622 mm inner tire diameter.
700 X 30C means 700 mm tire diameter, 30 mm tire width, "C" is the width of the rim on a scale from A to D.
So if anything, I should perhaps reduce the width of the tire somewhat, and hope that it then has a slightly lower outermost diameter?
What should I go for? Would 28 mm seem like a good bet?
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Can you adjust the fenders to give you more clearance? If not, try some 28s. Several winter tires are available in that size.
Quoted: 4195 Post(s)
Liked 3,837 Times
the "28" is likely a tire width reference. Thus the suggestion of a narrower tire to gain fender/tire gap. Of course a narrower tire in wintery conditions is not what most here would prefer, generally a wider tire with a thicker/deeper tread is wanted.
My opinion is that you have now realized some of "the cost" of the choice of bike you bought. Can the bike better handle changing needs and conditions. Bike with minimal clearances (and a lot of other limiting or lacking aspects) are not as accommodating in future situations. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2026 Post(s)
Liked 1,095 Times
30-622 and 700 x 30C are two ways of describing exactly the same thing. 700c is an older name for what is defined as an ISO 622 rim size but the 700c nomenclature still persists. You were probably not told to get a "28-inch tire" but a 28mm wide tire, aka 28-622 or 700x28c. As Andy described the narrower and slightly smaller diameter 28mm tire will (maybe) give you a little more fender clearance.
Liked 1,095 Times
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Likes For ThermionicScott:
I hope this dude realizes this, as I commute daily in snow and slush and crap and a lot of stuff builds up on the tire. I used to use a 2.5 inch mtb knobby for winter commuting before I got studded tires, and the clearance was close with the suspension fork bridge thing, and sure enough, snow and ice and road grit would build up and wore away some of the fork bridge. No big deal as it was a small amount and the bike and fork are ancient, but still, it does happen, so be aware.
Quoted: 4792 Post(s)
Liked 3,918 Times
Or - get wide fenders that don't fit your bike, then carve them to fit. The Planet Bike fenders carve very nicely. (I don't like them for other reasons.) SKS and other hard plastic fenders need round inside corners to the cutouts so cracks don't start. Fenders can be cut at the brakes and River City ReacAround Fender Brackets used.
https://www.rivercitybicycles.com/pr.../?startrow=30h
Plastic fenders are pretty flexible when it comes to diameter so stretching them to fit a large tire usually isn't difficult - if you can get around the frame limitations. With those brackets and a willingness to cut where needed and use a little creativity, most bikes can be fendered up nicely.
