Choices
Old 05-23-23, 06:46 PM
DonMac
Choices
Looking at two bikes- Trek Domane and Specialized Roubaix. I’m leaning towards the models with electronic shifting in the $4,500.00 range. I’ve been riding mostly mountain bikes for many years but I have been road riding more as time goes on. I’m riding a Cannondale Synapse, aluminum frame but I would like something nicer. Mostly longer rides, not a racer.
Any thoughts on these bikes?
Don
Don
DonMac is offline
Old 05-23-23, 06:56 PM
bampilot06
Quoted: 10233 Post(s)
Liked 5,172 Times in 2,220 Posts
Don
Don
Both are great, buy the one that is your size and that you can actually test ride.
bampilot06 is offline
Likes For bampilot06:
Old 05-23-23, 07:10 PM
yaw
should be more popular
Bikes: 22 Emonda
Quoted: 201 Post(s)
Liked 167 Times in 84 Posts
If you already have an endurance frame that fits and is in good condition, with what I assume to be entry level parts, and want something that rides better on your longer rides, then you could also consider spending that same budget on upgrading the groupset, lighter and lower pressure tyre & wheel combo with wider internal width, premium carbon shell or 3D printed saddle for buzz damping/comfort, and perhaps even new bars and stem on your existing frame. That way you can source bits that suit your riding perfectly and very likely shave considerable weight to change the responsiveness of the bike.
My impression is that said bikes in that price range leave a lot to be desired in some of these component categories, which are ultimately critical to the way the bike feels and performs. I would give the components a go first and then if you still lust after a new frame for some reason, just buy the frame and pop your bits on it. It's not hard to beat the stock components at that price point if you are open to a bit of research and sourcing.
yaw is offline
Old 05-24-23, 08:45 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,780 Times in 3,298 Posts
It's really a toss up. But I'd think the Roubaix will be slightly more comfortable on long hauls since it will have more seat tube exposed that will buffer the shock from the road. And It has other active stuff for buffering road shocks too. Though I don't know how well that works for everyone.
Iride01 is online now
Likes For Iride01:
Old 05-24-23, 08:59 AM
Mojo31
Quoted: 9647 Post(s)
Liked 6,363 Times in 3,503 Posts
This. I have a Domane and love it. My wife tried the Domane and found the Roubaix fit more to her liking.
The Domane achieves seat post compliance through the IsoSpeed, and the Roubaix has more exposed seat post.
Similarly equipped, they are both very nice bikes, and it comes down to what you like better when perched atop it and pedaling.
Mojo31 is offline
Likes For Mojo31:
Old 05-24-23, 10:44 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3646 Post(s)
Liked 5,377 Times in 2,729 Posts
Depending on what brands your local shops carry, you might also look at the Cervelo Caledonia and the Cannondale Synapse Carbon. Both are available with 105 Di2 and both have moved to proper threaded bottom brackets.
shelbyfv is offline
Old 05-24-23, 11:04 AM
DirePenguin
DirePenguin's Avatar
Bikes: 2014 Trek 8.3 DS, 2022 Trek Domane SL5
Quoted: 31 Post(s)
Liked 34 Times in 25 Posts
I ride a ‘21 Domane SL5 (mech. 105) and I love it!
The wider (32mm), tubeless tires combined with the rear IsoSpeed smooths out even the roughest pavement.
And, the down-tube storage is really clever. I can fit everything I need for a ride (CO2, tire lever, emergency tube, multi tool, tubeless “repair“ kit, etc) except my iPhone!
DirePenguin is offline
Old 05-25-23, 04:22 PM
TiHabanero
Quoted: 1740 Post(s)
Liked 1,369 Times in 718 Posts
My son has a Domane and loves the ride, but wishes the ISOspeed rear end was not there. He has had to rebuild it once already and it is only 2 years old. Says outside of that it is a nice bike, but doesn't accelerate like his race bike does, but then he doesn't race on it.
Between the two my choice is the Domane simply based on my kids willingness to put up with the ISOspeed.
TiHabanero is offline
Old 05-25-23, 04:39 PM
Quoted: 18394 Post(s)
Liked 15,466 Times in 7,307 Posts
Before you buy, ask for 2 hr. test ride.
Likes For indyfabz:
Old 05-25-23, 05:06 PM
bampilot06
I have a 2022 madone and have never had any issues with the iso speed.
Old 05-26-23, 05:59 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4729 Post(s)
Liked 1,530 Times in 1,001 Posts
Aside from recommendation to test ride, it appears that at your pricepoint for electronic drivetrain, you're also deciding between 105 Di2 (Trek) or Rival AXS (Specialized)? I can't provide any thoughts here, aside from highlighting that ideally the test ride covers this as well.
FWIW, the closest pricepoint on Specialized's site to your $4500 is actually $5200, which is about $500 more than the Domane -- so I suppose this could be a factor as well.
Sy Reene is offline
Old 05-26-23, 07:09 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Surprisingly, above does not alert on ZeroGPT. Slick!Edit- referenced post has been disappeared.
shelbyfv is offline
Likes For shelbyfv:
Old 05-26-23, 07:50 AM
biker128pedal
biker128pedal's Avatar
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 265 Post(s)
Liked 447 Times in 266 Posts
I agree both are good choices. There are other brands too but local you get support.
I’d really test ride both not just for fit but to compare the shifting of the group sets. I’ve only ridden SRAM electronic on a Domane. I liked it but it was a Project One and out of my price range at the time. It was also 56cm and I wanted the taller head tube of a 58cm. I’m intrigued by the Shimano. I think the shifting can be tailored more. Test rides are fun.
biker128pedal is offline
Old 05-26-23, 08:14 AM
DonMac
Thanks for all the feedback. These two choices are available locally. I will definitely test ride both before committing. I’m looking to do a century late fall so it’s an important decision for sure.
Don
DonMac is offline
Old 05-26-23, 10:14 AM
Yeah. Clearly AI. Look at his last 5 posts, especially the timing.
Likes For indyfabz:
Old 06-01-23, 09:03 AM
ussprinceton
ussprinceton's Avatar
Bikes: '18 S-Works Tarmac (white letters), '18 S-Works Tarmac (black letters), '22 Allez Elite, '16 Emonda SL, '03 fuel100, '14 adventure3
Quoted: 114 Post(s)
Liked 82 Times in 66 Posts
I own Treks and Specialized bikes, so I am biased towards those companies. You can't go wrong on either 1. Since you can test ride them both, then obviously, choose the one that you like best.
ussprinceton is offline
