Aluminum handlebars feel different than Steel?
I don’t have that many protective devices on my single speed. Just a $20 Textro caliper.
Sometimes when I do hills I try to pedal like crazy on the way down to build speed for the next ascent.
Once in a while I’ll see gravel, debris, holes in the road ahead as I zoom down. If I use my brake to be cautious I’ll end up suffering on the ascent.
So I grab my trusty ugly steel handlebars with all my strength in case I lose stability. For some reason I remember aluminum felt “flexy”.
Is that my imagination? I have grown to trust these ugly steel handlebars. Rusty, but in my imagination, trustworthy.Got a new Origin 8 aluminum one sitting right here, its shiny and pretty, afraid to try it.
Location: '16 StumpJ, Salsa Mukluk, Soulcycles SS, Dean Colonel HT, BMC FourstrokeTrail, Dean Torres CX, Santana Visa Tandem, Trek T2000 Tandem, Cupertino MTB Tandem, FreeAgent26"Xtracycle, Dirt Drop Dingle, Jamis Dragon Dingle, Airborne Skyhag SS, SSDean Cols
Quoted: 70 Post(s)
Liked 116 Times
My daily commute is by single speed steel bike with steel Soma Eagle handlebars. All the other bikes I ride have either aluminum or carbon handlebars, and one has titanium handlebars..
Honestly I really can't feel any difference in the material.
In this order, the position, the bar shape, the grips, the tire pressure and tires, the fork, and then the frame have more influence on how it feels.
Of course there's a subjective effect of psychological dimension that is going to play a huge role as well. If you believe in your set up, it can work out nicely as well.
Corrosion, and stress, and abuse are serious considerations. In my life I've had two forks, one steel, and one aluminum fold underneath me. That has instilled a certain lack of trust in those materials. A carbon handlebar has failed from a crash as well.
I don't trust anything anymore. Nothing is trusty.
When I think about it, trusty sounds a lot like truthy.
Depending on the extent of the rust and the kind of riding you do the steel handlebar might be okay. But that fresh aluminum one sounds appealing. It is lighter.
I should have said a few rust spots. Well maybe someday I will stick the Origin 8 's on. But sometimes I get caught threading the needle pedaling uphill on a skinny 24 " wide bike lane, cars whizzing by you, ditch on the right side, and I am superstitiously attached to the steel ones, never lost control . I should add my point straight out 90 *, but the Origin 8's sweep back ,which I don't like.
Quoted: 586 Post(s)
Liked 612 Times
There are way too many variables to draw a black and white conclusion or comparison between aluminum and steel. Sure, there's the difference in the metals, but beyond that there's the way they are fabricated. With steel it begins with what type of steel it is and then whether it is butted, double-butted or whatever. Add in heat treating or not too. Same for aluminum, by the way. So drawing a true comparison will necessitate knowing all of the above so that you can make it a fair fight.
Most all of my handlebars are aluminum but I wouldn't hesitate to purchase steel bars so long as they were of high quality. I've been tempted to try some of the Bullmoose Bars that are out there, some of which are steel. All materials have limitations. There is no perfect material for handlebars as far as I know. Titanium is probably the closest we have. So finding the "right" bars for you boils down to trial-and-error mostly. It's very similar to the search for the "perfect" saddle. And what ends up being perfect for you is very subjective.
Likes For TugaDude:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I can feel a difference when I’m pulling hard in the drops. Aluminum bars flex more, and I vastly prefer them on both of my drop bar bikes.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I'm running carbon bars on my fixed gear. They feel about as flexy as aluminum. Am I crazy to believe that they won't fail catastrophically?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 763 Times
Flexibility has nothing to do with strength. As long as you use a proper stem meant for carbon bars and use a torque wrench to tighten the bolts, you should not have a problem. Stay away from cheap off brand carbon bars. BTW, aluminum bars can fail catastrophically as well. If you really want to be 100% safe, get a steel bar.
Likes For TejanoTrackie:
I have this thing about Carbon Fiber. I read about a guy who would do cross continent expeditions and he eschewed it. You could find a welder in any town in the middle of nowhere , but if it were carbon fiber, time to wait for the weekly bus or postal truck.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2606 Post(s)
Liked 3,119 Times
What's the diameter of your stem clamp? A modern 31.8 mm alloy bar is going to be a lot stiffer than an old school one.
"Your beauty is an aeroplane;
Veteran Racer
Liked 763 Times
Why is that ? The bar will be 22.2 mm or 23.8 mm beyond the clamping area either way. The only advantage of a larger clamping diameter is that the bar will be stronger and less likely to fail.
Likes For AJW2W11E:
Not actually Tmonk
Liked 3,119 Times
Good question, and I can't answer that. I had assumed that a larger stem clamp diameter meant more bar stiffness, but maybe that's not the case?
Veteran Racer
Liked 763 Times
Like I said, a larger clamp diameter simply means a stronger bar at the location of highest load. By increasing the bar diameter, you decrease the stress at that point, which increases the failure load. The bar deflects throughout its entire length, such that the flexibility will be the accumulated deflection under load. Therefore, a longer/wider bar will be more flexible than a shorter/narrower more compact one.
Not actually Tmonk
Liked 3,119 Times
gotcha, makes sense
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Cheap aluminum flexes. Sometimes it's intentional, othertimes it's just a cheap handlebar. If you don't want as flexy, get a heat treated Nitto or some nice 7075 alloy bars.
Veteran Racer
Liked 763 Times
Making bars from stronger or harder aluminum material does not make them stiffer (less flexible), it just makes them stronger and tougher. This is because the modulus of elasticity does not increase as the material gets stronger. The only way to make a handlebar stiffer is to use thicker tubing.
No one mentioned it yet, but heavier bars are going to make your steering feel different too, if your front end is twitchy steel bars might feel slightly more stable in that way...
( Well I better be honest. Theres a big descent before that hill where I build up steam for the climb. I time my descent so there are no cars in my mirror and pedal like hell on the way down. And drivers on that road are pretty considerate if they do come up alongside. )
Anyway I took my rusty steel handle bars and got all the paint of them and hit them with 600 grit. I primed them and sprayed them with aluminium colored spray paint and use autobody compound on them and now you can't tell the difference. Problem solved!
Quixote
Bikes: Bianchi Pista Concept 05, Level 2014
Quoted: 44 Post(s)
Liked 78 Times
I feel a difference between my steel deda veledroma (40cm ctc) and my nitto heat treated alloy adb - x (37cm ctc) when I climb hills and when I sprint - both are wonderful bars. it may be subjective but I feel a little more explosive at the beginning of a sprint with the steel but that could be the deepness or angle of the drop too, I'm not sure. With the steel bars I'm always on the ramps when I ascend a hill but with the shallower drops on the nitto alloy I can pretend to be a Marko Pantani(dream on) and spend a decent percent of my climbing in the drops. I recently added a sakae fx modolo (39cm ctc) to my collection - I have wanted a steel one of these old bars for some time and never found a way to justify the price of a used one from njs export. Anyway I saw this one come up nos on eBay and that's what I thought I was ordering but nope, surprise to me this one is alloy - and had a little sticker on the bags label that read 'crit' - I find this bar way too flexible for standing starts - big contrast to the first two Which feel super stiff to me. When I first took it for a ride I wondered if I had entirely wasted my money, but I experimented a bit and found that with a couple of spacers and a twisted forward flat ramp repositioning of the bars I could get pretty low,with both a relitively horizontal back and forearms if you know what I mean... so yeah I guess the point of this long rant is for me at least it depends.
Quixote
Quoted: 44 Post(s)
Liked 78 Times
Velodrama - I hate spellcheck.
By the way I should have mentioned the steel bar is 31.8mm stem clamp and the other two are 26mm.
Bars with larger clamping diameters can maintain their diameter until the drops if so designed, but it's rare to see a smaller clamp bar increasing its diameter, at least among round-profiled bars. I'd bet there was a correlation between clamp diameter and stiffness, even once removing cofounders relating to the modernity of the 31.8 diameter. That said, we agree that the larger clamp diameter per se wouldn't be the cause of the greater stiffness.
Veteran Racer
Liked 763 Times
Really ? In over 50 years I’ve never seen any like that. I’m not saying that they don’t exist, but I think it’s not a very common occurence.
We might be talking about different things. As an example, the bars on my fixed gear are the Ritchey Comp EvoCurve. They stay fat until the (second) curve that begins the fall into the drops: https://images.internetstores.de/products/487987/02/9004c3/Ritchey_Comp_Evo_Curve_Lenker___31_8_mm_hp_black[1920x1920].jpg?forceSize=false&forceAspectRatio=true&useTrim=true. Perhaps that design is rarer than I thought---you must have seen a lot of bars!
