Wiping Tires On A Fendered Bike
Quoted: 1924 Post(s)
Liked 1,954 Times
I believe that wiping my tires with my gloved or ungloved hand after riding through glass, seashells, or "flints" has prevented numerous flats over the years. When I have fenders installed, I get paranoid and often stop after riding through such debris to properly wipe my tires. If you believe as I do, how do you deal with fenders? Do you have "flint catchers" installed? Or do you stop and wipe as necessary?
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Easy way to test that belief: just stop wiping and see if punctures increase.
I inspect my tires once in a blue moon while a bike is on the stand, and occasionally there is a tiny little thing to dig out of the tread, but punctures are surprisingly infrequent despite the amount of crushed glass and other debris that shows up on my roads. I suspect that wide, low-pressure tires shrug off little sharp things better than narrow high-pressure tires.
Quoted: 2430 Post(s)
Liked 2,889 Times
I carefully wiped my tires from my first years of racing in the mid-1960s until the early 2000s, when I happened on Jobst Brandt's argument that it's pointless to do so. (Sheldon Brown, on the same page, says that he's dubious concerning Brandt's reasoning, but I was convinced.)
In any event, my experience over the decades has corroborated a wise observation by a fellow-racer in 1974: "It's not the ones you see that get you, it's the ones you don't see."
Likes For Trakhak:
Quoted: 2578 Post(s)
Liked 1,901 Times
Thankfully, I rarely have to deal with flints or seashells. Glass I try to avoid.
I take the approach that I'd rather risk finding a sharp piece of glass with my tire than with my hand, or with my face when something got stuck in my glove and I wiped my brow. But if you've got fenders and still want to wipe the tires, you'll have to continue to stop and wipe.
Likes For pdlamb:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
I still think it's loopy that anyone not doing a freestyle BMX stunt is reaching down into their tires.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Liked 1,954 Times
It's not that hard for me on most days. But I have trouble with the reaching under the fender trick.
Likes For gringomojado:
Likes For billridesbikes:
Liked 2,560 Times
Quoted: 347 Post(s)
Liked 418 Times
On vintage bikes these are called 'flint catchers' so you can sometimes find used ones, because of l'eroica probably, on the Italy Ebay site by searching for 'flint cacciatori pneumatico'.
Liked 2,560 Times
That's very sad indeed, it still looks like there are a few left on Jan's site.
Bikes: Trek Mtn Bike
Quoted: 280 Post(s)
Liked 2,603 Times
Don't wipe.. But often check for goatheads after riding off pavement here. Better to pull them out carefully than wipe. And sometimes it's better to leave them in til you get home.
The canals often have mussel(?) shells along the bank. Don't think they've been a problem.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 834 Post(s)
Liked 332 Times
This. For added inspection, deflate the tire first and pinch the sidewalls in every couple of inches to further expose cuts and embedded debris, I dig them out with a small pick.
Longbikes Slipstream
Likes For Wilbur Bud:
Likes For sweeks:
