No squeaky pads for Mafac brakes?
Old 05-24-21, 02:00 PM
polymorphself
Quoted: 837 Post(s)
Liked 1,080 Times in 521 Posts
What pads do you recommend for mafac brakes that have some toeing capability and less/no squeak?
polymorphself is offline
Old 05-24-21, 02:54 PM
bertinjim
bertinjim's Avatar
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1970s Carlton Kermesse, 1982 Peugeot PB 12
Quoted: 343 Post(s)
Liked 262 Times in 154 Posts
Mafac Pads
I use Kool Stop black pads in my brazed-on Mafac Competition's brake shoes. Very effective.
bertinjim is offline
Likes For bertinjim:
Old 05-24-21, 03:00 PM
polymorphself
Quoted: 837 Post(s)
Not sure I’m seeing them on their site.
Old 05-24-21, 03:13 PM
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Liked 1,237 Times in 686 Posts
Kool-Stop Mafac pads
Alternatively you could probably fit any type of stud-mounted cantilever pads or pad holders and get something with a lip.
JaccoW is offline
Old 05-24-21, 05:18 PM
BFisher
Quoted: 767 Post(s)
Liked 1,898 Times in 889 Posts
I've seen the Kool Stops available from several vendors over the years. Here's one: MAFAC Brake Pads
The trick I used to toe mine in on my since sold Peugeot was to use small narrow pieces of brass shim stock under the outside edge of the round spacer where the mounting post goes through the caliper arm. It allowed me to get them squeal free on a set of machined sidewall rims. You have to be a little careful with how you tighten it because that round spacer can crack. I had no issues with performance with that setup, and actually consider them to be about the best vintage brakes I have ever used.
BFisher is offline
Old 05-24-21, 06:05 PM
rando_couche
Quoted: 228 Post(s)
Liked 167 Times in 110 Posts
Red Kool Stops on my non-brazed-on Racers, and they "almost" never squeak. A large crescent wrench is very effective for toeing in MAFACs.
rando_couche is offline
Likes For rando_couche:
Old 05-24-21, 08:44 PM
fender1
fender1's Avatar
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times in 233 Posts
+1 on this
fender1 is offline
Old 05-25-21, 04:06 PM
Feldman
Quoted: 117 Post(s)
Liked 71 Times in 51 Posts
Non squeaky Mafac pads? Try the Kool Stop CX pad/holder; they use Shimano type road inserts. No squeal on my bikes!
Feldman is offline
Old 05-25-21, 04:18 PM
79pmooney
79pmooney's Avatar
Quoted: 4782 Post(s)
Liked 3,899 Times in 2,536 Posts
Like others here, I just use Koolstops. I don't even pay much attention to which ones.
Now in past years I actually liked the famous Mafac squeal, especially in hostile '70s Boston traffic. A motorist pulls a fast on on me? I would just hit the front brake extra hard. That would turn every pedestrian's head within a block. I point at the offending car. Eyes follow my point. Motorist is awakened from his stupor by the squeal, looks up, sees all eyes on him and slinks of like a guilty cat with its tail between its legs.
79pmooney is offline
Old 05-25-21, 04:40 PM
markk900
markk900's Avatar
Quoted: 478 Post(s)
Liked 634 Times in 336 Posts
Honestly the crescent wrench approach works wonders - I was just out on my CLB Racer equipped MB/Supercycle and the back brake squealed loudly. 30 seconds and a slight toe-in adjustment with the wrench and all was well. Its faster and easier to adjust than trying shims.
markk900 is offline
Old 05-25-21, 05:44 PM
satbuilder
Bikes: A few
Quoted: 289 Post(s)
Liked 195 Times in 102 Posts
Have heard of the Crescent wrench method. Has anyone ever written a description of the process with photos?
satbuilder is offline
Old 05-25-21, 07:18 PM
markk900
markk900's Avatar
Quoted: 478 Post(s)
Not really much to tell - set the wrench to the thickness of the slotted piece of the brake arm that holds the pad. Twist in the direction desired.....The real thing to bear in mind is its not a stuck stem - be firm and gentle, and go slowly. If you twist with all your might you may break something.
markk900 is offline
Likes For markk900:
Old 05-25-21, 07:19 PM
C9H13N
Bikes: Davidson ’81
Quoted: 120 Post(s)
Liked 229 Times in 121 Posts
https://www.parktool.com/blog/repair...-brake-service
C9H13N is offline
Likes For C9H13N:
Old 05-25-21, 08:44 PM
fliplap
Quoted: 97 Post(s)
Liked 328 Times in 105 Posts
Rene Herse sells Mafac specific toe-in washers just for this purpose. I suspect angled washers from old cantilever brakes would also work.
https://www.renehersecycles.com/shop...e-washer-pair/
fliplap is offline
Old 05-25-21, 09:36 PM
polymorphself
Quoted: 837 Post(s)
These the ones?
https://www.amazon.com/Kool-Stop-Bic...87256959&psc=1
