Tubular tire that will last longer than 300 miles
Quoted: 9 Post(s)
I have been running Tubular tires now for a couple years. Originally the tires I took off my Mavic Ksyrium SR wheelset where Vittoria Corsa CX 25/28 Pro Series. They where glued on and I cleaned up the glue (which took hours) and decided to go with Tufo High Composite 25.
I mostly went with the Tufo tires because I thought at the time they where the only ones I could tape on. I really do not have the patience to glue and from what I read if you tape them on correctly they seem to work okay.
Well, I am on my 3rd set of Tufo tires and all I can say is they don’t last me more than 300 miles, I have read that other people have complained about that. The Vittoria that I took off had close to 1000 miles on them, can a tire like that be taped?
My question is, anyone have any suggestions for a tire that will last longer than 300 miles and works fine taped on tubular wheelsets. I am 230 lbs and am riding a 2008 Trek madone 6.5. I am happy with taping the tires, and no plan on gluing anytime soon, thanks.
climber has-been
Quoted: 3416 Post(s)
Liked 3,543 Times
Curious to know, what led you to the decision to ride tubulars?
Ride, Rest, Repeat. ROUVY: terrymorse
Quoted: 9 Post(s)
I had issues with the wheelset I had with my bike, saw a set on craigslist and really didnt know what I was buying. Have considered going back to carbon with clinchers but stuff like that rarely goes up for sale in my area so the cost of going back really isnt an option.
In reality I would really love to have disc brakes. Cant stand friction type, always have hated them.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Oh man, where do I start? What exactly do you mean 'last longer than 300 miles'? Tread life? 300 miles before they puncture? ANY tire should get 3-4 times that in tread life. I have a TON of experience w/ tubulars. Used to work for a few pro teams and some of them raced only on tubulars. I've ridden and raced on them a TON. Probably installed more than 1500 over the last 25 years. I would NEVER tape a tire on. No pro team mechanic tapes tires...they're all glued. You don't need to remove glue every time you mount new tires if you're careful removing the old ones and they were glued properly. Lastly, Tufo tires suck. They're technically not 'tubulars' as there isn't a tube inside the tire. They butylize the inside of the casing. Most of their tires ride like crap and have poor traction. The good points...they're durable (unlike your experience) and tend to be incredibly round and straight. If you want to keep using those wheels I'd try something like Conti Sprinters. My best advice? Get some clinchers.
Likes For cxwrench:
Quoted: 8264 Post(s)
Liked 9,000 Times
300 miles? Even for me that would mean a new tire every 2 weeks. F that.
Likes For big john:
Quoted: 523 Post(s)
Liked 227 Times
I learned my lesson decades ago when I bought a Motobecane Le Champion road bike at a bike shop I worked in. Since I had the opportunity to choose any wheelset they carried, I chose to build a set with Phil Woods hubs and sew up tires. I took it on a tour with a group from the shop later that summer. Carried 2 spares and by the time I was back home after riding about 300 miles I had gone through both spares and patched the two I took off. I got a pair of clincher rims and rebuilt the wheels. It stayed that way until I finally gave the bike away about 5 years ago.
Bikes: 3 road steelys, 3 alu, 1 mtb, 1cx
Quoted: 20 Post(s)
Liked 22 Times
From my personal experience, conti sprinters always get me 1500 to 2000 miles rear
unless i get flinted. Also glue tapes are garbage, use conti alu glue on the alu
rims and give them a few hours of set up time before the first ride after gluing.
I weigh 70KG and ride with 100psi tire pressure. I have even worn up to threadbare
on the rear with conti sprinters, and then use that takeoff as a carry spare.
Amazing traction with those tires,and no, I do not rep conti.
Quoted: 1455 Post(s)
Liked 1,477 Times
I have an old set of tubular wheels that I used to use for CX racing. I still screw around with them once in a while, I've got a set of Donnely PDX tires glued on there that are probably 3 years old now - I rode these yesterday at the pump track with my kid. Glue job is still holding strong but I wouldn't trust them in a CX race or probably even out on the road. Back when I raced CX on tubulars, I was getting a new set glued on every season by a local shop. Challenge tubulars were my favorite - super cushy and grippy.
That said, I have no idea why in the year 2022 anyone not being paid to win bike races would ride tubular tires. Don't get me wrong, they're amazing, but not exactly easy to live with on a day-to-day basis. Tubeless gives me 90% of what I got out of tubulars with far less hassle and cost.
If getting only 300 miles on any tire something is wrong. As usual not nearly enough information to even guess what the problem might be. Instead a starting point for bashing tubulars one more time. Will also note that OP is talking third set of tires that only get 300 miles and this record of failure has taken years. So OP barely rides or barely rode these tires. And after total failure the same tire was used again. And again. I am not sure when Vittoria CX were discontinued, will just say it has been years since OP's good tubulars were last made. Current Vitt CG last longer. Of course Vittoria can be taped if you must be that way. At a self reported 230# 25mm tires are not going to work well and will not last. Vittoria makes the CG in 28 and 30mm.
Quoted: 504 Post(s)
Liked 637 Times
I rode tubulars for 30 years and depending on the tire got 1500 to 2000 miles out of them. In 1998 I switched to clinchers and have NEVER considered going back to tubulars. I get close to 4,000 miles out of Continental GP 5000 clinchers. You give no information about what kind of tire failure you are experiencing so it is impossible to comment but both from "standard knowledge" and personal experience with trying loaded touring on tubulars, I would not recommend tubulars to anyone who weighs more that 180 lbs or so.
Quoted: 9 Post(s)
Its getting so bad I look at the tires after every ride. Sometimes I see little divots or small cuts in the tire.
I have spent years on tracks with motorcycles so always checking equipment is the norm for me.
Someone has a used/almost new set of Tokyo Areo Carbon Epic 5.6 for sale on craigs for $399. I dont know enough about carbons but I am guessing these are not that great.
Quoted: 6178 Post(s)
Liked 4,795 Times
Do you skid it and keep the wheel locked up? That looks like more than just normal wear.
There was something I read one time long ago about the number of skid patches a tire could get, but I never did understand what that was about.
Likes For Iride01:
Quoted: 9 Post(s)
With friction brakes lock ups for me at least isnt as common as on my Disc braked Mtn Bike
Bikes: lots
Liked 2,932 Times
There is no way I will ever get below 180 lbs so that blows. This was one, and 3 others where instant blow outs, where I heard them pop and knew i needed to slow down quick. I have one new one on the bike and one that has a hundred or so miles on it.
Fixed gear skid patches...they vary depending on the size of the tire and the gear ratio you're using.
Quoted: 9 Post(s)
[QUOTE=Why didn't you mention that at the beginning of the thread?
[/QUOTE]
Because the original Vittoria I had on there lasted around 1000 miles and with the Tufo I have had the one in the photo, and 3 others Pop in a 300 mile range. I dont believe in coincidences when I have that many issues with Tufo, which everything I haver read on them is that they are supposed to be a long lasting, low performance tire.
[/QUOTE]
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 411 Post(s)
Liked 897 Times
I bought five Continental Giro tubulars on sale for the 4 tubular wheels I have, and I've been riding two of them off and on for awhile. They have removable Presta valve cores, so living here in Goatheadland, I put in a bottle of Stan's sealant. It works. So does either Tufo tape, or Jantex tape, which is quite a bit less expensive.
Thanks to the rim tape, removable valve cores, and modern sealant, sew-ups can be MUCH less hassle than they used to be. This is coming from someone who repaired and re-glued dozens of them, long ago.
For all the people who feel great bikes deserve to be ridden, so do great wheels...
Bikes: lots
Liked 2,932 Times
Just say no to tape. I have personally pushed a Conti right off a rim that was taped w/ Tufo. Tire had 100psi in it. If it worked you'd see every pro that still rides on tubulars riding on taped tires...mechanics would be all over it because it's such a time save. But here we are in reality land and there aren't any. Not a one. That says a lot to me. That and the hundreds of tubulars I've mounted and never had one roll.
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
I ride tubulars, have for years - not a commuter, not a racer. I have weighed up to 205#. I would suggest a 27+mm tire at your weight, but 25mm should also work OK. Continental Sprinter Gatorskins should be durable. Veloflex works for me, on sale.
Here is what I'm riding as of now.
Schwalbe One - 30mm - easily over 1000miles, tough as nails, not very supple when pumped hard, several years old so not sure it is the exact tire sold today.
Veloflex in both 25 & 27mm - these are my favorite tubular, buy them on sale @merlin UK. Good suppleless, good durability.
Vittoria Corsa 25mm almost as nice a ride as Veloflex, but only a few 100 MI on first set.
Challenge Elite in 25mm - less supple than the Vittoria, again = not enough miles to assess durability
Continental Sprinters in 22mm not supple at this width but excellent road feel and durability. New Sprinters also come in a wider 24/25mm.
The cheaper Continental Giros and Vittoria Rally have also graced my wheels
Specialized Turbo - 24mm race tire, great traction, short wear life.
Good luck in tubular world.
C&V has a Totally Tubular sticky thread. Ask there as well.
Oh - I have no experience with Tufo.
Quoted: 9 Post(s)
I have orange seal in the tires, the one that is for tubular tires. We have lots of goat heads here, but thats not what is causing it. More thank likely small sharp rocks on bike lanes blown off from the road, and my large framed 235 lb body. I was running these at 110 to 120 lbs.
Thanks, yours is probably the most informative reply and I will check into your recommendations. Pretty much my only choices are buy a new bike with Disc brakes (which I really really want) and carbon wheels, or put more money into this old bike, which probably wouldnt be the best choice.
I love the way I can take off with these tubulars. And being 235 with athletic build when at traffic lights its zero to top speed in a heart beat or so..
I’ve had the Vittoria Rubino G tubular tires (25mm) on my commuter/single speed and they have been rock solid so far. Not sure how many miles (definitely more than 500), but I put them on over the winter and they’ve rode like a champ on these very tough streets. I have a pair of Veloflex for when these wear out, but it might be some time for that.
I used tape for mine - not a fan of the messy glue.
Quoted: 581 Post(s)
Liked 921 Times
From the picture, that sure looks like user error. Or, as they say, 'a loose nut behind the wheel'.
Perhaps OP needs to work on their braking technique? Maybe they are primarily using the rear brake, which is much easier to lock up than when (more correctly) primarily using the front brake.
Quoted: 237 Post(s)
Liked 451 Times
Reads more like you ride on really crappy roads.
Are the punctures pinch flats or single hole punctures?
230lbs...what tire pressure do you run?
Are you a "snow plow" rider...hitting every pothole, road crack, etc. not riding "lightly" going over said obstacles results in many more flats for those that don't know how or don't bother to ride "lightly" regardless of weight.
You're likely better off on at least 28mm tires.
Veteran, Pacifist
Liked 4,829 Times
On the sealant, I ruined a couple of valves by having the sealant clog them up when the wheels sat un-used for a while (a given with my number of bikes). I now try to remember to keep valves at the top of the tire's rotation at the end of a ride. Not being in goathead territory, I have stopped using sealant as a preventative and carry a small amount on rides should it be needed.
These would be my recommendations for a buy today. $68, $48 and $56 respectively from Merlin.
27mm
Veloflex Protour Tubular Tyre - 700c | Merlin Cycles
30mm
Vittoria Corsa G+ Isotech Tubular Tyre - 700c | Merlin Cycles
25mm
Continental Sprinter Gatorskin Tubular Road Tyre - 700c | Merlin Cycles
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
Likes For genejockey:
