Rear hub area squeak only when pedalling backwards
Quoted: 31 Post(s)
Liked 13 Times
When I pedal normally, rear hub area sounds normal.
But... when I pedal backwards, I hear a squeaking noise from the rear hub/cassette area. Completely repeatable, on and off the bike. Bottom bracket area is not the source of the squeak -- it's definitely from the hub/cassette area.
Bike is ~10 years old with probably 15K miles on it, and these are the original (albeit sealed) hubs. The cassette and rear derailleur jockey wheels I changed last winter, so those are relatively new.
Thoughts?
Thoughts?
The wheel hub and its bearings won't be rotating if the bike isn't moving, so I'd suspect the noise is originating from your freehub/freewheel or its interface with the wheel hub or cassette.
Maybe take off the back wheel and see if you can recreate the noise by spinning the freehub/freewheel.
Quoted: 1819 Post(s)
Liked 1,693 Times
Thoughts?
Thoughts?
Quoted: 1438 Post(s)
Liked 1,092 Times
Bicycles are intended to be pedaled forward. If it does that OK I would advise leaving well enough alone. Never Fix A Running Piece.
Likes For dsbrantjr:
Quoted: 506 Post(s)
Liked 638 Times
Thoughts?
Thoughts?
Quoted: 31 Post(s)
Liked 13 Times
Sorry -- should have provided some more info. Bike is a 2011 or 2012 Trek 2.3 with Shimano 105 10-speed (5700 series) components. The rear wheel is the original Bontrager <something-or-other> (forgot the exact model), with the original hub, rim, and spokes. As I noted, I did replace the cassette, with a Shimano Ultegra CS-6700 12-30, but I did this in early 2021 and the drivetrain has not made this squeaking noise until just a week or two ago.
Quoted: 31 Post(s)
Liked 13 Times
Quoted: 31 Post(s)
Liked 13 Times
Oh, and no, I don't get the noise when I coast. I specifically have to pedal backwards to hear the noise. The chain is running smoothly, not skipping.
Quoted: 2482 Post(s)
Liked 2,952 Times
If you haven't lubed the chain lately, do so. That might be the source of the squeak.
Likes For Trakhak:
Likes For frogman:
