Gyroscopic effect of deeper front wheels?
Old 07-16-22, 12:22 AM
tFUnK
Quoted: 430 Post(s)
Liked 460 Times in 318 Posts
When I first went from a 38mm to a 60mm front wheel a few years ago, I recall feeling that the steering became heavy. At the time I attributed it to the aerodynamics (catching more wind). I switched back to the 38mm and that was that.
Today on a different bike I switched out my 32mm front to a 50mm front and felt the steering become noticeably heavier. But this was just a driveway spin at slow speeds, so I'm now thinking it's the added mass concentrated at the rim is introducing a gyroscopic effect. Does my physics check out? Anyone else notice this when going to a deeper front wheel?
tFUnK is offline
Old 07-16-22, 03:40 AM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2239 Post(s)
Liked 3,434 Times in 1,797 Posts
I've never tried a deep rim, but yes, your physics checks out. If you want to further test your hypothesis, fill your tube (or tire) with water. The result should be dramatic.
Polaris OBark is offline
Likes For Polaris OBark:
Old 07-16-22, 12:26 PM
RChung
Perceptual Dullard
Quoted: 918 Post(s)
Liked 1,149 Times in 491 Posts
How fast was your driveway spin?
You can check this by holding your front wheel in the air and turning the bars left and right, then spinning it as fast as you can and turning the bars left and right. I can spin my front wheel with my finger up to 3 or 4 revolutions per second. If the wheel has a circumference of 2m, that's something like 6 to 8 m/s, or maybe in the 15mph range, give or take. While it's spinning, is turning the bars easier, harder, or about the same as the wheel wasn't spinning? Is it easier, harder, or about the same as when you were in your driveway "at slow speed"?
RChung is offline
Likes For RChung:
Old 07-16-22, 08:32 PM
xroadcharlie
Bikes: 2018 Giant Sedona
Quoted: 183 Post(s)
Liked 116 Times in 95 Posts
I understand stand the principle of a gyroscope. Keep in mind a smaller tire will spin faster then a large one at the same speed thereby increasing the gryo effect. Which is one reason I believe it has much less effect on a bikes steering then the bikes geometry, like head tube angle, fork rake and trail. My comfort bike has twitchy steering and it doesen't get better with speed even with heavy 2" wide tires. I swapped bikes with a friend's cruiser bike that was much more stable thanks to a more relaxed geometry.
It should be noted that a taller tire will change the geometry slightly, and that might have an effect on steering when combined with more rubber on the road with a wider tire.
xroadcharlie is offline
Old 07-16-22, 10:48 PM
tFUnK
Quoted: 430 Post(s)
Good discussion here. I'm glad my physics checks out. Just surprised at how noticeable the effect was going from a 32mm or 38 mm front wheel to a 50mm or 60mm front wheel. When I say the steering felt heavy, I mean I actually felt what I can only describe as resistance, not that the steering was too slow. I am curious if anyone riding 50mm+ front wheels experienced anything similar? I imagine the pro peloton routinely ride 40-60mm fronts, and it's obviously no issue for them. And yes, I am conflating wheel depth with mass here, but I think we can accept that the two are correlated.
tFUnK is offline
Old 07-16-22, 11:41 PM
base2
I am potato.
base2's Avatar
Quoted: 1789 Post(s)
Liked 1,629 Times in 933 Posts
The two are definitely related. The force input to a gyroscope exits the gyroscope 90degrees away. Thats why when you turn your bars at approxamately horizontal, the bike leans one way or the other (perpendicular to the direction of rotation.) The more mass/higher the rotation, the more pronounced the effect, the heavier the resistance to input.
"Counter steering" is the conventional term for utilizing this emergent property.
base2 is offline
Old 07-17-22, 06:34 PM
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4387 Post(s)
Liked 3,016 Times in 1,865 Posts
Not so fast. If your deep section rims are heavier than the ones you replaced, then you'll probably get more of a gyroscopic effect. But as some of that mass is at a smaller radial distance from the hub, it's gyroscopic effect is not as pronounced than would be the case if they weight were at the circumference. If you were to replace those original rims with rims with the same weight as your deep sectin set, but which had the same profile as the original (i.e., a cheaper set of wheels), the gyroscopic effect would be greater than the deep section wheels.
In fewer words, the deep section wheels only add a gyroscopic effect insofar as they might be heavier than the shallow section wheels. Further, heavy shallow section wheels have the greatest gyroscopic effect because of their mass distribution.
I think the "heavy" steering of deep section wheels is more likely owing to the aerodynamic effects of moving more air around as the wheels rotate to the side, rather than owing to a gyroscopic effect.
MinnMan is offline
Likes For MinnMan:
