Canti Mounts - What are they good for if you are not using them?
Old 08-12-22, 08:32 AM
bebikecentric
First time poster. My stoker and I have been riding a budge tandem for 3 years and want to move up a notch in quality. I'm thinking of buying a used Cannondale MT800. It has both disc and canti mounts and is using the disc mounts for braking. Are the canti mounts good for anything else? I don't like the look of them on the frame and if there is no use for them, can they be taken off?
Thanks in advance!
bebikecentric is offline
Old 08-12-22, 08:40 AM
base2
I am potato.
base2's Avatar
Quoted: 1782 Post(s)
Liked 1,620 Times in 926 Posts
https://duckduckgo.com/?q=sunlite+ca...ages&ia=images
Car dependency is a tax.
base2 is offline
Old 08-12-22, 08:45 AM
Steve B.
Quoted: 3221 Post(s)
Liked 2,043 Times in 1,169 Posts
It's merely a design feature from the frame manufacturer to allow the use of canti's as desired by the end user. Not everyone wants disc brakes, this gives you an option. If you really object to the look, consider a different frame designed only for disc brakes.
Steve B. is offline
Old 08-13-22, 01:47 AM
bwebel
Quoted: 42 Post(s)
Liked 10 Times in 8 Posts
I'm not sure about the MT800, but some of the 'dales had removable posts for the canti brakes so at least you didn't have them sticking out, even if there were still holes where they screwed in.
You probably could mount lights on them as well.
bwebel is offline
Old 08-13-22, 06:16 AM
Juke41
Quoted: 17 Post(s)
Liked 19 Times in 8 Posts
It would be wise not to shave them off completely, it is a very robust weld and you risk weakening the seat stays / forks if you remove them.
I made a feature on my Cannondale , machined some aluminium and inserted some reflectors
Juke41 is offline
Likes For Juke41:
Old 08-13-22, 06:49 AM
BobbyG
BobbyG's Avatar
Quoted: 1362 Post(s)
Liked 1,674 Times in 827 Posts
There are some nice porteur racks that mount on the canti bosses.
BobbyG is offline
Likes For BobbyG:
Old 08-13-22, 08:11 PM
bebikecentric
What model is your tandem? Looks amazing!
Old 08-13-22, 08:29 PM
RB1-luvr
I don't know.
RB1-luvr's Avatar
Quoted: 314 Post(s)
Liked 850 Times in 444 Posts
tandems have never impressed me until I saw that C'dale. That's a beaut.
RB1-luvr is offline
Old 08-14-22, 08:23 PM
jccaclimber
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times in 108 Posts
While I understand it's become much less common as disc brakes have improved, leaving rear canti posts leaves you the option of running cantis or v-brakes and an Arai drum should you ever choose to.
They do make convenient mounting points as has already been noted.
jccaclimber is offline
Old 08-15-22, 05:42 AM
bebikecentric
How did you get your mounts to point horizontal? The look reminds me of a '57 Chevy. Very cool.
Old 08-22-22, 07:11 AM
Juke41
Quoted: 17 Post(s)
Hi, The Cannondale is a 2000 model, I swapped out the raked forks for a set of Fatty forks so I could use disks all round.
On the reflector mounts, I removed the studs and on the rear used some aluminium bar, cut at an angle so it would be horizontal, centre drilled and threaded it so I could screw the reflectors in, same with the fronts, except I used square bar.
Would have liked to have lights in there but my knowledge of electrics and the fear it would be a little unsightly put me off
Juke41 is offline
Old 08-27-22, 11:03 PM
sapporoguy
sapporoguy's Avatar
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times in 41 Posts
We use our canti mounts on the rear for a second set of brakes as a backup for the disc. The stoker controls the V-brake, pilot controls the disc.
You can also attach a Velogical rim dynamo to a canti mount, front or rear.
sapporoguy is offline
Likes For sapporoguy:
