Motobecane Gran Turismo equivalent
Hello All-I bought a Motobecane Gran Turismo hybrid/touring bike from Bikes Direct in 2011. I toured all over with it. It was my baby. It was stolen 3 months ago. Bikes Direct discontinued that bike a couple of years ago so I’m trying to find an equivalent to that bike. I would love any help with this. I miss my baby!
I took a screenshot of the Gran Turismo specs but they won’t let me post it yet so I copied and pasted the specs.
Main Frame-Motobecane custom butted 4130 Cro-Moly, Double water bottle mounts
Rear Triangle-Motobecane custom tapered Cro-Moly with forged dropout, Spare spoke holder, rack mounts, 130mm rear spacing
Fork- Motobecane custom tapered Cro-Moly, front Rack Brazeons, drop-out eyelets
Crankset SUGINO XD-600T, 28T(ALLOY SILVER), 38T(ALLOY SILVER), 48T(ALLOY SILVER), ALLOY CRANK, FOR SQUARE BB, W/BB BOLT W/170mm Alloy Silver Cranks, W/Cap Bolts
Bottom Bracket-Shimano CARTRIDGE BOTTOM BRACKET, BB-UN26 AXLE:LL113, SHELL:BSA 68MM, W/O FIXING BOLT
Pedals-WELLGO LU-908A 9/16" BORON AXLE, ALLOY SLV BODY, ALLOY BLK CAGE, W/ CLIP 43/49:M SIZE,54/58/64:L SIZE AND BLACK STRAP
Front Derailleur-Shimano Sora, clamp-on, 31.8mm
Rear Derailleur-Shimano Deore XT, 9-speed, Rapidrise (LowNormal)
Shifters-Shimano SHIFTING LEVER BAR END TYPE, DURA ACE SL-BS77
Cassette/Freewheel Shimano CS-HG50-9, 11-13-15-17-20-23-26-30-34T
Chain-KMC Z-9000 1/2"*11/128
Front Hub-Vuelta Sealed Alloy Road, 36H
Rear Hub- Vuelta Sealed Bearing Freehub 36H, 130mm rear spacing
Spokes- Stainless, 14g
Rims-Vuelta FRONT/REAR,F:36H.3X,R:36H.3X TOURING, W/O EYELET,CNC SIDEWALL
Tires-Kenda Eurotrek, 700 x 32c, presta valve tubes
Brake Set-Tektro Oryx Cantilever, TEKTRO 992AG F&R, CARTRIDGE PADS
Brake Levers-TEKTRO RL340
Headset- 1" W/SEALED ψ26.4 CROWN CONE
Handlebar- 6061 Butted Road, Anatomical Drops
43/49/54:420W,56/58:440W,64:460W
Stem-Motobecane Superlight Road Aluminum, 1" Removable Clamp
EXT: 43/49*90mm,54/56/58/64*100mm, QUILL 150mm, 0 DEG
Tape/Grip-Motobecane custom cork wrap Black
Saddle-Motobecane Sport "Comfort Cut-out" Touring
Seat Post- Superlite Micro Adjust alloy, 250mm X 27.2mm
Seat Clamp- New Motobecane Ultralite alloy, Lazer etched
aka Timi
Check out the Bianchi Volpe Classic
The theft of a beloved bike is a real kicker isn't it? I'm sure you've started looking at options, and there are less triple equipped touring bikes out there now.
I remember the gran Turismo but was always confused why they went with a road triple and not smaller chain rings.
The Kona sutra is still made I believe, but what have you found?
What market are you in, North America?
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
If you find a used Windsor Tourist, It was similar, 'cept it had STI shifters instead of bar ends. Seems like it's becoming to find bikes that come with 36 hole touring wheels. At bikes direct, they had to really downspec their newer bikes to get them into the price point they are trying to hit. Fuji had/ has? a similar touring bike.
Miles to Go
Drag... I lost my beloved LHT to bike theft last year. Although not a direct replacement for your bike, you might consider a LHT or the bike I replaced it with.. the Fuji Touring. Both are steel triples with bar end shifters. Both have disc brakes, or you can get rim of you shop used.
And that makes me a little nervous. Is it worth it still for a touring bike?
Bikes: 1979 Trek 412, 2011 Dawes Ultra Galaxy
Quoted: 17 Post(s)
Liked 58 Times
Sorry to hear about the theft. Most all bike owners have experienced it at some point. Not that it helps, but we feel your pain.
Check out the Bombtrack Arise Tour... https://www.bombtrack.com/complete-bikes/arise-tour
This is the one I'd go for... cheers!
