What kind of nipples should I get?
Quoted: 206 Post(s)
Liked 38 Times
Got 2mm (on the thread end) DT Swiss Alpine III spokes to go on a Sun Rhyno Lite rim with spoke eyelets. Is there a particular kind of nipple I should look for with this kind of rim?
Thanks!
Thanks!
Liked 2,941 Times
brass seems to be the better option.
giggity
giggity
-Oh Hey!
-Oh Hey!
Likes For Troul:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Brass. Always.
Likes For Cyclist0108:
Clark W. Griswold
Quoted: 4328 Post(s)
Liked 3,949 Times
Another vote for brass. I like the Sapim SecureLock nipples but the DT Swiss ProLocks would probably also work.
Likes For veganbikes:
Quoted: 1079 Post(s)
Liked 1,017 Times
Those spokes and that rim sounds like it should be a brass nipple build.
Likes For Russ Roth:
Likes For dsbrantjr:
Quoted: 6934 Post(s)
Liked 10,936 Times
Six posts so far, and nothing salty.
I'm disappointed.
I'm disappointed.
Likes For Koyote:
Alloy. BUT..... only if (1) you are sure that they were built by a quality builder and (2) you are fairly adept yourself at truing wheels and won't do anything stupid if you need to tweak them. But brass is a common sense, practical answer that you can't go wrong with.
Pierced, with a modest 1 cm hoop attached. Other option is studded.
Likes For Rogerogeroge:
Occam's Rotor
Liked 2,331 Times
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Have you already bought the spokes? Then some 12mm brass nipples.
For an ultra-paranoid build there are Pillar DSN (double square) nipples, they require a bit longer spokes, but the threads are made so that the spoke goes further in: https://www.pillarspoke.com/external-nipple
This is supposed to reduce nipple breakage.
Likes For csport:
Quoted: 1188 Post(s)
Liked 1,154 Times
Sapim Polyax seem alright.
But the last set of Rhynolite XL I built with Alpine III I just used standard DT Swiss Nipples, but you could use the brass Pro nipples, they have a similar round head to the Polyax.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Do the future owner of the wheel a favor. Skip the aluminum and go straight to brass. He or she will thank you (one day).
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,198 Times
My personal favorites are Wheel Fanatyk splined. Lots of colors like aluminum but without the problems that square aluminum can have. Square brass is okay but only if you want silver or black, although black may be more difficult to get.
The other advantage of using splined spoke nipples is that they don’t slip while building. Square spoke wrenches are prone to slippage especially at higher tensions. Since splines nipples have more point of engagement, they are easier to turn at high tension. If you insist on square nipples, in either brass or aluminum, do your self a favor and get a Park SW-42 spoke wrench. It doesn’t have as many engagement points as splined nipples do but they are better then the more open spoke wrenches.
Stuart Black
Stuart Black
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1233 Post(s)
Liked 317 Times
Get DT Swiss Prolock, which are brass. They don't need any magic goofball prep. And will NEVER unravel, very important.
I have these on all 5 of my DIY builds on my custom heavyweight tour bike and an old CCM, all with Dyad rims.
IMO they soften the stresses. My front wheel is a SA XL-FDD dyno drum with 27,000 miles. Good as new after 2 tours on a 120 lb bike.
Clark W. Griswold
Liked 3,949 Times
Because I use Sapim on most of my wheel builds and find to to be a really quality product and one of my favorite wheel builders who actually did my touring bike wheels fully endorses Sapim and those wheels have been flawless.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Quoted: 145 Post(s)
Liked 35 Times
Stick with brass.
=8-|
Disclaimer:
Disclaimer:
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4334 Post(s)
Liked 2,977 Times
Likes For DiabloScott:
Likes For Skulking:
Quoted: 145 Post(s)
Liked 35 Times
Disclaimer:
Disclaimer:
Liked 1,154 Times
And putting aluminium nipples on Alpine III spokes with Rhynolite Rims is kind of like putting alloy rims on a tractor. Yeah, it'll save weight, but what's the point?
