How High Maintenance are Tubeless Tires Anyway?
Quoted: 4384 Post(s)
Liked 4,824 Times
I am also investigating tubeless and have seen the youtube videos of trying to seat the tire with/without compressor. But what about the other question - can you re-seat the tubeless tire out in the field without the possibility of needing a compressor? Or does adding a tube remove that issue?
1. Stop by the roadside
2. Locate the hole (easy enough with fluorescent pink Muc-off sealant oozing out!)
3. Put my thumb over the hole to temporarily seal it
4. Take out my Dynaplug Racer repair tool with my other hand (always keep this to hand in a jersey pocket)
5. Fire in a Dynaplug (actually needed 2 in this case to fill the extra large hole)
6. Spin the wheel by hand to encourage sealant to seal the plug
7. Top up lost air pressure (It had lost about half its pressure by that point)
Then just ride on as if nothing happened. Total stop time, around 2 minutes (most of that time pumping the tyre back up to pressure)
This is about as bad as it gets too. In fact it's the first time I've had to actually stop on the road in 2 years of using tubeless road tyres. The only reason I know exactly what to do in this scenario is from over 15 years of mtb tubeless experience. Even then it's a pretty rare occurrence and I have never ever had to resort to fitting a tube in all these years. But I do carry one on long rides just in case.
But be warned! Some other people just seem to get into all sorts of **** trying to deal with tubeless flats!
Likes For PeteHski:
Quoted: 83 Post(s)
Liked 157 Times
When my friend switched to tubeless I was highly skeptical at first. Because I read on these forums that tubeless are painful junk. But gradually he learned how to handle the new technology and practically stopped getting flats. Before tubeless he would get a few flats every months. With tubeless all small punctures would heal themselves. The rare large ones can be fixed with bacon tool or even better the Dynaplug system.
Looking at his success I also got a new bike with tubeless tires. Hutchinson Sector 32 rear, Conti GP 5k front. After more than 5k km I haven't had a single accident of a flat interrupting my ride. Whatever punctures I get would heal themselves. Usually I notice them after the ride by white spots on tires and sometimes white remnants of dried sealant on frame.
We both use Orange sealant since it is supposed to be better than Stan for plugging punctures. Maintenance is not that hard - mount tire, add sealant, seat the tire by CO2, pump to max pressure, rotate in all directions and orientations to distribute the sealant. After that add sealant every 3 - 6 months depending on weather temperatures and how many punctures have happened during that time.
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
They are horrible. I spend hours putting new sealant in every week. Not to mention that if I have a flat or when a tire wears out I will have to get schmutz on my hands, so I sit by the side of the road or in my garage with the door open and cry until a boy scout happens to walk by and change my tire for me...
And worst of all is when I don't even know that I had a puncture and I get home and there is this dried rubbery crap on my frame and I have to take the rear wheel off to get in there with a cloth and wipe it off. And then I need to throw my riding gear in the wash because it has this water soluble stuff on it... It would have been so much better to just put a tube in there on the side of the road than to ride all the way home only to discover that I was riding on 75 PSI instead of 100!!! That is what happens to me most often and I am getting tired of it. I wouldn't buy it if I were you!
By the way, what size is this bike and do you have contact info for the seller?
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2560 Post(s)
Liked 5,591 Times
I am disappointed with the tubeless setup I had done recently, yet I'm determined to make them work. Had the LBS build me a wheelset with tubeless rims and install tubeless tires. They've set them up twice now and they will not hold air more than a few minutes at a time after the tires came "unstuck" from the rims from the weight of the bike pressing down on the flat tires as the bike leaned against a wall in the garage. I'm so frustrated about it that I'm just not riding it. Eventually I'll quit being stubborn, but I just can't deal with them right now. I've spent too much time pumping them up in my garage over and over when I wanted to go riding on the weekends. They either won't "stick" at all, or do for a short while but then go flat in the ten minutes it takes me to run inside to put on my bike shorts, fill a water bottle, and put on my shoes. Everyone says, "they aren't supposed to come off the rim, even when low on air" but they do.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Grupetto Bob
Liked 5,591 Times
Likes For rsbob:
Quoted: 760 Post(s)
Liked 1,717 Times
Likes For jaxgtr:
Quoted: 760 Post(s)
Liked 1,717 Times
You are right. I don't know. Getting a tubeless tire SOUNDS like it's harder to get the bead right without a compressor. You need a lot more pressure to get bead to seat right, sounds like you need a compressor not just a hand pump but again maybe I'm making to big a deal out of it. Sounds like flats are a lot less frequent so maybe I'll give it a try. I can always go back
Quoted: 760 Post(s)
Liked 1,717 Times
Likes For jaxgtr:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,645 Times
Liked 4,824 Times
If you have to add a tube, seating is no different to a non-tubeless tyre. It's trying to seat them tubeless that can potentially be a problem. I wonder if CO2 would work in that scenario? Not something I've ever had to face.
Liked 4,824 Times
the one time I had a bad sidewall puncture, I did have to remove the tubeless tire, valve stem and insert a tube and boot for the cut. For me, it was no more difficult than any tubed road side flat other than getting sealant on my hands which some grass took care of. The tire with tube seated fine.
Likes For PeteHski:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 266 Post(s)
Liked 447 Times
Or go with a tube. Get a nail that makes not one but two holes in the tube. Then spend time pulling the wheel and changing the tube. Can’t wait to wear out this set of tube tires and go tubeless.
I switched to tubeless to enjoy the big improvement in ride that I get from riding 28mm michelin tires with a pressure in the 60's, as recommended by the pressure calculator at zipp.com. Before tubeless, I had no punctures in 10,000 miles, but I did have two pinch flats from hitting rocks that are common on mountain road sides. I also figured out that my old pump gauge was reading high by about 8 psi,so the 80psi I was using in my 25mm tires was really only 72, which contributed to the tubed pinch flats.
I've hit a rock big enough to bend my rim a little, but with tubeless I don't get a pinch flat or lose any air.
I don't have to use rim tape with my Fulcrum racing 3 wheels. I use orange seal endurance sealant. I carry a tube and two CO2 cartridges so I can add some air if needed or inflate my spare tube. I don't carry any plugs or bacon strips. I do have nitrile gloves and a stem removal tool in my repair kit that fits into a plastic sandwich bag. I like to put that in a jersey pocket rather than use a seat bag.
Likes For DaveSSS:
Grupetto Bob
Liked 5,591 Times
Just wondering about the second scenario. Why would you ever need to seat a tubeless in the field? The only thing that comes to mind is not carrying a spare tube if you get a massive hole which a plug and sealant won’t take care of,. But then patching on the inside of the tire along the road is problematic getting a patch to stick without thoroughly cleaning that area. As one other poster very delicately put, Only a moron would ride tubeless without a spare tube, or something to that effect. Delicate or indelecate, he is right and you should never be in that position unless I can’t thing of a scenario, which is possible.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
I'm slow to adopt new technology, but once I bit the bullet and put tubeless tires on my mountain bike and one of my singlespeeds, I'll never buy another bike or wheelset that requires tubes. Initially mounting one set of tires was a little tricky, but that was so long ago I've all but forgotten about it. And even though I carry all the stuff to repair a tubeless puncture, I've never had one that didn't seal itself, usually without me even knowing it was there. When I think about all the patch kits, pinched tubes, and invisible thorns I've dealt with over the decades, tubeless seems utterly effortless by comparison. Literally, you tape the rim, push in a valve, pour in some goop, inflate the tire, and then never think about your tires again until you need to add air or more goop. Heck, the improved ride quality is worth it all by itself.
Likes For Rolla:
Guest
Liked 3,270 Times
Bikes: Early 70's Stella -> Gravel SS Conversion, 2019 Trek Stache SS
Quoted: 7 Post(s)
Tubeless tires haven't given me any issues since sometime around 2015 when all of the rim and tire manufacturers starting figuring it out. Set up became quick and easy, and my slow leaks were a thing of the past. It's 100% the way to go in my opinion.
Likes For themrbruceguy:
Liked 4,824 Times
In reality I’ve never had a tubeless tyre actually unseat out on the road or trail. So I’ve never had any trouble adding air after a tubeless repair.
Grupetto Bob
Liked 5,591 Times
Actually the scenario I was thinking about was where you could easily use a Dynaplug to seal the hole, but the tyre had unseated making it very unlikely to re-seat tubeless using just a mini-pump. So then you would have the extra hassle of fitting a tube just so you could re-seat the tyre. So I was wondering if CO2 would avoid this by re-seating the tyre tubeless.
Likes For rsbob:
Quoted: 20801 Post(s)
Liked 9,448 Times
Quoted: 383 Post(s)
Liked 690 Times
Guest
Liked 3,270 Times
Liked 4,824 Times
Reality is overrated. Besides a good portion of the population lives in an alternate one anyway (you can take that anyway you want). I have never had a tubeless unseat either, whether MTB or road tire, so couldn’t say whether CO2 would work either (thanks for the nothing reply to your question). If it did unseat and CO2 cannot do it, then it’s back to the tube, call of shame, AAA Roadside Assistance ride home, or Uber. Pride would make me go for the tube first. If it ever happens please update what you did - current reality please.
I've had one tire/rim combo that would unseat at very low pressure (like, under 10psi or so). If that experience in anything to go by, tires that unseat at low pressure are pretty easy to seat, so I would expect that a shot of CO2 would do it. Before you get to that point, though, I would try to get a thumb on the puncture, in an effort to maintain some pressure, while prepping a plug/bacon strip to shove in to it.
I used to carry CO2 when mountain biking, but haven't bothered for years. But I did just upgrade my mini-pump to a Silca Tattico for road use, which makes light work of reaching my normal running pressures (70 psi).
and for anyone who hasn't done it before, putting a tube in a tubeless tire is a disgusting mess on the roadside!
Likes For Caliper:
