stem expander cone 'nut'
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
The first couple mm of threading of the cone-shaped expander nut of the stem on my '72 PX-10 are stripped. The cone is a very tight fit in the stem and the bolt is just long enough to reach it, but not long enough to get properly threaded.... So I either need a new expander cone, or a longer bolt (M8x1.0 x 155mm or more.....), and I'm not coming up with either. Other than finding a new/old stem (which maybe isn't a bad idea, I'm not sure if what I've got isn't a 'suicide' stem- it is an AVA..... though I do kind of want to keep the bike as original/period as I can), anyone know of a source or have any ideas?
Half way there
Quoted: 986 Post(s)
Liked 880 Times
If it has two slots, it's almost certainly a "suicide stem". Some of the single slot stems are suspect as well, needing routine inspection. I have a single slot AVA on one of my bikes and am fairly comfortable with it.
Re: your issue - Have you tried gently tapping the cone into the stem so that you gain a few millimeters? I don't think that would expand the stem too much so that it wouldn't fit the steerer tube. I'd also suggest filing the bottom of the stem to gain some space. I've done this with wedge-style stems when the wedge threads are partially stripped. You could also remove the bolt washer to install the stem. If this got the stem nice and tight, you could then remove the bolt and reinstall the washer.
Good luck.
Good luck.
Likes For Moe Zhoost:
Quoted: 930 Post(s)
Liked 1,291 Times
If you're not at the minimum insertion height and it's not a suicide stem you could cut off a few millimeters off the bottom of the stem and lengthen the slot(s) if necessary to give you a better thread purchase. However, I'm suspicious that your bolt isn't long enough to go through the cone nut. It sounds to me like something is amiss there so perhaps you'd be better off buying a different stem..
Likes For davester:
Quoted: 761 Post(s)
Liked 1,563 Times
Good luck.
Good luck.
Quoted: 761 Post(s)
Liked 1,563 Times
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
If the cone is stripped or threads compromised then it is probably not safe to ride.
any thoughts from the group about converting the stem to a wedge ? has anybody done that ?
you'd need a donor stem or lower wedge piece
/markp
/markp
Quoted: 761 Post(s)
Liked 1,563 Times
The cone is 13mm or so tall, and it's only the top 3 or so mm of threading that is stripped, the rest is fine. But with the bolt being just long enough to engage and pull the cone up into the stem if the threads are good all the way to the top means I couldn't get enough threading to engage to get it started. But I cut about 4mm from the bottom of the quill and that was enough for the bolt to engage and then get several full turns of tightening.
Likes For ehcoplex:
