Schwinn IC3 stationary bike seat suggestions
Hi. I am looking for suggestions (any and all price ranges) for a more comfortable seat than the stock Schwinn seat.
I want to begin a cycling routine that will feel a bit more comfortable for longer trips.
Suggestions on brands, models, price range and where to look for a good quality comfy saddle for a 240 pound frame
The stock seat is ok but not very comfortable for any length of time spent on the bike.
If I am going to be utilizing this exercise bike as intended , no point in "suffering" with the stock seat.
May as well go up one or two notches on comfort and quality
I have seen a lot of options, but want to be better informed or educated on choosing a saddle that will accommodate 240 pounds comfortably.
Thanks, Steve
Thanks, Steve
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Question:
I'm not familiar with that unit. Can it take a standard bike seat?
What are you wearing? Can you wear bike shorts with a padded seat?
It's a very personal decision, but I ended up with a Brooks B17 on my Wahoo Kickr bike.
Quoted: 4387 Post(s)
Liked 4,827 Times
At a quick glance it does look like it can take standard saddle rails and the stock saddle looks hideous!
Now saddles are a very personal choice, but I would start with something pretty standard and not too expensive like a Fabric Scoop - that most people would get on with reasonably well.
Don't fall into the trap of thinking that you need extra padding or width. Those huge "fatboy" saddles you often see on gym bikes are not actually very comfortable beyond an hour of use. They feel superficially comfortable to sit on for the first few minutes and then you realise that your sit bones are not properly supported, which can be agony after an hour of pedalling.
Yup, with the proper seat and positioning it'll make a world of a difference. When I was first looking for a new saddle, I was about to pull the trigger on a fat boy cushion saddle. Then after reading up on ****** I realized that those sofa-like saddles usually cause more problems than helping you.
I went down to my LBS and sat on their sit bone measurement device and went with a 155mm Specialized Expert Mimic saddle and never looked back. It wasn't cheap at $160 + tax but it has been oh so comfortable, even spinning for extended periods.
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Finding a saddle that fits your, eh .... frame..... is a bit of an issue.
As previously said the Fabric Scoop can be a good option for some people, but be aware that the Scoop comes in two Widths and 3 different curves!
Finding the right one for you can be an expensive experiment. I myself have two Scoops (saddles not ice cream) and others, in my parts bin.
Determining how a saddle fails to fit is very important. Exactly where does it rub, chafe, place pressure.... will help you find how your existing saddle fails to meet your requirements.
Do take your existing saddle to the store for a side by side comparison.
Also of great importance is the angle adjustment of the existing saddle.
Start with the saddle perfectly level (using a bubble level) and make very small adjustments.
Be aware, if the saddle rubs in the front and you tilt the front downward, this can cause the pelvis to tilt further forwards making the rub in the front worse.
So the required adjustment can be counter-intuitive.
I personally use a digital level so that I can reproduce a saddle angle accurately.
I then keep paper notes regarding angle and my felt result. It took some time, but I've now the perfect saddle & setup for my outdoor bikes + the same setup on my Indoor Wahoo Kickr Bike.
All the best
Barry
All the best
Barry
