My FnHon Gust 16" 2022
Quoted: 419 Post(s)
Liked 537 Times
'Sand Red', rim-brake FnHon Gust 16"
Starting the assembly process...
Waiting for the press fit tool to arrive to install the headset. Still undecided on 305 or 349 wheels...
Likes For Ron Damon:
Bikes: There is always room for one more.
Quoted: 179 Post(s)
Liked 366 Times
Love that paint color! Based on the seat post and bottle cage, are you going with black components?
Don
Don
Quoted: 419 Post(s)
Liked 537 Times
Yes, that color is pretty sweet, likely the best of that generation (the last one made for rim brakes). Candy 🍎 Apple, I call the color. Indeed, Black will be the theme color. Though it will have a few red flourishes here and there...
This looks to be an MTB cassette. About 40t? Are you sure the derailleur will accommodate this cassette and it’s cage not hitting the surface with 16’ wheels?
Quoted: 179 Post(s)
Liked 366 Times
I'm no expert but it appears to me that the derailleur is using larger jockey wheels rather than a long cage so it should work okay. One thing for sure though, that little guy will be able to climb walls!
Don
Don
Quoted: 419 Post(s)
Liked 537 Times
The cogset is a Shimano Deore HG50 11-36t 10-speed and the RD is a Freeride spec Shimano Zee which is rated for 36t, precisely the same setup I've used on my other 305er for years with smaller tires. So, no, I am dead certain this set up will work with even more plump tires. I've been down this road before when it comes to the drivetrain.
Btw, I've seen the same RD used with a 11-42t cogset. The RD will work fine. I choose to stay at 36t max which is plenty low.
Quoted: 419 Post(s)
Liked 537 Times
I live in what is essentially a volcanic spine risen from the ocean to 3,100masl at its peak. There are climbs, steep ones, aplenty here plus I tour with a bit of load.
Quoted: 419 Post(s)
Liked 537 Times
MTB Deore M6000 GS RD & HG500 11-42t Cogset paired with XT shifter up front on 406 folder
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x9,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 249 Post(s)
Liked 221 Times
However, in the folding bike world, MTB are more popular because tougher as mentioned also "weight winnies" have been fitting things like ultegra and other TT groupset to lighten their rigs.
The Road cassettes tend to have shorter range and be lighter. At equivalent range, the difference is the metal used wide range ultegra/durace will be made of similar stuff as XTR. SLX 10 is like Tiagra but Sora goes up to 34 max.
I like my SLX 11-46, not the lightest but crisp shifting, very durable and inexpensive (unlike my favorite e13 cassette).
Quoted: 419 Post(s)
Liked 537 Times
Not quite, road flat shifters have been around for many more years than 3... they were used on hybrids (the old tourney comes to mind).
I think the equivalence goes like this:
1. XTR - DuraAce
2. XT - Ultegra
3. SLX - 105
4. Deore - Tiagra
I usually stay within the 2-4 range of components.
Likes For GeezyRider:
Quoted: 419 Post(s)
Liked 537 Times
Palmer
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1644 Post(s)
Liked 1,785 Times
55+ Club,...
Bikes: 9+,...
Quoted: 1085 Post(s)
Liked 821 Times
https://www.google.com/search?q=Shim...obile&ie=UTF-8
iti biking
Or for half the price and one gear less, the Microshift Advent super short rear derailleur, officially 9 speed and 11-38t. No, I’m not on commission!
Quoted: 179 Post(s)
Liked 366 Times
I have to get out of my cave more often. Zee has been around for 10 years and I'm just now learning about it.
Don
Don
iti biking
Any recommendations for a 305 or 349 frame out there suitable for someone about 180cm tall then? Or do I just have to accept that I’m stuck on 406s, Birdies or Bromptons? (Nothing wrong per se with those options, just musing on a day when I may need a smaller wheeled folder for ease of multimodal travel without spending substantial amounts of money for an off the peg ride).
Quoted: 249 Post(s)
Liked 221 Times
Note that I was told that there were frame cracking issues with the early Dahon MUL sl and the fix by Dahon was to go from a seatpost tube OD of 40 to 41mm. then, problem gone
Quoted: 419 Post(s)
Liked 537 Times
Or the similar offering from Litepro, the Spyder.
In all cases you'll want a banana handle post that curves away from you, as in the one on the Spyder.
iti biking
Luckily, I’m well within those weight limits so both those options could work. I’ll keep those models squirrelled away for future reference, thanks 😊
QR-disc must die!!!
Bikes: '99 Trek 520, '20 Kona Sutra (FOR SALE 48cm), '21 Simon-Bikes mini-velo and a chromoly-framed folding bicycle with drop-bars and V-brakes, that rolls even while folded.
Quoted: 397 Post(s)
Liked 199 Times
Well done. Fnhon chromoly with V-brakes is the best thing going for folding bicycles.
Likes For Nyah:
Quoted: 179 Post(s)
Liked 366 Times
Coming along nicely. Are the Maxxis Hookworms and Swallows the same tire? They appear to have identical tread patterns.
Don
Don
